Looking for 12v power source in engine compartment | FerrariChat
Discussion in 'Boxers/TR/M' started by 1TRICK6, Jun 28, 2020.
  1. 1TRICK6
    1TRICK6 Karting
    Aug 28, 2014
    159
    So. Cal (L.A./O.C.)
    Jim
    Looking for a quick tap-in to get a hot 12v power supply preferable in the right rear engine compartment area for my 89TR.
    Needed to power license plate flipper (used for car shows & events of course).
    Any suggestions.
  2. Qavion
    Qavion F1 World Champ
    11,567
    Ian Riddell
    Can't think of anything other than the starter. It may be better to wire the flipper into the number plate lights and just turn on the lights. What kind of current does your flipper draw?
  3. 1TRICK6
    1TRICK6 Karting
    Aug 28, 2014
    159
    So. Cal (L.A./O.C.)
    Jim
    Very little current draw, 8AA's batteries probably would run it, but would hate to put batteries in that hot eng compartment.
  4. Qavion
    11,567
    Ian Riddell
    If the flipper only uses power for a second or two, I guess using the number plate light power should be ok. Fuse 13 does power quite a few lights though:
    side markers (front and rear)
    tail position lights
    number plate lights
    engine bay lights (when lid raised)
    other lights which I was unable to identify.
    The 0.8mm^2 wire going to the number plate lights should be able to handle an amp or two. Do you need constant power for a wireless remote for this flipper system?
  5. 1TRICK6
    1TRICK6 Karting
    Aug 28, 2014
    159
    So. Cal (L.A./O.C.)
    Jim
    Yup, has to have constant power. Power to license plate light wiring would only be available if I have parking lights/headlights on.
  6. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Yeah back of starter has direct line to battery
    Sent from my Moto Z2 Play using Tapatalk
    1TRICK6 likes this.
  7. Qavion
    11,567
    Ian Riddell
    #7 Qavion, Jun 29, 2020
    Unfortunately, this car doesn't seem to have a battery bus bar in the engine compartment, say, like a F355.
    There is really not much use for power to devices when the car is turned off. Hazard lights, cigar lighter, park light switch, headlight pod motors (down), clock, etc...
    Here's the wiring diagram for the lights...
    Testarossa (USA) Lighting Wiring Diagram Fig5
    ... and the starter:
    Testarossa(USA)BatteryAlternator&StarterFig1
    EDIT: I just noticed hot 12 volts in the relay black box "137". There is a 10amp fuse inside the box with power on it. Is this closer to the number plate lights than the starter?
    Testarossa (USA) Injection System Fig3
    1TRICK6 likes this.
  8. Qavion
    11,567
    Ian Riddell
    1TRICK6 likes this.
  9. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,934
    romano schwabel
    don´t forget to use also a fuse
    1TRICK6 and Qavion like this.
  10. 1TRICK6
    1TRICK6 Karting
    Aug 28, 2014
    159
    So. Cal (L.A./O.C.)
    Jim
    @Qavion,
    I'll check the relay box today for juice, if none it looks like I'll have to get it from the starter.
    Nice wiring diagram.
    Qavion likes this.
  11. Clyde Romero
    Clyde Romero Formula Junior
    Sep 6, 2019
    691
    Atlanta Georgia
    Clarence Romero
    come off the starter
    its always hot
  12. Aerosurfer
    Aerosurfer Formula 3
    1,305
    Indianapolis
    Nick
    Sorry for the redundant thread post..
    Upcoming work on a 512TR. I cannot find a picture or tell if it’s accessible with the engine installed… the Terminal box, Part 170114. Part #20
    Wanting to source a new fused power source from within the engine bay. Would like to keep it out of sight and off the starter.
    is this a reasonable location, or is there another way to run a line from the battery back?
