News
Lowered FF with spacers
Discussion in 'FF/GTC4Lusso/F12/812S' started by Brian L, Mar 7, 2017.
  1. Brian L
    Brian L Formula 3
    1,930
    Los Angeles
    Brian
    When I first got the FF it was so great there was no need to play with it. I thought I never would. WRONG.
    8000 miles later the wheels looked too small/narrow and the chassis looked and felt too high. A little floaty for my taste in all modes.
    Tom at Lucent (Fchat recommended, incredible skills and knowledge) has made it greater than ever. Lowered 14mm on stock springs, 15mm front and 18 mm rear spacers. Slight camber adjustment with the new alignment. Turn in slightly faster. Still the original MPSS tires with 9200 miles.
    Wow, it's never felt better. What a joy the drive I just took ! Like a new car, super happy.
    More planted at speed, better cornering, and overall just feels right on the suspension. Highly recommended.
    Autolove likes this.
  2. dmundy
    dmundy Formula 3
    Rossa Subscribed Owner
    Sep 11, 2010
    1,249
    Unspecified
    Arthur Dent
    Do you happen to have pics of the before/after? I'd be curious about how visible that change is.
  3. Brian L
    Brian L Formula 3
    1,930
    Los Angeles
    Brian
    #3 Brian L, Mar 7, 2017
    Not a specific before/after. Although I have posted the car here previously.
    It's a subtle drop. 14mm is 0.551 inch. Not enough to make life difficult. Here are a few quick afters in the garage.
    (also: cold pressures up a little always, around 36 and 39 psi)
  4. not4one
    not4one Formula Junior
    May 23, 2010
    886
    CT, FL
    The lowering looks perfect. The spacers look better than stock...but to my eye, the 18's on the back are just a smudge too much. Maybe try the 15's on the back? In which case 15's or 11's on the front...though I'm biased!
  5. saraojo
    saraojo Formula 3
    Mar 9, 2015
    1,274
    Northeast
    Looks great. The rear offsets look very aggressive. Similar to the setup on my r8. Some people thought it was a bit much but it made the car appear more low and wide..
  6. Autolove
    Autolove Karting
    Jun 8, 2012
    179
    S.A. TX.
    Ivan
    #6 Autolove, Mar 7, 2017
  7. Autolove
    Autolove Karting
    Jun 8, 2012
    179
    S.A. TX.
    Ivan
    Sorry for the last picture upside down��
  8. Brian L
    Brian L Formula 3
    1,930
    Los Angeles
    Brian
    For me, the FF too low makes the whole thing look top heavy and the rear end look larger. The gap above the tires becomes pinched making the gap around the tire sides seem to flare out oddly. To each their own, the center of gravity is happy there I'm sure.
    Agree for sure, could be 15 front and 15 rear with a 14 or 15 mm drop. Fronts need to be at least 12 so there can be a lip. 11 and lower just a floating ring.
    Am experimenting with the slightly wide 18s in the rear ... a little too wide is cool for now.
  9. Brian L
    Brian L Formula 3
    1,930
    Los Angeles
    Brian
  10. HBstig
    HBstig Karting
    95
    HBstig
    How do you lower the car with the stock springs?
  11. Altoria F
    Altoria F Rookie
    Jan 24, 2020
    26
    France
    P
    I lowered mine about 10mm as well with the stock springs.
    Even the 4 seats Ferrari are true sport car with adjustable coilovers.
    I come from the Porsche world where only the GT2/GT3 run adjustable coilovers.
    Notice the FF are often lower at the right side vs the left side from the factory, surprisingly much more than the "weight by wheels" balance needs.
  12. HBstig
    HBstig Karting
    95
    HBstig
    How did you lower yours with the stock spring?
  13. Altoria F
    Altoria F Rookie
    Jan 24, 2020
    26
    France
    P
    First you check the 4 wheels arch heights on a flat surface (mine and some friend's Ferrari were up to 9mm higher on the left!).
    So you bolt off the wheels, use a spring compressor tool to ease the spring tension and de-tighten your springs twin nuts a few turns.
    You adjust this way each wheel arch height, you can keep the left side 2mm higher than the right side if you often drive your car alone to balance the gravity center. (The inverse if in GB of course)
    I also like to "drop" a very little the front vs the rear (2-3mm), it gives a nice agressive stance.
    If your front is higher vs your rear it looks ridiculous IMHO, and it is often the way our cars are adjusted when stock.
  14. Mickey Bharat
    Mickey Bharat Karting
    81
    Cotati, California
    Mickey Bharat
    I heard on another chat forum that using stock springs to lower reduces spring tolerance and can not be a great ride. Better to replace the springs with something like Novitec. They are about $1700 for 4 and about $1200 labour. Not that expensive to get a great look and ride
  15. Brian L
    Brian L Formula 3
    1,930
    Los Angeles
    Brian
    I lowered 1/2" on stock which is fine. For $3000 Novitec is TOO LOW for my taste.
  16. HBstig
    HBstig Karting
    95
    HBstig
    Novitec has adjustable sleeves like coilovers unless I'm wrong.
    Sent from my Pixel 4 XL using FerrariChat.com mobile app
    ClayMan and Brian L like this.
  17. Brian L
    Brian L Formula 3
    1,930
    Los Angeles
    Brian
    Ah, I see them always looking too low, could be user pref.
  18. HBstig
    HBstig Karting
    95
    HBstig
    I checked with Novitec. It's fully adjustable.
