Garage lighting ideas | FerrariChat
Discussion in 'Detailing & Showroom' started by azzurribaggio, Nov 28, 2019.
  1. azzurribaggio
    azzurribaggio Formula Junior
    Hello, I'm about to embark on finally putting in some serious lighting in my garage to replace the one 100 watt light bulb in there LoL... Wanted to get some advice with those that have created some nice lighting within their garage.
    Sent from my Nexus 6P using Tapatalk
  2. JohnnyRay
    JohnnyRay F1 Rookie
    3,579
    Central FL/NW WI
    4000K color temp LED strip lights. 5000-7000 lumens. 4000K is a nice bright white light with good color rendering. Traditional warm white 2700-3000K is not the best for shop lighting and 5000K or greater is too harsh.
    Solid State and Bryanp like this.
  3. Ak Jim
    Ak Jim F1 Veteran
    9,570
    North Pole AK
    What kind of electrical fixtures or outlets do you have? If just the one then you could try one of the "corn cob" bulbs. Just replace the existing 100 watt (1600) lumen with something like this.
    https://www.ledlightexpert.com/150-Watt-E39-LED-Bulb--21892-Lumens-5000K_p_63.html?gclid=EAIaIQobChMIxqmhgsaQ5gIVqyCtBh3IAwrzEAQYBCABEgLKAvD_BwE
    Well that one has 22,000 lumens so it might be a little over the top but you get the idea. They make many different lumen and color choices. Just keep in mind you currently have 1600 lumens so size accordingly.
  4. clonmeliw
    clonmeliw Karting
    Aug 27, 2016
    192
    Tulsa, OK
    Jeff Fischer
    I'm a big fan of Hyperikon (https://www.hyperikon.com). You can get numerous choices in commercial grade LED tubes that will retrofit into standard fluorescent fixtures in a large selection of color temp and brightness (you might have to disable the ballast though). Quality is excellent, shipment is quick, prices are reasonable, and they will actually entertain counteroffers! If a tube is not your thing, they have numerous other options including LED fixtures. Worth checking out.
  5. Ak Jim
    Ak Jim F1 Veteran
    9,570
    North Pole AK
    I like this brand also. Installed 20 of these in can lights in part of the garage. Difficult to do if existing construction.
  6. Mang
    Mang F1 Veteran
    Jul 11, 2007
    5,975
    ta HO
    Mike S.
    Costco recently had some motion detector led ‘shop lights’ that are just ez, simple, and plug into any outlet if anyone looking for cheap functional garage units.
  7. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,040
    Atlanta, GA
    Steve D.
  8. JohnnyRay
    JohnnyRay F1 Rookie
    3,579
    Central FL/NW WI
    I've been in the electronics industry for many years - helping customers work through the conversion of commercial, automotive and residential lighting to LED technology. Any light source "whiter" than 4000K color temperature is too harsh for home shop/display in my opinion. Here are a few references:
    Warm Light (2000K-3000K): Typically for ambient lighting in relaxation/leisure areas like Living Rooms, Hotel Lounges, Restaurants.
    Neutral Light (3500-4500K): Typical for general purpose such as Offices, Lobbies, Classrooms, and Retail
    Daylight White (5000-6000K): Typical for high task high visibility needs such as Workshops, Laboratories, Kitchens, and Manufacturing
    Cool White (5500-6500K): Typical for outdoor lighting such as street lights, parking lots, warehouses
    Typical Color Temps
    1000K: Low Pressure Sodium
    1500K: Candlelight
    2200K: High Pressure Sodium
    2700K: 60W Incandescent
    3000K: 200W Incandescent
    3200K: Sunset/Sunrise
    3400K: Tungsten Halogen
    4000K: Standard Metal Halide
    4200K: Typical Office Fluorescent
    5000K: Daylight White
    5500K: Noontime Sunshine
    5500K: Daylight Metal Halide
    7500K: Overcast Sky Mid-Day
    10000K: Aquarium Lighting
  9. Baitschev
    Baitschev Formula Junior
    Jan 8, 2017
    262
    Vienna
  10. Lagunae92
    Lagunae92 F1 Rookie
    2,775
    SoCal
    Have adjustable cans (boxed in with drywall) that range from 2700-5000k. They are set at 5000K and accompanied by 6 5000K 2'x2' LED panels. Works out pretty nice and looks interesting.
    Chad Thomas likes this.
