Heater Valve | FerrariChat
Heater Valve
Discussion in 'Mondial' started by race, May 29, 2019.
  1. race
    race Karting
    87
    Carrollton Texas
    Jeffery Mead
    I am trying to locate the Heater valve on my 85 QV it seems to be stuck on and during Texas summers make driving VERY unpleasant
    Jeff
  2. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
    #2 AndruL, May 29, 2019
    Passenger footwell, up toward the right fender. You can remove the stainless steel door step, along with the under door panel cover, then follow the hoses up.
  3. race
    race Karting
    87
    Carrollton Texas
    Jeffery Mead
    Thank you sir. for that information.
    Jeff
  4. Steve Magnusson
    26,732
    It might be more accurate to say that it is "stuck off". The 61079000 hot water valve needs to be powered to stay closed so, if you've lost +12V power to the system, it will default to the open condition. Unplug it and measure the voltage between the two terminals in the unplugged harness connector when not requesting heat with the key "on" (or engine running) = it should be +12V.
    If it is +12V, but you still get heat without requesting heat, either the valve is bad or another possibility is that the coolant hoses going to it have been swapped. There is a flow direction arrow on it to show which way the coolant should be flowing, and it will only seal if the coolant flow is in the correct direction.
    Good hunting!
    jkstevens2, ronfrohock and Wade like this.
  5. ronfrohock
    ronfrohock F1 Rookie
    4,153
    MA
    Ron Frohock
    Steve,
    You amaze me with your expertise. We are lucky you are here!
