News
INSTRUMENT CLUSTER NOT WORKING
Discussion in '456/550/575' started by GWB, Dec 16, 2015.
  1. GWB
    GWB Karting
    Feb 18, 2007
    209
    Houston Texas
    Gavin Britz
    I jumped started my 575 and the instrument cluster is no longer working. Any ideas
  2. stardoc
    stardoc Formula Junior
    May 5, 2005
    645
    The big oven
    K RA
    Have you checked the fuse panel?
  3. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,720
    Amsterdam
    Jump starts in general can cause voltage peaks that can damage electronics, especially if your battery is faulty or drained extremely deeply. How was the jump start performed? Another car, a second battery, or a jump start machine? Some older jump start equipment is dangerous to modern electronics.
    What caused the battery drain? Is the battery itself faulty?
    Also a battery once it has been fully drained even once, is more often than not damaged afterwards - if it wasn't bad already you should consider replacing it. This is one of the items where money is never wrongly spent. Do not buy an expensive one, unless you go for the gel types it won't bring much benefit.
    You can try to disconnect the battery entirely for a few minutes and reconnect. I believe on a 575 this does mean you will need to do the reset procedure.
  4. Ferris Bueller
    Ferris Bueller Formula 3
    Mar 23, 2004
    1,697
    New Jersey
    Dominic
    Do you mean the gauges are not working? or do you mean the instrument panel is not lighting up?
    575's do have an issue with the panel not lighting up.
    The panel is back lit with a fiber optic light, control board and transformer.
    Rod from Francorchamps of America can repair these clusters.
  5. DrJan
    DrJan Formula Junior
    Feb 28, 2015
    553
    Grand Cayman
    Dr Jan P
    My own instrument cluster is with them.
    Discharged the battery in about 10 days.
    Cheaper than buying a new instrument cluster (I hope!)
  6. GWB
    GWB Karting
    Feb 18, 2007
    209
    Houston Texas
    Gavin Britz
    Instrument panel not lighting up. I jumped using another car. When I pull the handbrake it does light up that icon.
