Major started on the 512tr | FerrariChat
Discussion in 'Boxers/TR/M' started by Zeff, May 25, 2020.
  1. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    692
    Cupertino, Ca
    Ryan
    #1 Zeff, May 25, 2020
    The belts looked like they were brand new. Major was done 5 years ago. With 1k miles.
  2. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    692
    Cupertino, Ca
    Ryan
    Some cheap hose clamps were used on the last major. Also he will be doing the diff upgrade using Newman’s. I will also be adding a New exhaust.
    MM355 likes this.
  3. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    692
    Cupertino, Ca
    Ryan
  4. JPMD
    JPMD Karting
    Jan 17, 2016
    146
    FL
    subscribed
    michaelcwfung1237 likes this.
  5. eziotestarossa
    eziotestarossa Karting
    Mar 28, 2014
    92
    Delray Beach, Fl
    Ezio
    Awesome! Belts look like you just put them on!
  6. sherrillt
    sherrillt Formula 3
    1,119
    Northern Virginia
    What did you expect. Oddly, why do people think belts and hoses are go bad in 1k miles?!?
    If a car is not driven and there’s little heat or stress on rubber and plastics the engine will look like this one (like a fresh major).
    Natkingcolebasket69 likes this.
  7. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,505
    romano schwabel
    but when the belts are old and never or nearly never running then it will take not long time when they will run after for example 10 years that they will get destroyed soon
  8. sherrillt
    sherrillt Formula 3
    1,119
    Northern Virginia
    Don’t mean to take the thread down the periodIc belt debate, so I’ll say my piece and shut-up/let it go.
    To say basically an unused engine needs a mini overhaul (Belts, seals, gaskets, hosed, Tabs, etc) doesn't make much sense. It is back to the periodic belt argument of what’s the expiration date on NOS belts?...I have had extremist tell me NOS rubber items were garbage after 3-4years (which is nonsense).
    As in past debates arguably it is always about tensioners, which need to wear out, that causes problems and not 1-3k mi barely used belts on whats typically a cruiser car - such belts spontaneously breaking is highly improbable.
    I aspouse condition based maintenance that is based on age, driving Style/miles (driving avg miles), and environmental (running in hot/cold Temps) factors assuming the engine bay gets hot for a prolonged period and all of these are what drives the manufacturer to prescribe a Conservative service interval.
    Although it’s a good precaution after 10+plus years to perform a service on such an expensive car, to perform such a costly breakdown on a 5yo/1k engine is a preference, and not a requirement if that’s what anyone might believe.
    Comparative Example - My Corvette belts are still the original from 2011 on a 9kmi ZR1; they aren’t “magic belts“ that are made better or last longer than the belts in my 512TR and they are just fine (no stress cracks) and I have no plans to replace them in the next year as that car will probably not see 1kmi this year.
  9. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    692
    Cupertino, Ca
    Ryan
    I agree with everything you said here. The main reason I wanted to go ahead with the major was because I wanted the diff upgrade. After Shamiles car had a problem I didn’t want to take any risk. My mechanic said, dont do the major right now. With my light use of the car, he recommends doing the major every 7 or 8 years.
    EZORED likes this.
  10. ago car nut
    ago car nut F1 Veteran
    5,495
    Madison Ohio
    David A.
    Diff problem keeps you up at night!
  11. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    692
    Cupertino, Ca
    Ryan
    Almost, lol. I called Brian Or Rifledriver and had a long discussion about this. If it occurs and does major damage will cost a small fortune. He said do it ASAP. Plus, the parts are getting difficult to resource. I trust his input so I went for it early. Funny thing is, my mechanic said some of the valves were loose. So I guess the stealer didn’t check the valves when they did the last major. At least that’s what we both concluded.
  12. turbo-joe
    Apr 6, 2008
    9,505
    romano schwabel
    what you understand under this? too much valve play? under loose I understand somethinging other - so for example play in the valve guides
  13. ago car nut
    5,495
    Madison Ohio
    David A.
    I did three different times valve settings, none of valves were out of tolerance!
    Zeff likes this.
  14. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    692
    Cupertino, Ca
    Ryan
    I found 6 of exhaust valves loose and one intake. Others check okay.
    Intake valves set .025 /.030 mm
    Exhaust vl. Spec. .030/.035mm
    Reply from mechanic yesterday.
  15. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    692
    Cupertino, Ca
    Ryan
    Yes too much play.
  16. Clyde Romero
    Clyde Romero Formula Junior
    Sep 6, 2019
    760
    Atlanta Georgia
    Clarence Romero
    totally agree
    I have a 512 TR with 110 k on it
    replaced the belts after 40k
    use it or lose it
    sherrillt and Zeff like this.
  17. Clyde Romero
    Sep 6, 2019
    760
    Atlanta Georgia
    Clarence Romero
    very rare
    they barely move until around 60k
    then the exhaust valve eat into the heads
  18. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    692
    Cupertino, Ca
    Ryan
    Yeah, the mechanic thought it was odd too.
  19. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    692
    Cupertino, Ca
    Ryan
    The major is now complete. He did run into trouble with the Ferrari dealership using too much silicone on the cam heads. But everything is ok now. I decided to wait on the Kevlar clutch as my clutch was brand new and he talked me out of it. But new hoses, exhaust, and diff upgrade completed. 16k plus the cost of the diff part 3500 plus the exhaust. Total 24k. Who says you can’t do a major for 5k with all the extras you may need or want? Fools I tell you, just Fools!! Lol
  20. Clyde Romero
    Sep 6, 2019
    760
    Atlanta Georgia
    Clarence Romero
    get the silicone hose kit and replace the S upper hose to the radiator pipes along with the other lower hose
    save the old hose and always carry it with you
    it will be the one to burst since its on top and catches all the heat and you actually replace it on the road if it goes
    don't ask me how I know
    also replace the hoses under the intake manifolds they catch hell
    use marine hose for that if you can
    check your front main seal as well
  21. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    692
    Cupertino, Ca
    Ryan
    Thanks Clyde for the info. He also replaced the fuel cross over hoses. Take a look at what the dealer installed on the last major for fuel hoses.
  22. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    692
    Cupertino, Ca
    Ryan
  23. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    692
    Cupertino, Ca
    Ryan
    #23 Zeff, Aug 13, 2020
    The dealer charged 25k last major. Garbage service quality. I had high expectations of them initially. Never again! I really enjoyed the process of getting the major done. I now have a good foundation with the car. I know that everything is done correctly and is current. It’s just ready to drive and enjoy. I don’t think you have been properly initiated into the tr world until you Have at least one major under your belt.
  24. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    Now for sure u better keep her 10+ years!
    turbo-joe likes this.
  25. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    692
    Cupertino, Ca
    Ryan
    Thanks Nat! That was always my intention.
