430 - manual 1st and 2nd gear shift | FerrariChat
430 manual 1st and 2nd gear shift
Discussion in '360/430' started by Paul Kane, Jun 21, 2020.
  1. Paul Kane
    Paul Kane Karting
    May 27, 2020
    228
    Rickmansworth UK
    Paul Kane
    Why is it the 1st and 2nd gears have a life of there own?
    Very difficult to get in to these gears, when engine and gearbox is hot its much easier but still notchy.
    Is there a one off cure for this problem....thanks
  2. catdog
    catdog Formula Junior
    Aug 18, 2010
    252
    I think there is...
    My F430 recently had F1 to manual conversion by European Auto Group and think of the pieces in one part of the linkage is improved compared to factory stock. I was just thinking yesterday how precise and accurate mechanism was. Only notchiness is first 1st-2nd shift when cold then it's perfect, and that one easily dealt with double clutch little rev. Ask for Art, he may be able to help...
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,314
    South East
    Jimmie
    Pretty much every manual Ferrari struggles with 2nd from cold - some find improvement with different gear oil eg Redline
  4. one4torque
    one4torque F1 Veteran
    5,123
    Houston
    One4torque
    Let it warm up..... then you will be happy
    DOWORKFCAR and EastMemphis like this.
  5. RedTaxi
    RedTaxi F1 Rookie
    3,256
    New Zealand
    Glen
    Does the stick have any looseness/play side to side in neutral. If so the plastic clevis/bush may be flogged or broken. Hill Engineering do an aluminium one that made a huge difference on mine.
    JaguarXJ6 and Bigilo like this.
  6. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    817
    S La
    Great point Red Taxi and that just might be the primary problem.
  7. brogenville
    brogenville Formula 3
    2,020
    Robin
  8. saudio
    saudio Karting
    Jul 22, 2014
    169
    Western Virginia
    Good to hear that. Whew! :)
  9. catdog
    Aug 18, 2010
    252
    Excellent point, great to know for the future!
  10. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,651
    England
    Mark
    It should go in with precision and no different to the other gears. It could be:
    Bushing,
    Clutch wear,
    Old brake fluid in the slave cylinder,
    A broken brake fluid distribution block on the gearbox
    Cable adjustment.
  11. Paul Kane
    Paul Kane Karting
    May 27, 2020
    228
    Rickmansworth UK
    Paul Kane
    Thanks for the info everyone.
    Got good and bad news.
    Good, bought a Hill Engineering bushing.
    Good, ordered 3xUS gallons of Redline 70W90 GL50 gearbox oil.
    Bad, the existing bushing is in peices, loose washers are floating about from a previous botch repair.
    Really Bad, broke the gear stick as gear knob and locking nut glued and over tightend.
    Bad....Expecting a large ££££$$$$ bill now.
  12. Paul Kane
    Paul Kane Karting
    May 27, 2020
    228
    Rickmansworth UK
    Paul Kane
    Forgot to mention, there is another worn bush in this area, I'll let you have a picture and its part number soon.
  13. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,651
    England
    Mark
    How did you manage that :(
  14. ItalGerBrit
    Mar 15, 2016
    817
    S La
    My question as well. Might be the first one ever broken. F1 guys will love this. "Did you hear that, MT knobs are falling off. Glad I have an F1".
    Performante and kes7u like this.
  15. brogenville
    2,020
    Robin
    Doh!
    That's intensely annoying. Find a good TIG welder and get that one fixed. I would be looking to do that before going for a replacement, which may well not be available any more from Ferrari.
    If EAG really are selling reproductions, you could probably get a new gear stick from them too.
  16. ItalGerBrit
    Mar 15, 2016
    817
    S La
    Or a machinist could rethread the end of it. Shorter throw but still should work just fine.
  17. ItalGerBrit
    Mar 15, 2016
    817
    S La
    Lot of finger flippers on Ebay. No "real" manly shift rods. :D
  18. Paul Kane
    Paul Kane Karting
    May 27, 2020
    228
    Rickmansworth UK
    Paul Kane
    It wasn’t me that broke the gear shifter, it was the technician, he said the gear knob had been glued and over tightened, heating still didn’t loosen it.
    Must have used a large wrench and then snap.
    New shifters sticks are available at a cost approx £360 plus a new knob and lock nut from Hill Engineering at £60 delivered.
  19. Paul Kane
    Paul Kane Karting
    May 27, 2020
    228
    Rickmansworth UK
    Paul Kane
    Got the car back yesterday and pleased to say the gear shift in 1st and 2nd is perfect now even from a cold start. I did notice it all tightened up when up to temperature but all gears were easy to change into.
    Besides needing a new gear lever and chrome knob the common fault plastic bushing (now Hill Engineering part) was in pieces and another bushing close by was also badly worn and replaced. Everything was greased up, then linkage cables adjusted.....sorted!
    The exhaust brackets were cracked so replaced with stainless steel ones from Suoerformance.
    A happy ending, sort of £££££££
    mwstewart and brogenville like this.
