Massive oil leak from the rear. | FerrariChat
Discussion in 'FF/Lusso' started by HBstig, Oct 25, 2020.
  1. HBstig
    HBstig Karting
    Nov 3, 2019
    164
    HBstig
    I went for a normal drive this afternoon and when I got back to my garage I noticed a puddle of fluid leaking from the rear of the car. Any ideas of what it could be? Rear diff? Where are the transmissions located? 2914 FF with 10k miles. Thanks Image Unavailable, Please Login
    Sent from my Pixel 4 XL using FerrariChat.com mobile app
  2. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    I assume no dash sign? Hopefully it’s not the PTU.
    Did u get the warranty just in case?
    Gosh those FF are not that reliable. Hope it’s nothing!
  3. HBstig
    HBstig Karting
    Nov 3, 2019
    164
    HBstig
    Nothing on the dash. Isn't the PTU in the front? No warranty. :(
  4. Akhil
    Akhil Rookie
    Feb 19, 2019
    32
    Medina Washington
    Akhil T
    I came across the same issue during July, The rear trans seal failed which caused fluid to leak out and occasionally started smoking during driving. I got my tech to rebuild the trans and issue free since.
  5. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    That definitely looks like coming from the main tranny. You should take it to the dealer asap.
  6. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    The FF has a Transaxle. This is not an FF issue. The FF has the same unit as the F12, Lusso and 812. It might be a seal, or it might be a bearing. Seeing that you have no warranty, let's hope it's a seal. I will strongly advise you not to drive it to the dealer. Get them to arrange transport.
    The PTU is on the front of the engine, so that has nothing to do with oil from the rear.
  7. HBstig
    HBstig Karting
    Nov 3, 2019
    164
    HBstig
    Why did you have to rebuild the whole trans? How much did it cost?
  8. Natkingcolebasket69
    U mean it could be DCT?
  9. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Yep. The DCT and rear diff is basically built as one unit and is part of the rear axle. That's why our boot space sucks:D
  10. Akhil
    Akhil Rookie
    Feb 19, 2019
    32
    Medina Washington
    Akhil T
    Rebuild cost for me was $15k out the door. My tech advised me since my unit is early production there's a set of issue that needs to be addressed to prevent any failures in the future.
  11. HBstig
    HBstig Karting
    Nov 3, 2019
    164
    HBstig
    Why couldn't he just replace the seals?
  12. Akhil
    Akhil Rookie
    Feb 19, 2019
    32
    Medina Washington
    Akhil T
  13. HBstig
    HBstig Karting
    Nov 3, 2019
    164
    HBstig
  14. ttforcefed
    ttforcefed F1 World Champ
    19,254
    DCT or PTU?
  15. Cavallino Nero Rampante
    Aug 16, 2018
    140
    ST
    Hi Akhil,
    When you say, "But for me I just did the rest", what exactly are you referring too?
    Thank you kindly.
  16. HBstig
    HBstig Karting
    Nov 3, 2019
    164
    HBstig
    I think he just did a full rebuild.
  17. Natkingcolebasket69
    Just FYI my car was a 13 ans Ferrari refused to do extended warranty to previous owner until he replaced as a preventative measure the DCT. So not sure they will tell u yes straight up. They are smart like that!
  18. Akhil
    Akhil Rookie
    Feb 19, 2019
    32
    Medina Washington
    Akhil T
  19. ttforcefed
    19,254
    u can get that done for a 1/3 of the price at an independent. ur paying 2x for all the parts and its a 17 hr job
  20. HBstig
    HBstig Karting
    Nov 3, 2019
    164
    HBstig
    That would be illegal. Can't ask a customer to replace something as preventative measure to obtain warranty.
    350MH83 and Il Co-Pilota like this.
  21. Natkingcolebasket69
    Well they inspected the car and told him his dct was about to fail so he replaced it but it was still
    Cover by warranty though.
    Il Co-Pilota likes this.
  22. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,211
    Santa Barbara County
    Sam
    I had twice as much fluid as that last December after driving very spirited the day before. I had 35K miles and extended warranty on my 2012 FF. It was $15K to fix. Said it was the intermediate transmission needed to be replaced. No problems since.
  23. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Not entirely so.
    A tear-down and cleaning is a minimum. First off, where has the piece of seal that has detached itself ended up? Is there any kind of debris in the trans? You don't know.
    Has the leak caused water or dirt to enter?
    Has the low fluid level damaged clutch plates? Has moisture or debris affected clutch plates?
    When you are dealing with this kind of issue, there is a very good chance that everything's fine, but a clean and inspection is a must.
    This is definitely a case of doing it right the first time is the cheapest fix.
    papou and Natkingcolebasket69 like this.
  24. Solid State
    Solid State F1 World Champ
    10,564
    Maximus Decimus Meridius
    What year was the covered work done If you remember?
  25. Natkingcolebasket69
    My car is 13 and they did it in I believe 16-17 got check records
    Solid State likes this.