  11. RedNeck
    RedNeck F1 World Champ
    12,197
    The CSA
    Me
    I just went with the old tried-and-true track lighting. Cheap, and looks much better than the fluorescent fixtures I had in there before. Matched with 100-watt equivalent daylight bulbs and my Chamberlain garage door opener, it's pretty darn bright in there. Expandable also, I may get 90 degree couplers and expand them even more if I want to blind folks.
  12. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,850
    Memphis, TN
    Lagunae92 likes this.
  13. moysiuan
    moysiuan F1 Rookie
    4,177
    Canada
    Keep in mind that too much light is very hard on the eyes, and you don't want fixtures where in your peripheral vision you have too much glare. While Led's are all the rage, and of course very energy efficient, they can be very hard on the eyes and some can give a flicker effect (both visible and invisible flicker) depending on tghe drivers that control the lighting. And for sure, stay with the warm spectrum, the blue light spectrun from high K temp LED's is now shown to cause retinal damage. The flat panel types of fixtures don't let much light out horizontally, they tend to down light. Old style flourescents have a much more diffuse light, and in surface mount fixtures often had side depth that allowed for some side diffusion as well, tending to flood the room, which is generally easy on the eys and what you want.
    Sorry I sound old school, but the Led industry is still in an exciting experimental phase, with all kinds of technology advances, but is really winning over people for architectual design reasons more than the quality or appeal of the lighting effect. It is best if you can see the fixtures in a live application before you buy.
    While it may not be high tech, a few well placed warm to daylight flourescent fixtures, with old fashioned incandescents for task lighting areas is still the gold standard.
    JLF likes this.
  14. colombo2cam
    colombo2cam Formula Junior
    Jan 31, 2019
    840
    Ted
    When I did my garage - I installed normal fixtures that throw off nice complimentary light. I also installed LED panels on a different circuit for when I am working on something.
  15. MobileJay
    MobileJay Formula 3
    Sep 9, 2006
    1,441
    Houston
    Jason Cavallo
    Where did you purchase these lights? I've seen this style in many locations but never pulled the trigger.
  16. Lagunae92
    Lagunae92 F1 Rookie
    2,775
    SoCal
    Extreme1, Thecadster and MobileJay like this.
  17. MobileJay
    MobileJay Formula 3
    Sep 9, 2006
    1,441
    Houston
    Jason Cavallo
    No worries, thanks I’ll check it out.
  18. moysiuan
    moysiuan F1 Rookie
    4,177
    Canada
    Nice car (and matching wall colour)! The lighting does seem to take up alot of ceiling square footage for the amount of light produced. I notice there are pot lights on the permiter too, meaning the lighting of just the panels must not distribute well, this directional down lighting effect is part of the problem with led's or more accurately the lack of desire to design more costly reflectors and diffusers into the design.
  19. Lagunae92
    Lagunae92 F1 Rookie
    2,775
    SoCal
    Thanks. Waiting for the Ferrari shield to come. There are can lights around the perimeter for two reasons. They are adjustable temperature color, and there for standard work light. The LED panels were chosen because I like the look and how much presence they have. Don’t need the cans on as well, but the cans aren’t enough in this configuration and with the panels on it is much better. What you are seeing is one guys vision with form over function. Could have done it much more economically and minimalistic, but this has better presence.
  20. Lagunae92
    Lagunae92 F1 Rookie
    2,775
    SoCal
    Three different configurations. May try 4000k on the cans.
  21. moysiuan
    moysiuan F1 Rookie
    4,177
    Canada
    Yes, I understand that aesthetics are a big part of led lighting, that's why architects love them, so we are in a golden age of lighting experimentation. I suppose the designer of this car could have used a simple dome light for the function :) I wonder if anyone has done a starlight garage ceiling...
    Mang likes this.
  22. Lagunae92
    Lagunae92 F1 Rookie
    2,775
    SoCal
    That would be fun! I did see that an F8 owner put a starry headliner in. I like it in the rolls. Not in an F car.
    jake23581 likes this.
  23. EnzoItaly
    EnzoItaly Formula Junior
    Sep 29, 2016
    266
  24. Lagunae92
    Lagunae92 F1 Rookie
    2,775
    SoCal
    Thanks! There's more to it and more coming. I'll post it up when it's done. The Pista is Rosso Fuoco and the 812 is Rosso Maranello.
