Instrument housing | FerrariChat
Instrument housing
Discussion in 'Mondial' started by JLF, Oct 8, 2020.
  1. JLF
    JLF Formula 3
    1,658
  2. decardona
    decardona Formula 3
    Apr 23, 2005
    1,019
    PA
    Dennis Cardona
    Each one plugs in under the dash. The outer cover of each gauge comes off so you can unscrew/screw the gauge in. Be sure to do one at a time so you plug them in the correct plug. I did my new speedo when I had the dashboard off and that's how I remember doing it.
  3. JLF
    JLF Formula 3
    1,658
    Yea I could easily get the speedo and tach out but not the smaller gauges. I think they’re held in by a nut, tomorrow will try again and try and unscrew the nut from back of each small gauge while I have the big gauges out. If my hand will fit in there....
  4. 350HPMondial
    350HPMondial F1 Veteran
    5,195
    Edwardo
    watch the little gauge circuit boards,,
    on the bottom gauges,, It protrudes out the bottom of the trim/support plastic.
    SNAP,,, it you will. Repair or you will.
    grasshopper
  5. JLF
    JLF Formula 3
    1,658
    Ok thanks. Tried to get them out, no luck. Going to have to remove steering wheel and steering column plastic surround to get to the bottom nuts on instrument housing.
  6. 350HPMondial
    5,195
    Edwardo
    you might not need to do that.
    if you tilt the top of the panel,, with the 4 gauges foreword.
    Remove the steering wheel ,, 5 nuts.
    good luck.
  7. 350HPMondial
    5,195
    Edwardo
    I believe,, the repair is pretty
    simple. Just look for screws after you pop off the front trim panels,,, gently,,get them out.
    First remove your speedometer and tach,,, of corse.
  8. JLF
    JLF Formula 3
    1,658
