Help Identify | FerrariChat
Help Identify
Discussion in '308/328' started by chasjen, May 11, 2021.
  1. chasjen
    chasjen Karting
    70
    Dublin, Ohio
    Charlie
    I was digging in the trunk of my 85QV and under the carpet I found this wood piece. It is not solid but is two thin pieces of wood glued together by blocks centrally like a sandwich. Very curious. It seems nicely finished. I was thinking maybe heat control as it has an air gap. Any ideas?? Image Unavailable, Please Login
    waymar likes this.
  2. Dr Tommy Cosgrove
    35,350
    Birmingham, AL
    Tommy
    Believe it or not, that was put there by the factory.
  3. chasjen
    chasjen Karting
    70
    Dublin, Ohio
    Charlie
    Thanks. That's pretty cool.
  4. 4right
    4right F1 Rookie
    What?
  5. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,086
    SanFrancisco BayArea
    1983 US 308 GTS QV
    My car is a 1983 and I have a deluxe mahogany veneer version of the wooden trunk bottom. It has the same air gap and all. It looks like by 1985 Ferrari downgraded to some cheaper wood veneer in their trunk bottom spacer. Titch, titch.
  6. Dr Tommy Cosgrove
    35,350
    Birmingham, AL
    Tommy
    If you were to disassemble the interior totally, you may well find more blocks of wood used as shims here and there.
    Not a joke.
  7. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I found a block of wood under the little piece that covers the seam on the rear shelf. I'm not sure if it was factory or not.
  8. Dr Tommy Cosgrove
    35,350
    Birmingham, AL
    Tommy
    It was
    Charming hand built "quality"
    Kidasters likes this.
  9. 4right
    4right F1 Rookie
    Years ago, I found a wood shim under the instrument cluster on the dash.
    Weren't the floors on F1 cars also made out of wood? So F1 technology is found in our cars!
    Dr Tommy Cosgrove likes this.
  10. Dr Tommy Cosgrove
    35,350
    Birmingham, AL
    Tommy
    I believe they used wood on the outside bottom just recently before going back to that metal one for the spark show.
    Had something to do with clearance rules and only so much could be scrapped off after a race or qualifying. Couple mm only, if that.
    This was just a few years back. Not long.
  11. ragtop1
    ragtop1 F1 Veteran
    5,002
    Ontario
    Larry Warren
    I threw mine out. ugly 5 lb piece of scrap wood
  12. JuLiTrO
    JuLiTrO Formula Junior
    Nov 2, 2017
    383
    Julio Saiz
    Thats correct
  13. built2grind
    built2grind Formula Junior
    410
    The Peninsula
    ANDREW
    I was wondering that, Thankyou for the insight. I discovered mine a few years ago and wasn’t sure who or why it was there. I’m still confused why it was there
  14. Steve Magnusson
    25,149
    #14 Steve Magnusson, May 13, 2021
    Extra thermal insulation on the US version cars to protect the rear trunk area from the (greater) heat from the cats below (I don't think it's used on the euro version cars). It is fairly lightweight, inexpensive, and has a high thermal resistance -- but still don't put ice cream in the rear trunk ;).
    dinoart likes this.
  15. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I recently serviced my AC system and I had to return all of the tools I borrowed from to complete the job including an extra brand new can of R134 I was going to donate to the next user. I packed it all in the trunk for the drive to our 308 breakfast. I remembered that the can said not to store over 120F. I put that can up front with me.
    OTOH when an evening drive gets a little chilly and you pull a jacket out of the trunk, it's nice and toasty warm!
  16. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,109
    Mansfield, TX
    Ron
    Yes. Not in Euro cars.
  17. ChevyDave
    ChevyDave Karting
    Dec 21, 2019
    78
    Pacific Northwest, USA
    Dave W
    With a similar problem to solve, FIAT used a thick felt-type media bonded beneath a heavy rubber mat in the rear trunk of X1/9s.
    Just a little down-market from its cousin’s mahogany piece. ;)
  18. Banzairacer
    Banzairacer Formula Junior
    482
    San Diego, CA
    Sanjeev Thohan
    You can coat the underside of this wood piece with sound/temperature dampening and it helps with any rattles or heat dissipation - still no ice cream in the back. Costco thermal coolers do work if you want to carry things.
