Introducing: Novitec F12 N-LARGO Wide Body | FerrariChat
Discussion in 'F12/812' started by Exotica Motorsports, Oct 8, 2013.
  1. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
    #1 Exotica Motorsports, Oct 8, 2013
    N E W S R E L E A S E
    NOVITEC ROSSO N-LARGO
    Spectacular widebody version and 781 hp for Ferrari F12berlinetta
    NOVITEC ROSSO N-LARGO. That is the name of a spectacular widebody version for the Ferrari F12berlinetta presented by NOVITEC ROSSO, the leading global refinement specialist for the sports cars from Maranello.
    The body conversion kit is manufactured from ultra-light yet ultra-strong carbon fiber, and represents a winning combination of exciting design and aerodynamic efficiency. Also part of the conversion are tailor-made three-piece NOVITEC ROSSO NF5 NL forged wheels combining 21-inch rims in the front and 22-inch rims on the rear axle. Further features are a revised suspension with front lift function, and a power upgrade to 574 kW / 781 hp, which propels the two-seater to a top speed of about 350 km/h.
    Upon customer request NOVITEC ROSSO also customizes the cockpit to the N-LARGO’s owner’s personal preferences down to the last detail.
    205 centimeters: with this impressive width the NOVITEC ROSSO N-LARGO widebody version surpasses its original by exactly eleven centimeters on the rear axle. To this end the designers developed strikingly styled fender flares that are seamlessly joined to the production body. The larger wheel arches, for which precise-fit liners were developed, then offer space for the NF5 NL wheels, which were custom-developed for the NOVITEC ROSSO N-LARGO. The three-piece wheels are manufactured using high-tech forging technology. But that’s not all: the widebody version also made it possible to design the wheels with an extremely concave wheel spider and five delicate double spokes. The size 12Jx22 rims are shod with Pirelli P ZERO high-performance tires in size 335/25 ZR 22.
    The N-LARGO front fenders create a striking hour-glass-shape effect. They replace the production components in their entirety and add six centimeters to the width of the F12 on the front axle. To create a decidedly wedge-shaped appearance, front wheels in size 9.5Jx21 with an equally concave centerpiece were custom designed for this sports car. Tires in size 255/30 ZR 21 were selected as the perfect option.
    The development of the front and rear fender flares not only focused on fascinating looks. A lengthwise slot is integrated into the back of each front fender flare to assist in venting the air heated by the ceramic brakes from the wheel wells as quickly as possible. The rear flares feature large integrated brake cooling ducts that route the relative wind to the deceleration components.
    Strikingly styled rocker panels, available with a matte or high-gloss clear-coated carbon-fiber finish or painted in body or contrasting color, ensure a smooth airflow between the N-LARGO fenders on the front and rear axle.
    Key factors in the aerodynamic properties and the appearance are of course the fascia and spoilers of the NOVITEC ROSSO special model. The front and rear fascia, which replace the production bumpers, were not only restyled to match the fender flares.
    The shape of front fascia and the central front blade, optionally available with a clear-coated carbon-fiber finish, lend the two-seater a decidedly aggressive glance. Their styling, which was optimized in the wind tunnel, reduces negative lift and further improves handling stability.
    The new carbon-fiber front grille is the perfect complement. The hood receives some added striking highlights with the N-LARGO air scoops on the left- and right-hand side as well as with the central air deflection insert. Carbon-fiber covers for the exterior mirrors provide the finishing touches.
    In the rear the combination of five-piece diffuser on the N-LARGO fascia and the large rear airfoil create additional aerodynamic downforce at high speeds. The subtle separation edge on the roof, which like the other aerodynamic-enhancement components is available with a clear-coated carbon-fiber finish, lends the sports car a full-blooded racing look.
    The molding for the central rear fog lamp and the black tinted NOVITEC ROSSO taillights also demonstrate the great love of detail.
    To round out the striking appearance of the N-LARGO and to further enhance dynamic handling, NOVITEC ROSSO lowers the ride height of the car by up to 40 millimeters with the help of special sport springs. Steep ramps such as can be found in a parking garage or speed humps can be navigated more easily with the optional front lift system. At the push of a button the hydraulic height adjustment raises the front axle by about 40 millimeters. At a second push of the button or automatically upon reaching a speed of 80 km/h the ride height reverts to its original position.
    To match the spectacular appearance, the NOVITEC ROSSO experts upgrade the 6.3-liter 12-cylinder four-valve engine. New mapping for the engine management system was developed in extensive test series on the test rigs and on the road. On the exhaust side a NOVITEC ROSSO high-performance quad exhaust, available with or without controlled butterfly valve, ensures exhaust emissions with low back pressure.
