Getting no spark and no fuel to my 512TR. Trying to figure out. | FerrariChat
Discussion in 'Boxers/TR/M' started by silvergts1998, Aug 13, 2019.
  1. silvergts1998
    silvergts1998 Formula 3
    Apr 10, 2005
    2,419
    ky
    Adam
    Hi everyone,
    Hoping to maybe narrow down some issues.
    Today I was going to take my 512TR to vacation with me and it won't start. It cranks over, starter works, all fuses are good.
    I took out the spark plug and grounded it with it plugged on the spark plug. No spark. I didn't see any fuel on the spark plug either. When cranking the car over, I don't smell any raw fuel. I would think I would when cranking the car over and no spark.
    I know the fuel pumps work. I put power directly to them and I could hear the fuel pumps kick on. Full tank of gas.
    Checked the connectors on the coil pack. Looked at connectors and reconnected.
    So I think basically I am not getting fuel and spark at this point. I swapped around relays and that didn't do anything either.
    Any leads?
  2. silvergts1998
    Apr 10, 2005
    2,419
    ky
    Adam
    Found out if the 512TR doesn't get spark there's no fuel deliver either. I wonder if it's a crank sensor. Not sure if the phase sensor has anything to do with not getting spark?
  3. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,907
    Troy, Michigan
    James
    I wish I could help but I am unfamiliar with the 512tr. I'm sure its some sensor or ground that cam loose.
  4. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    Wouldn’t everything be controlled at this point through the ECU?
    Then this makes me wonder why it wouldn’t run on one bank.
    Do you think there is a common ground for both ECUs?
  5. silvergts1998
    Apr 10, 2005
    2,419
    ky
    Adam
    Just a follow up, I found the problem, I had a screw come loose in my phase sensor box.
  6. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,934
    romano schwabel
    what you understand under this phase sensor box?
  7. silvergts1998
    Apr 10, 2005
    2,419
    ky
    Adam
    Not sure what you are asking?
  8. turbo-joe
    Apr 6, 2008
    8,934
    romano schwabel
    when you not even sure how could I know then???
    you have written:
    and I asked you what you understand under this phase sensor box?
    so what problem you have not understanding my question?
  9. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,907
    Troy, Michigan
    James
    the english doesn't make sense. maybe there's a translation error?
  10. silvergts1998
    Apr 10, 2005
    2,419
    ky
    Adam
    I think you're right.
