458 - Limited engine performance message comes on | FerrariChat
458 Limited engine performance message comes on
Discussion in '458 Italia/488/F8' started by RWC58, Sep 23, 2019.
  1. RWC58
    RWC58 Karting
    Oct 14, 2018
    154
    Columbus Ohio
    Robert W Crooks
    On my last 2 rides the limited engine performance message comes on on the left hand side of the dash and the engine won't go above 3500 rpm's . The circumstances are that it occurred under hard acceleration . There are no lights on the dash and both times I shut the car of and restarted it and everything was fine. The reason I'm soliciting opinions on this is before I have it checked out is that I want to make sure it is nothing that I am inadvertently doing while driving or shifting etc. to cause this concern .
    Thoughts ??
  2. 338Lapua
    338Lapua Formula Junior
    Sep 5, 2015
    834
    Michigan
    Tony
    Battery? Low battery voltage does a lot of strange things. When I first bought my 458, I would get intermittent messages to the point that I would need to turn the car off and then back on and everything would be fine. Changed the battery and the car is happy. Might want to start there first if you haven't already. I know it sounds simple but sometimes that all it takes.
    jem890 and AlfistaPortoghese like this.
  3. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    3,500 rpms. Maybe your identifies as a Prius?
  4. RWC58
    RWC58 Karting
    Oct 14, 2018
    154
    Columbus Ohio
    Robert W Crooks
    Feels like a Prius. You can shift it no problem but the RPM's will not go above 3500 .Talk about limited engine performance !!
  5. RWC58
    RWC58 Karting
    Oct 14, 2018
    154
    Columbus Ohio
    Robert W Crooks
  6. Yellowgallardo1
    Yellowgallardo1 Karting
    Sep 19, 2018
    143
    marcus
    Could be a few things, battery, fuel, spark. I’m currently chasing a similar gremlin.
  7. Golattus
    Golattus Karting
    227
    JN
    Always battery.
  8. Yellowgallardo1
    Sep 19, 2018
    143
    marcus
  9. RWC58
    RWC58 Karting
    Oct 14, 2018
    154
    Columbus Ohio
    Robert W Crooks
    That’s one of the things the Ferrari dealer is saying! Lol
  10. Yellowgallardo1
    Sep 19, 2018
    143
    marcus
    I already replaced mine. I ordered another high pressure pump
  11. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,260
    Mel
    Try an OBDII device … and watch the codes … and\or do reset ...
  12. Yellowgallardo1
    Sep 19, 2018
    143
    marcus
    Yah, I had an independent shop pull codes. My scanner isn’t as sophisticated as theirs so I use them to help diagnose.
  13. Wazmo
    Wazmo Rookie
    Mar 31, 2019
    21
    Grayslake IL & Naples FL
    Wazmo
    Can you recommend anOBDII that works best on a 458?
  14. Ski Bum
    Ski Bum Formula 3
    Jun 19, 2012
    1,088
    I had this message all day several years ago on a 2013 Italia. It would not clear with a restart or filling the gas tank. The next morning the car stalled shortly after starting (which it never did any other time). My wife said it belched out some white smoke from the exhaust when it stalled. On restart, the limited performance message was gone and never recurred.
  15. Melvok
    Jul 25, 2008
    14,260
    Mel
    Any Chinees device from $ 15 or so ….(Car Scanner or Clear and Go or … )
  16. Zamir
    Zamir Rookie
    Oct 1, 2023
    2
    Zamir
    Hallo, my Ferrari f12 had this also, did somebody know what the problem is? And @karting you find the fault ( put new battery 1 year ago
