Help with Error Codes and 355 that died and would not start | Page 2 | FerrariChat
Discussion in '348/355' started by Vince355, Oct 19, 2020.
  1. Qavion
    Qavion F1 World Champ
    11,567
    Ian Riddell
    Yeah... just realised.
    So the "seizure" process wasn't instant. Temperature related? Coolant/lubrication problem.... or should you be able to restart the car when cooled in some cases?
    These kinds of problems sound expensive :confused:
  2. Qavion
    11,567
    Ian Riddell
  3. WATSON
    21,727
    WI
    My buddy's was tested as A+ as well. Optima's are a mess.
    If it were me, I would try a different battery
    Last time I'll pop in here....
    Qavion likes this.
  4. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,669
    CT
    John Kreskovsky
    Yes. I read where you said that the solenoid click and the starter hums but no crank. By first though was bad starter/battery. But that doesn't jive with the way the engine died in post #1. Not to panic, just a quick check to get that out of the way.
    [edit] It could still be the battery but you did say it was tested good.
  5. Qavion
    11,567
    Ian Riddell
    If a bad battery is dragging down the voltage of the entire electrical system, the ECUs might go undervoltage and cause those kinds of symptoms. ECUs don't like overvoltage, either. Could it be a bad battery/alternator combo?
    WATSON likes this.
  6. johnk...
    Jun 11, 2004
    10,669
    CT
    John Kreskovsky
    Before I'd be worrying about ECU I want to figure out why it won't crank. The way it died suggest either electrical or mechanical issues. Just figure start with the mechanical. Eliminate one thing at a time.
  7. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,179
    NYC, USA
    Phil
    Start with replacing the Optima battery with a standard type, Interstate of other brand.
    WATSON likes this.
  8. Vince355
    Vince355 Rookie
    Jul 31, 2020
    23
    Vincent Joseph Tevere
    I can’t tell up when I rock it if the engine is moving - need to pull a plug. I would love to push it up the driveway and try and push start it. I am going to try replacing the battery. Then it may be time for a trip to the shop.
    Qavion likes this.
  9. Vince355
    Vince355 Rookie
    Jul 31, 2020
    23
    So I took a video trying to start it but file is too large to upload
  10. johnk...
    Jun 11, 2004
    10,669
    CT
    John Kreskovsky
    Battery might work. If it doesn't, next step. I suggested first rocking before you spent money.
  11. Vince355
    Vince355 Rookie
    Jul 31, 2020
    23
    Thanks John not many 34 R battery options out there any more
  12. johnk...
    Jun 11, 2004
    10,669
    CT
    John Kreskovsky
  13. GTO Joe
    GTO Joe Formula Junior
    989
    Charlotte, NC
    Joseph Troutwine
    John is correct, NAPA is good choice. MFG by East Penn here is the USA.
  14. Vince355
    Vince355 Rookie
    Jul 31, 2020
    23
    Thanks Guys
  15. Vince355
    Vince355 Rookie
    Jul 31, 2020
    23
    AGM or Wet?
  16. Qavion
    11,567
    Ian Riddell
    AGM is safer, lighter and less hassle. They have a faster charge rate and they last longer in situations where the car is not used daily. Google "deep cycle". But they must be kept topped up. Don't let them discharge more than 30%. This will reduce their lifespan. Some have special charging requirements. Do you have a smart charger?
  17. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,179
    NYC, USA
    Phil
    Wet - what came with these cars when new.
  18. johnk...
    Jun 11, 2004
    10,669
    CT
    John Kreskovsky
    So I googled it.:)
  19. Vince355
    Vince355 Rookie
    Jul 31, 2020
    23
    I have a smart charger
    Qavion likes this.
  20. Qavion
    11,567
    Ian Riddell
    By cranking battery, I think they mean one which will be used repetitively to turn an engine (say, on the same day) and in doing so drops the charge below 70%. With my battery on a trickle charger, my car starts first time, every time.
    Another drawback of the AGM is that some older alternator/regulators don't always put out enough recharging volts for an AGM battery when driving. If you repetitively do this without putting your car back on a trickle charge, then you might lower the battery voltage over time. If you treat the AGM battery well, it should last much longer than a "wet" battery.
  21. johnk...
    Jun 11, 2004
    10,669
    CT
    John Kreskovsky
    #46 johnk..., Oct 23, 2020
    Actually the quote was from article discussing automotive (cranking) batteries to AGM deep cycle batteries. A more complete quote:
    I know that in some modern Ferraris dealers are recommending deep cycle batteries as replacement because of the high current draw of all the electronics when the car is off because batter failure seem to occur frequently. But not the best choice if the above quote is correct. Sound more like a fix to a problem in engineering of the car's electical system in the first place.
    Qavion likes this.
  22. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,969
    Indio Ca/ Alberta
    Grant
    When I had problems with my car last year it would still turn over below 12 volts on a gauge in the cigarette lighter.
    Just check voltage at the back if it’s in the high 12s I would suggest listening to John and try too turn engine over.
    Confirm it’s in neutral by rolling it, but I think if you put it in gear and rocked it you all ready know it was in neutral when attempting to start.
    So back too John and confirm engine can rotate.
  23. Vince355
    Vince355 Rookie
    Jul 31, 2020
    23
    I checked ground strap it is intact and I cleaned the contacts as well. Don’t think that is it. I checked Battery voltage and it is 12.17 but drops to 8.97 when I go to crank it. Seems like an electrical problem to me.
  24. johnk...
    Jun 11, 2004
    10,669
    CT
    John Kreskovsky
    Battery voltage should drop when you crank the motor. How much is the question. Being pulled down to 9 V indicates a couple of possibilities. 1) The battery is shot and can not deliver enough current to turn the engine, or 2) the battery is good and delivering the current needed but the starter can not turn for some reason such as, starter shot, jammed, or being prevented from turning for some other reason. In either case, that the voltage drops when you try to start it would indicate to me that the solenoid is closing and you are dumping current through the starter motor winding.
    WATSON likes this.
  25. WATSON
    21,727
    WI
    Is this with the same battery? ....or did you put a new one in there yet?