    With 574 kW / 781 hp of power at 8,600 rpm and a peak torque increased to 722 Nm at 6,400 rpm the N-LARGO reaches a top speed of about 350 km/h.
    NOVITEC ROSSO also offers custom exclusivity for the interior. The cockpit can be designed in leather and Alcantara in any desired color.
  2. perrinnation
    perrinnation Formula Junior
    Nov 24, 2012
    697
    The Detroit area
    David
    Wow! This thing needs an exorcist! Its nearly on the verge of being 'too much' but I am sure that is the appeal.
  3. Lone Wolf
    Lone Wolf Formula 3
    Oct 24, 2006
    1,085
    Highway to Hell
    GORGEOUS. price must be silly though, and especially since my car has the 'special color' paint on it?
  4. Salivan
    Salivan Karting
    Apr 27, 2012
    84
    That looks amazing!!!
    DGPF likes this.
  5. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    41,433
    ESP
    Bas
    Like that a lot. Not a big fan of the bonnet though. But without it, and the wheels without the studs, MASSIVE YES!
  6. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
    I have a ballpark price but nothing in stone yet so I am not going to post it. The parts come in a box for you to install and paint so a special color would be up to your install shop. I have a good install guy in LA that has done a lot of the Bentley wide body kits and has built a lot of SEMA cars that could do a nice install job.
  7. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
    The bonnet parts are an add on to the factory bonnet so you could leave them off if you wanted.
  8. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
    This is a super rare kit, only 3 are slated for the USA!
  9. jvecchi
    jvecchi Formula Junior
    May 5, 2005
    370
    Sarver, PA
    John M. Vecchi
    Anyone have hi res photos?
  10. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
    I have hi res photos. I have uploaded them to Seriouswheels.com. The images will be on their homepage in the next couple days.
  11. speedsterr
    speedsterr Formula Junior
    Sep 14, 2013
    418
    I can imagine. Not much of a market for that kind of stuff here. This is more Mansory kind of stuff. I'm sure many people in the middle east and China will be ordering the rest of these.
  12. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
    I don't know what the market will be on a Ferrari wide body in the USA. The Bentley wide body market is good but I don't know here. I may have a deal on 2 of the 3 coming here but they won't be staying in the country.
  13. 95spiderman
    95spiderman F1 World Champ
    15,221
    ny
    usually dont like these conversions but this one looks like what a factory race version might be like. overall, would just keep the f12 stock and buy a 458 special to go with it. probably, not too far off in price either.
  14. ferrarivigo
    ferrarivigo Rookie
    Sep 25, 2005
    24
    New York
    Jojo Purin
    Nice pics. I'm sure this thing will look badass on the street.
  15. NürScud
    NürScud F1 Veteran
    Nov 3, 2012
    7,277
    Very beautiful! A beast. Maybe the only thing that i believe that appears a little bit 'weird' on the car is the rear spoiler..BUT it's gorgeous!!
    Bravo!
  16. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
    The rear wing is an option I believe. I should have all the parts, options and pricing on our website shortly.
  17. ferrarifan83
    ferrarifan83 Rookie
    Feb 25, 2010
    40
    Columbia SC
    Jonathan
    Love the way this looks! Bravo! Will the fenders have cutouts for the US side markers?
  18. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
    I am not sure. I can find out if you are interested in a kit.
  19. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
    All the hi res images are now loaded on seriouswheels.com
  20. NürScud
    NürScud F1 Veteran
    Nov 3, 2012
    7,277
    Sounds interesting. I'll take a look when it will be ready.
  21. jvecchi
    May 5, 2005
    370
    Sarver, PA
    John M. Vecchi
    I'd be interested to know if install a kit like this adds or subtracts value to the car. If it's what you want, and money isn't an issue, then of course go for it (I would if I was in the market). That said, resale value on anything as pricey as a Ferrari can't be ignored.
  22. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
    I would think it would add to the resale value but probably not as much as you would have invested and the buying market would probably be smaller. The Novitec supercharged cars are valued more than a stock car but not as much as the buyer had invested. I would think that would be right with this car unless it becomes well liked by buyers and it proves to be very rare. If there is only one or two US cars ever then the price may increase due to demand.
  23. F12B88
    F12B88 Karting
    Aug 16, 2013
    71
    Can you buy parts off of that car or do you have to purchase the entire kit?
  24. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
    Things like the wheels, hood pieces etc are available seperately and are already loaded on our website. The kit as a whole is sold only that way and individually wouldn't fit a stock F12 anyway. If you just wanted the front fenders for example since they are wider than stock they would line up with your bumper etc.
