HomeLink-garage door opener setup F12 | Page 2 | FerrariChat
Discussion in 'F12/812' started by rockitman, Oct 24, 2016.
  1. ttn27
    ttn27 Formula 3
    Sep 30, 2010
    1,134
    TX
    TN
    Instead of trying to hold your handheld remote for a few seconds then release, you have to cycle the button on your remote (i.e. push and release the button 3-4 times) while holding in the homelink button at the same time. This will allow the homelink button to memorize the handheld remote much easier (I found this out by going to the homelink company website since the instruction booklet did not tell you to do this).
  2. Labman
    Labman F1 Rookie
    3,804
    Long Island, NY
    Steve
    Nope. Not working. I guess my new liftmaster with rolling codes not compatible. The clicker will remain.
  3. carz80am
    carz80am Formula Junior
    Sep 23, 2015
    702
    Even though Homelink may in theory be the same in all makes, all my other car brands (toyota, honda, ford, porsche, bmw) were much easier, the ferrari's seem to never work or be a complete pita
  4. ttforcefed
    ttforcefed F1 World Champ
    19,294
    steve look back to post 17 in this thread
    xoxo
  5. Labman
    Labman F1 Rookie
    3,804
    Long Island, NY
    Steve
    Lol! Yep. On the sun visor it stays.
    430jm likes this.
  6. DaveMc
    DaveMc Formula Junior
    Nov 29, 2012
    426
    Palm Coast, Florida
    Guys, some of you will need a "compatibility bridge" to make the homelink work. I just built a new home with new garage door openers and I had to install this bridge to get everything to work with my 4-5 year old cars. The bridge is very easy to install. Everything works perfectly now, just like it used to with my old house.
    https://www.amazon.com/Liftmaster-855lm-Chamberlain-Homelink-Compatibility/dp/B00IPQY3GS/ref=sr_1_1?ie=UTF8&qid=1501617942&sr=8-1&keywords=homelink+compatibility+bridge
    And some of you will also need to push the "learn" button on your opener TWICE in order to get it in the "learn mode". This is also a common error that people make when programming the homelink
  7. Ski Bum
    Ski Bum Formula 3
    Jun 19, 2012
    1,088
    +1
    I needed the compatibility bridge to get Homelink in a 2014 458 Spider to work with a new Liftmaster system. Once I got the bridge, it worked fine. The installer of the new Liftmaster system (the prior system died) was aware of the issue.
  8. Labman
    Labman F1 Rookie
    3,804
    Long Island, NY
    Steve
    Thanks guys! Ordering it now. Hal I will discuss with you when I see you next.
  9. Labman
    Labman F1 Rookie
    3,804
    Long Island, NY
    Steve
    Guys...I ordered it from Amazon Prime and I got it in two days. Installed and works perfectly. Goodbye clicker!! Thanks!
    VColin likes this.
  10. F5506M
    F5506M Formula Junior
    Nov 3, 2003
    935
    New Jersey
    Ray
    The problem is not the HomeLink in the car, but the garage door, which needs to learn the new receiver in the car. Just did it on the FF and worked perfectly.
  11. papou
    papou Formula 3
    1,755
    plantation Fla
    daniel ross
    YouTube guys it’s simple..
  12. gilly6993
    gilly6993 F1 Rookie
    Aug 20, 2009
    2,577
    Longmeadow, MA
    Eric
    Yes home link is super simple in every single vehicle I’ve ever owned.....EXCEPT Ferrari.....
  13. TheMayor
    107,798
    Vegas baby
    I completely agree! I never could get mine to work right but in every other car it works great.
  14. Thecadster
    Thecadster F1 Veteran
    7,731
    Link? I have not had success with my F12. Meanwhile, my Performante worked immediately. Naturally, YMWV.
  15. Labman
    Labman F1 Rookie
    3,804
    Long Island, NY
    Steve
    All you guys need is this. My 458 Homelink finally can be used!
  16. Labman
    Labman F1 Rookie
    3,804
    Long Island, NY
    Steve
  17. ERIC ANDERSON
    ERIC ANDERSON Rookie
    May 3, 2020
    44
    Cleveland, OH
    Eric Anderson
    I was also frustrated with this with my '15 F12. In a nutshell the Ferrari Homelink system is dated, and requires a $25 "bridge" to make the car opener compatible with most US garage door openers. With the Homelink Bridge it was < 5 minutes to get the car opener working. Here are the steps as slightly modified from an early post on this:
    1.Press and hold the two outside buttons on the Homelink® system until the LED starts to blink, release buttons.
    2. Press and hold the desired Homelink® button in the car and the transmit button on the transmitter provided with the bridge kit at the same time until the Homelink® LED changes from a slow blink to a rapid blink. (Your Homelink® system is now programmed)
    3.Locate the learn code button on your garage door opener. It is typically YELLOW. (These are located under the light cover or on the rear panel depending on model)
    4.Press the learn code button on the garage door opener, a red LED will start to blink. (You will have 30 seconds to complete programming)
    5.While the LED on the garage door opener is blinking, return to the vehicle and press and hold the pre-programmed Homelink® button. Once it flashes you can release it. The button worked first time when I did this.
    If you have problems with the Homelink® system please call 1-800-355-3515 or their website at HomeLink
    VColin likes this.
  18. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,211
    Santa Barbara County
    Sam
    My car is a 2012 and I didn't need a bridge. Ny garage door opener is at least 10 yrs old
    Sent from my SM-G975U using Tapatalk
  19. Terrence
    Terrence Formula Junior
    Feb 15, 2004
    361
    Hawaii/LA
    Terrence
    Works for me, and I have rolling code.
  20. RichPunk505
    RichPunk505 Rookie
    Nov 17, 2021
    3
    Lee
    guys - this totally works - just spent 4 hours with garage door people - they said cars prior to 2016 need a repeater (for lift master). I have a 2016 FF so it didn’t occur to do this. Then we hooked up the repeater and everything worked. Apparently the Homelink chips in a 2016 Ferrari are from the older models. Hope this helps - it’s awesome to have it work!!!!
  21. ttforcefed
    19,294
    what if your garage door opener is 15 ft high?
    Way2fast likes this.
  22. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,211
    Sam
    I have a very tall ladder. My garage is 14 ft high
    Sent from my SM-G998U using Tapatalk
    Caeruleus11 likes this.
  23. Vegas CS
    Vegas CS Formula 3
    1,237
    Vegas
    James
    This is good info. Gate to my community is old so the old programming worked (holding it close to the mirror and copying the code). My new Chamberlains garage door openers will not program though. I’ll just use a visor mounted clicker for them I guess. Glad to read this thread so I don’t waste anymore time on the subject.
  24. Solid State
    Solid State F1 World Champ
    10,800
    Maximus Decimus Meridius
    The remotes now are so small you just put them on a keychain and there's two or three it can control. Safer than programming a car with secure entry.
  25. priericky128
    priericky128 Formula Junior
    761
    St. Louis MO
    Rick
    Thanks for this thread, I used it today to program my ff. Super simple once you have the right steps. Programmed both doors in my garage.
    I did have the car running when I did it.
    rob5819 likes this.
