Looking for F355 F1 TCU! | FerrariChat
Discussion in '348/355' started by bders001, Mar 10, 2018.
  1. bders001
    bders001 Rookie
    Jan 4, 2015
    9
    Burbank, Ca
    Hello Forum,
    I have 98 F355 F1, I've changed everything regarding the clutch and even attempted to repair the TCU but still having a problem. Does anyone have, or know where I can get a new TCU? I have already tried Ebay, Ferrparts, and Scuderiaparts. Thanks in advance.
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    Welcome.
    What makes you think it is the ECU
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    What problems areyou having? Did you test itwith an sdx, or try a ecu that worked.
  5. FrederickWhite50
    Feb 22, 2018
    9
    F. White
    Try Dave Helms in CO, he can help
  6. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    Fast cars in cali
  7. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    If you filled out your profile we could tell you a dealer that is maybe closer
  8. bders001
    bders001 Rookie
    Jan 4, 2015
    9
    Burbank, Ca
    Thanks everyone for the responses. I ended up taking it to the dealer and they have stated the problem is from the F1 system. They recommended changing the whole system to solve the problem. Now I'm looking to convert it from the F1 system to a manual system because it would be a night and day difference in price. I have found many of the parts required to convert it. Would I be required to change the ECU for this job?
  9. windsock
    windsock Formula 3
    1,070
    What is your symptom?
  10. WATSON
    21,727
    WI
    What????? Just replace everything? SURE!
    Asked before...but what are the symptoms?
  11. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    If you convert it, I'm interested in the F1 parts.
    WATSON likes this.
  12. WATSON
    21,727
    WI
    Stand down son. I am already in line.
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Then why is my post ahead of yours ? ;)
  14. WATSON
    21,727
    WI
    I am on Central time zone...you are on Eastern....duh.
  15. Qavion
    Qavion F1 World Champ
    11,567
    Ian Riddell
    Do you mean the engine Motronics ECU (for the manual conversion)?
    I hope they said that as a joke. Just because they can't fix it, it doesn't mean someone else can't. I'm sure every individual component is either fixable or replaceable on the F1. Have they checked everything (including the engine/gearbox support mounts)? Ask them what their diagnostic computers are telling them.
    ernie likes this.
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Converting the car is, well, stupid. Sorry, it is. Clearly the people working on it have no clue. I want the parts but if the OP comes to his senses, I'd be happy to help him get the car in the hands of techs that can properly diagnose and fix the problem.
    tres55 likes this.
  17. WATSON
    21,727
    WI
    I have the whole process mapped to switch a car from F1 to Manual.
    It is not very hard from what I can tell. I have not done it so I am sure there are some surprises I have not fully defined.
    But why? The F1 system is not easy...but not very complicated.
    The F1 car, when running right is waaaaay cool.
    There are far fewer F1 cars than manual cars.
    To the OP...if you want to sell the car, let me know. I am interested.
    Post your issues in detail...lots of help here.
    Or PM me...Dave...or others....we can help.
    SoCal1 likes this.
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    As time goes on the idiots working on these cars keeps growing. Any tech wanting to switch an f1 because of costs is not someone you want working on anything because they are literally clueless.
    ernie, tres55, WATSON and 2 others like this.
  19. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    The OP needs to run and get the car to someone who understands it and is not trying to bend them over
  20. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,571
    SoCal LA/OC/New Mexico
    Tim Dee
  21. bders001
    bders001 Rookie
    Jan 4, 2015
    9
    Burbank, Ca
    The car doesn't change gears. Turn the car on, car goes into neutral and doesn't go into first when warm. Then it would engage randomly. Sometimes it doesn't go into reverse. Drove the car for 30 minutes with no problems and then it just wouldn't change gears after coming to a full stop. They said the F1 pump is losing pressure from the actuator and should have the whole system replaced. They also said the mounts need to be replaced because the engine is leaning on the hydraulic hose?Going to further diagnose the vehicle. They said that the diagnostic shows no codes.
    Any info helps.
    Thanks.
  22. Rossocorsa1
    Rossocorsa1 F1 Veteran
    May 14, 2017
    6,203
    For what it’s worth, the F1 is a much rarer variety than a gated car. They will be highly prized. You live in southern CA. I’m sure there are a few very capable hands that can fix your car as it should be done.
  23. WATSON
    21,727
    WI
    Pump could be failing. That's not new. Options exist from 360 pump conversion to OEM style replacement.
    The relay could be the problem...easy fix.
    Worn motor mounts will drop the engine and create a contact point on the input shaft at the cross bar. That's a real concern. You can see that easily looking underneath.
    I chased a similar issue. Not saying it is the problem, but a blown accumulator bulb makes the pump run all the time and completely screws up gear selections. It also ruins the pump in very short order.
    Take a look here: https://www.ferrarichat.com/forum/threads/f1-accumulator-bulb-replacement-procedure.555260/
    Based on what you just described..... I would....and I am not you....do this:
    1. New Motor mounts
    2. New pump (Juri or others)
    3. New "fail off" relay.
    3. Put in new accumulator bulb
    See what I got......carry on.
  24. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    My recommendation would be close
    New motor mounts
    Check how much motor runs
    If runs lots replace accumulator
    If motor drawing more than 10 amps replace.
    Also when reading Watsons post I believe he meant to change motor on pump not pump.
    Dave rocks and WATSON like this.
  25. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    Being n burbank take the car to fast cars and thenenjoy it later.
    Redondo beach and a sponsor. I have talked to. Their guys lots and they have man qualified people not just one.
