Is No Suspension Lift a Deal Breaker on a V12 Lusso? | FerrariChat
Discussion in 'FF/Lusso' started by BrntRubber, Feb 20, 2020.
  1. BrntRubber
    BrntRubber Karting
    Feb 18, 2020
    111
    Farris Alnaqeeb
    I have been hunting for a V12 Lusso and I have just been offered a spec I really like. The only option that is missing is the suspension lift.
    Given how the Lusso sits is this as big an issue as say a 458 or 488?
    Is this a big negative for resale?
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,663
    South East
    Jimmie
  3. colonels
    colonels Formula Junior
    Aug 5, 2011
    874
    it was a deal breaker for me on an F12. i am not sure if the Lusso is similar ground clearance. i researched adding the lift after and Novitec was the only one that offered a solution for roughly 10k USD.
    my F12 has the lift and there are many times where i don't activate it and it does scrape the bottom of the front spoiler, always underside where you cannot see, never the visible edges.
  4. BrntRubber
    BrntRubber Karting
    Feb 18, 2020
    111
    Farris Alnaqeeb
    Very helpful! KW make a system that’s £4k which isn’t too bad if it needs it down the line.
  5. Shabadoo
    Shabadoo Rookie
    Mar 12, 2017
    20
    I never use mine on my FF. I just had it replaced for a pretty penny too.
  6. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    I got the lift on my ff...never use it
  7. colonels
    Aug 5, 2011
    874
    what's the replacement cost? can you specify what parts failed?
    vraa likes this.
  8. Lukeylikey
    Lukeylikey F1 Rookie
    3,658
    Don’t have it on my Lusso, semi-daily the car and never need the lift. Regularly use 3RS on the same roads and that does need the lift.
    BrntRubber likes this.
  9. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,780
    Weston, MA
    Paul
    I only used mine just to see how it worked. Many times if you approach at an angle, and slowly, you either won't scrape or if you do it is minor and underneath the car.
  10. BrntRubber
    BrntRubber Karting
    Feb 18, 2020
    111
    Farris Alnaqeeb
    Thanks guys! Glad it isn’t a deal breaker.
  11. Nospinzone
    Jul 1, 2013
    7,780
    Weston, MA
    Paul
    Yea, it does depend on how much something means to you. As far as the lifter, I could have cared less. My two "must haves" were the front view camera and the panoramic roof.
  12. gilly6993
    gilly6993 F1 Rookie
    Aug 20, 2009
    2,558
    Longmeadow, MA
    Eric
    I have it on mine but rarely use it. All depends on where you live though
  13. ScottS
    ScottS F1 Rookie
    2,937
    Winter Park
    Scott S
    Considered it a must have on my cars. My FF had it and I used it all the time. My F 12 has it and I use it all the time. When I don’t I scrape or bottom out on my Uneven brick paved Street and /or underground hospital parking garage exit.
    That said-
    My Lusso does not have it and I’m fine. If you check the Ferrari catalog on their website, the lifter is an option that can be added according to Ferrari.com
  14. deltona
    deltona Formula 3
    Aug 7, 2009
    1,386
    Justin
    I've an FF, F12 and Lusso all without lifter and never needed it. No scrapes yet.....
    Natkingcolebasket69 likes this.
  15. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    I use my FF lifter a lot, Houston just has too many bad roads / parking lots
    migg48 and ScottS like this.
  16. Natkingcolebasket69
    Interesting that some have to use it. My car is lowered with novi springs and never had to use it. Maybe because I’m used to being super low as my Testarossa front valence would scrape often
  17. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,211
    Santa Barbara County
    Sam
    I only use for very steep driveways. Not very often
    Sent from my SM-G975U using Tapatalk
  18. Gh21631
    Gh21631 F1 Veteran
    9,134
    East
    Never used it on my FF and used it once on my F12. I dont have it on my Pista and it hasn't been an issue.
  19. Shabadoo
    Shabadoo Rookie
    Mar 12, 2017
    20
    The pump failed. It was ~$12k from the dealer.
  20. colonels
    Aug 5, 2011
    874
    i only use mine on entry/exit areas with a slope. roads are typically ok and potholes come up too fast to even consider using the lift.
    the f12 has so much sound insulation you probably never hear front end scrapes. with radio on i wouldn't be able to.
    ScottS likes this.
  21. uhn2000
    uhn2000 Formula 3
    Oct 15, 2011
    2,128
    Toronto
    Joe
    1FF and 4 Lussos... only my current and hopefully last Lusso has the lift and I will use it only after we drop the car .5 inchs.. also I have the carbon front lip on this car so just paranoid to scratch it. Other then that my previous cars did not have it and I never wished I needed it. Gosh even my 812 does not have a lift and its fine, so interesting that everyone thinks these cars GT type cars need lifts but they have all been fine so far and Toronto is nasty.
  22. racerdj
    racerdj F1 Veteran
    Jan 19, 2003
    6,952
    Indianapolis
    DJS
    I had it on my Diablo but rarely used it. Not a deal breaker for me and I did not order it on the 812 either.
  23. BaronM69
    BaronM69 Formula Junior
    Aug 29, 2005
    978
    Washington DC / FR
    4 lussos?!?!
  24. Jas
    Jas Formula 3
    Mar 2, 2005
    1,060
    Kent, UK
    Jas
    Deal breaker for me. I'd never buy one without a lift.
  25. BrntRubber
    BrntRubber Karting
    Feb 18, 2020
    111
    Farris Alnaqeeb
    Why have you had 4 Lussos!?
