help.. half my 348 motor shuts down | FerrariChat
Discussion in '348/355' started by tommygunct, Feb 25, 2020.
  1. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    Car starts up and runs fine for about 5 minutes then sputters a little and the whole side Bank goes out I have switched MAF sensors from one side to the other same thing I have changed fuel filters spark plugs check Spark installed two new O2 sensors and took apart and clean my throttle bodies but it still keeps happening just on one half of the motor on the half that goes out if I take the MAF plug off the motor stays the same if I go to the other side and take the MAF plug off it dies right out anybody have any suggestions any help would be appreciated
  2. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,629
    Elliott Caras
    Crank sensor?
    ernie and Pangea like this.
  3. Wingnut
    Wingnut Karting
    Feb 11, 2005
    155
    Corolla, NC
    See my post on the Mondial forum "Left bank running rich". The Mondial T has the same engine as the 348 I am told.
  4. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  5. Pangea
    Pangea Formula Junior
    Mar 27, 2011
    442
    Nick
    Can you identify which bank? Any slow down lights or CELs on the dash? Can you pull any codes? ( maybe no bulbs fitted) If not my first thing would be to disconnect the cat ecus and thermocouples just to take them out of the equation before digging deeper. Few seconds work. Many years ago I had a very similar situation at start up from cold. About 5 mins or so in it dropped a bank. It was a cat ecu. Didn't even get up to full temp. I run decat pipes so I left it disconnected.
    ernie likes this.
  6. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    the cat and thermos are already disconected have been for a long time
    no lights on the dash i have an 89 so no code lights to pull codes from it has the old motec with 1 throttle position switch
    Pangea likes this.
  7. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    Do you think it might be a crank sensor have you ever changed one in your car are they a pain in the ass what is usually the problems that go on when a crank sensor goes bad
    Pangea likes this.
  8. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    I had a bit of trouble following your dilemma as described (run-on sentence without punctuation). So I broke it down... did I get it right?
    Car starts up and runs fine for about 5 minutes then sputters a little and the whole side (i.e. one Bank) goes out.
    I have switched MAF sensors from one side to the other and the same thing happens.
    I have changed fuel filters, spark plugs, checked the spark, installed two new O2 sensors and took apart and cleaned the throttle bodies, but it still keeps happening (just on one half of the motor)
    On the half that goes out, if I take the MAF plug off, the motor stays the same.
    If I go to the other side and take the MAF plug off, it dies right out.
    Anybody have any suggestions? Any help would be appreciated.​
  9. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,629
    Elliott Caras
    My car was recently dropping a bank when driven hard. It was the 5-8 side and was the crank sensor for that bank. It was not that bad to change and the 5-8 side is the difficult one.
    Pangea likes this.
  10. tommygunct
    tommygunct Karting
    Dec 26, 2012
    175
    Stuart florida
    that's the one I think is bad on mine why was it so hard to change is it that stupid plug that's all the way underneath the car near the alternator
  11. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,629
    Elliott Caras
    I went from underneath with a small Allen key once the bolt is broken loose it’s easy to change. I didn’t have a lot of leverage to loosen it but it is doable.
  12. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,042
    Atlanta, GA
    Steve D.
    bad ground? dirty connector somewhere?
    sjd
    ernie likes this.
  13. Iltorored
    Iltorored Rookie
    May 17, 2013
    6
    Houston
    John Murphy
    I had the same issue awhile back and what worked for me was unplugging the tps on the bank that drops and sprayed contact cleaner on both the plug and the socket. Disconnect the battery first.
  14. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    You can get the crank sensor very easily andnin a fraxtionmof the time from the passenger wheel well if you remove the liner with a 1/4" 2 foot extension and a swivel.
    Sent using FerrariChat.com mobile app
  15. A348W
    A348W Formula 3
    Jun 28, 2017
    1,846
    North Wiltshire, UK
    If your Cat ECUs are disconnected and from what you have said:
    - its not your MAFs;
    - its not plugs/leads/o2 sensors.....
    next just replace the crank sensors (cheap from Kia; see master sticky).
    If that doesn't cure it you need to start swapping parts etc;
    - clean all electrical connections with cleaner
    - swap relays for ECUs;
    - swap relays for fuel pumps;
    - put a volt meter on your fuel pumps to see if one of those is being temperamental;
    - swap your ECUs over ;
    - check earths.
    If none of that finds an issue, then replace the following (not overly expensive)
    - power modules and coils;
    If none of that works, come back for more help; and hopefully somebody with some deep understanding will step in!!!
    Good luck. I've had similar issues and feel your pain/hassle. For me 1 incident was Cat ECUs, and another was crank case sensors.
    Wade and Qavion like this.
  16. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,214
    CT
    John Kreskovsky
    Check fuel pressure and check to see if injectors are firing.
  17. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    Another place to check are the 6mm screws near the driver cam cover, I can't remember if they were on the top or the bottom but the grounds
    for the motronic 2.5 are tied there. And of course, do you have any way to verify fuel pressure on the dead side?
    Jeff Pintler
    89 348tb, 86tr, 99 360 3pedal, 05 S-160 Bobcat
  18. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I'd switch maf, coil and ignition module from one back to other and see if problem changes banks. No cost and takes 20 min.
