Gear oil 75w90 vs 75w140 | FerrariChat
Discussion in 'Boxers/TR/M' started by tamburini44, Oct 31, 2019.
  1. tamburini44
    tamburini44 Karting
    Jun 6, 2019
    111
    The shop that did the last major on my TR used 75w140 in the gearbox.
    Shifts were fine both cold and warm, but I'm wondering about the long term.
    Anyone have experience with this weight oil in their TR?
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,510
    romano schwabel
    in my competiton I only use 75W140 LSD castrol, in my BB only 75W90 LSD
    the oil in my competiton is getting much warmer than in the BB when I go curvy roads because the diff has to work more with so much power. but for "normal power and driving" I would use this 75W90 also in a TR
  3. tamburini44
    tamburini44 Karting
    Jun 6, 2019
    111
    Alright, I was wondering how the thicker spec when warm would work vis a vis the TR's known issue with the diff.
  4. ago car nut
    ago car nut F1 Veteran
    5,495
    Madison Ohio
    David A.
    The oil viscosity should contribute to the suspect welds on the diff.
  5. MOSS
    MOSS Formula 3
    Apr 28, 2004
    1,629
    This is a case where you use what the factory says for sure. Redline 75-90ns is the bomb.
    Shamile and blkdiablo33 like this.
  6. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Hmmmm.... interesting choice of words.
  7. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    Seriously the Redline NS is the one to put in.
    MOSS and Shamile like this.
  8. MOSS
    MOSS Formula 3
    Apr 28, 2004
    1,629
    Doubtful
    turbo-joe likes this.
  9. ago car nut
    5,495
    Madison Ohio
    David A.
    I misspelled should! Meant to read SHOULDN'T.
    MOSS and turbo-joe like this.
  10. ttforcefed
    ttforcefed F1 World Champ
    19,247
    isnt this the same discussion as the tranny oil debate?!?!
  11. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
    I've used the 75w140 in the gearbox without any problems.
