355 - M5:2 but not OBD II | FerrariChat
355 M5:2 but not OBD II
Discussion in '348/355' started by Klas, Feb 19, 2021.
  1. Klas
    Klas Formula Junior
    Mar 17, 2014
    329
    Gothenburg, Sweden
    Klas Nilsson
    My MY97 F355 with the M5:2 engine management system does not have OBD II diagnose system which I thought came with the M5:2. Obviously not. Anyone have this experience? I have EU spec (Germany)
  2. Qavion
    Qavion F1 World Champ
    11,578
    Ian Riddell
    Only North American cars have the 16 pin OBD2 port. The rest of the world uses the Ferrari SD1 tool or a much cheaper "Fiat 3 pin OBD2" port adaptor attached to the matching connector on the Motronics ECU.
    https://cablematic.com/en/products/obd-ii-connector-adapter-to-fiat-3pin-OB044/
    Use the 348/355 forum Search to find further information on the subject. Some Fiat adaptors for sale don't always fit.
  3. PaulK
    PaulK F1 Rookie
    4,625
    Michigan
    Paul
    This is a DUMB question, but could I use that connector on my 2.7?
  4. Qavion
    11,578
    Ian Riddell
    I'm sure it has been tried before without success. The data coming from the 2.7 is probably not in the correct OBD2 format.
    I guess you're stuck with the pushbutton/flashing CEL method.
    PaulK likes this.
  5. PaulK
    PaulK F1 Rookie
    4,625
    Michigan
    Paul
    I see. I am wondering about finding a used Launch and seeing if it can read the data from the 2.7 but I think you are right. Thank you.
  6. salbrech
    salbrech Karting
    Dec 20, 2013
    103
    I had the same problem on my Swiss-Motoronic 5.2.
    Its OBD2, but only with the 3pin AMP plug. In Switzerland no OBD2 connector adapter is installed (at least on my '96 model year). Also, I could not get codes form CEL flashing. Is CEL flashing working on a 5.2? or only on a 2.7?
    However I manufactured my own adaptor (looks actually 100% as the once from cablematic.com as mentioned above). The 12V I soldered into the main harness (Ignition on).
    Details see attachment. Working fine since several years.
    Greetings from Switzerland
