Fuel Tank Removal | FerrariChat
Fuel Tank Removal
Discussion in '206/246' started by Eltel246, Feb 15, 2021.
  1. Eltel246
    Eltel246 Karting
    May 14, 2012
    180
    London
    Charles Hill
    Looking to remove the fuel tanks on my M series to give them a good clean out.
    Any advice on removal would be most welcome. Do I need to remove any suspension components to get them out.
    Car is non A/C.
  2. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    Can you pull all the hoses and flush them in place or is it a varnish/sediment buildup situation that requires some scrubbing and shaking?
    I've only done tanks with the engine out, looks tough otherwise. sorry not much help...
    Eltel246 likes this.
  3. daviekj
    daviekj Formula Junior
    486
    If I recall correctly the fuel tanks can be removed with engine in place. I don’t recall having to remove any suspension. Tanks come out through respective wheel arches.
    Kevin
    Eltel246 and GermanDino like this.
  4. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    from memory the tanks will not come out with the suspension units in place especially the top arms, you risk puncturing the tank, as a minimum the discs need to be removed as well.
    tony
  5. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,485
    Germany
    Matthias
    that`s correct, needs a bit of skills, I have done it .... but not easy
  6. Eltel246
    Eltel246 Karting
    May 14, 2012
    180
    London
    Charles Hill
    Thanks for the advice guys. Always helpfull as usual.
    Will get stuck in and if any of the suspension needs to be removed so be it.
    synchro likes this.
  7. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    On both my Euro and USA E series the driver's side tank was able to be lifted up, rotated 90 degrees twice and then removed but I had to touch up the exterior from minor paint rubs. The passenger's side will depend on the piping and sender configuration (I have seen some Dinos with fuel tank senders on either tank).
