How do Mondials feel at high speed? | FerrariChat
Discussion in 'Mondial' started by abarre, Jun 28, 2004.
  1. abarre
    abarre Formula Junior
    Jul 9, 2003
    295
    I had my Mondial up a little over 100 (on private property, of course) on a smooth road. The tires have 2000 miles on them and they are 18 mos old. The alignment is fresh.
    Car feels great up to about 90 and then gets "darty" after that. There is also a noticable vibration in the front. I can't imagine getting it much over 100. Much less the 150MPH supposed top speed.
    Is this normal or do I have a problem?
  2. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,955
    MO
    Omar
    Check air pressures? You would be supprised what a few PSI can do...
    If that is fine, check your bushings in the front end, I would imagine they are worn if never replaced up to this point.
  3. Jet-X
    Jet-X F1 Veteran
    Nov 2, 2003
    5,693
    Washington State
    Brian
    I think it's normal. My Mondial t (cabriolet) is the same way. Twitchy at over 100mph, regardless if I have the top up/down (top up seems to be a bit more twitchy_
  4. tifosi
    tifosi F1 Veteran
    Sep 5, 2001
    5,382
    texas
    Tom D
    I would check the suspension parts and psi - I have had mine up to 110-115 and it was solid - except for the cab top flapping a little :)
  5. AR!
    AR! Formula Junior
    Apr 8, 2004
    981
    Berlin, Germany
    Strange. Mine has a stable ride even at top speed.
    To me this sounds definitely like a problem.
  6. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,762
    US of A
    Michael
    My 1989 is rock steady well past the 150 mark.
    Heck, it cruises @ 100 like it was made for it (oh yes, it WAS made for it).
    My car is set low (4 inches ground clearance) and it is rolling on excellent tires (225/45/16 & 245/45/16 Yokohama's). I am sure that contributes to my car's performance.
    I think (like the other posters mention) that you should check tire pressures, maybe redo the alignment specs (have them add just a touch of toe in for stability), etc. on your car.
    Come to think of it... Did you see the alignment specs after the "fresh alignment?" Double check them. If the front or rear settings are zero toe, or even toe out, that may be your issue. Its not a big deal to change them.
    Mondial's (any Ferrari for that matter) should track as straight as a freight train @ speed.
  7. Philjay50
    Philjay50 Formula Junior
    Jan 16, 2003
    595
    Chester, England
    Philip
    Mine is also very stable at speed, the only comment I will make is that it runs on TRX's and these seem to have a tendency to tramline, so give that pressures etc are all OK what was the condition of the road surface ? Could this have influenced the stability of the car.
  8. RAYMAN
    RAYMAN Formula Junior
    315
    Oklahoma
    Raymond Santilli
    Wonder why NO ONE knows how to adjust toe in or other wheel adjustments on this board.
  9. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    my 88 3.2 cruised all day at 120+ very solidly on the German Autobahn. Even at redline in 5th, very stable.
    I would agree that tires play a big part.
    best
    rt
  10. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    My QV feels stable at high speed because
    a) the tyres are correctly inflated (although they do tram line so road surface plays a part)
    b) the UJ's on the steering column have been replaced as they wear pretty badly
    c) my snooper tells me about radar!!! (so I feel stable!)
    d) most other cars fade into hte distance.....behind!
  11. trevi
    trevi F1 Rookie
    May 19, 2003
    2,619
    Switzerland
    no problems up to 170mph (according to speedo), open roof. my tyres: goodyear f1 eagle gsd3 ZR, original dimensions, no mods.
  12. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    If you have a vibration it will NOT be alignment.
    Check wheel balance and tyres for run out.
    All Ferrari's run at 2/3rd max speed without any drama.....all day.
