Help fixing lighting and wiper stalk switches 84 QV | FerrariChat
Discussion in 'Mondial' started by rjp80s, Apr 13, 2020.
  1. rjp80s
    rjp80s Rookie
    Jan 24, 2017
    40
    Houston
    Rick Pleczko
    The lighting stalk switch on My 84 QV has gone 'floppy. Everything works as normal (raise lights, main beam etc except the part of the switch that turns on the foglights. It's very floppy, no real resistance or 'click'. It has assumed the position of the foglights always being on. To solve the problem I jam something between the steering wheel and the switch to ensure the fog lights stay off when I'm not driving.
    Also, the washer switch has never worked (the wipers do though).
    I've attached pictures the steering column after I've removed the retaining nut fans the steering wheel. Where do I go from here to further diagnose and fix the problem? I don't want to undo things I don't have to.
    Help greatly appreciated.
    Cheers, rick
  2. rjp80s
    rjp80s Rookie
    Jan 24, 2017
    40
    Houston
    Rick Pleczko
    On a related note, I just put direct power to the leader on the windshield washer pump and nothing happened. Any ideas how to fix this, or where to get a replacement pump would be greatly appreciated.
  3. 350HPMondial
    350HPMondial F1 Veteran
    5,323
    Edwardo
    Mr. FIAT has pumps.
    hey FERRARI friend,,,,
    be VERY careful when reinstalling your steering wheel.
    BE sure that the two “engagement
    ‘ black plastic tabs line up with the wheel..
    good luck. EDUARDO
  4. rjp80s
    rjp80s Rookie
    Jan 24, 2017
    40
    Houston
    Rick Pleczko
    Thanks for the advice Eduardo. Regarding Mr. Fiat... do you mean that the pump is a standard Fiat part?
  5. 350HPMondial
    5,323
    Edwardo
    Mr Fiat has expanded his store to include some Ferrari parts.
    also, that pump might be an 80’s bmw part,,, like our mirror switch.
    good luck,
    Eduardo
    81 euro Mondial 8
  6. rjp80s
    rjp80s Rookie
    Jan 24, 2017
    40
    Houston
    Rick Pleczko
    Great, thanks very much Eduardo
  7. ronfrohock
    ronfrohock F1 Rookie
    4,154
    MA
    Ron Frohock
    Wade likes this.
  8. rjp80s
    rjp80s Rookie
    Jan 24, 2017
    40
    Houston
    Rick Pleczko
  9. rjp80s
    rjp80s Rookie
    Jan 24, 2017
    40
    Houston
    Rick Pleczko
    Ron, I talked to Verell and he can fix them. Thanks ever so much for the lead.
    Wade and ronfrohock like this.
  10. afterburner
    afterburner F1 Rookie
    3,468
    Switzerland
    Urs STEMMLER
    Did you check its ground?
  11. ronfrohock
    4,154
    MA
    Ron Frohock
    I’ve seen this problem before. It’s very likely a soldering / contact issue. Verell has fixed a good amount of them.
  12. rjp80s
    rjp80s Rookie
    Jan 24, 2017
    40
    Houston
    Rick Pleczko
    Yes, that was the problem, We managed to get it working. Thanks for the suggestion.
    afterburner likes this.
