Is the steering wheel height adjustable? | FerrariChat
Discussion in '308/328' started by Ballie64, May 3, 2021.
  1. Ballie64
    Ballie64 Karting
    Apr 24, 2021
    112
    Simon Ball
    Hi everyone I have posted quite a bit the last week as I try to fund out things about my recently purchased 328.
    It looks like there is the option to adjust the height of the steering wheel? Would this be the case? It looks like by undoing the bolts shown in the photo it can move up and down?
  2. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    29,547
    E ' ' '/ F
    Trailer Swift
    Ballie64 likes this.
  3. Ballie64
    Ballie64 Karting
    Apr 24, 2021
    112
    Simon Ball
  4. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,319
    maurice T
    I adjusted it to the highest point but then found the gap between the steering wheel and the dash to be too close so I recently put a 1/2” (12.5mm) spacer on mine and found that is the max I would go with the indicator stalk reach..I tried with a mock up of different size spaces, (25 and 50mm)
    More than that and it would fill a bit awkward to reach.
  5. JonWH
    JonWH Karting
    Aug 13, 2020
    57
    Jonny
    Yep 25mm spacer works like a charm. I thought I'd need to adjust the entire column but the spacer fixes the driving position perfectly.
  6. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    To adjust via those bolts, you also need to loosen the collar bolt on the column (sometimes, it's HELL tight). I've done it, but was disappointed to find that 1) you can't really adjust it that much and 2) on the far end, you can't properly see the gauges.
  7. Dal308
    Dal308 Karting
    123
    Coppell, TX
    Dude
    I used the 50mm Hill spacer and changed to a Mondial shift leaver on my 308......it is taller like a 328 and angles back. That setup makes the steering wheel more reachable and at the same time lets me sit farther back and get more headroom. And still reach second and fourth gear without a problem.
