FS - Carbon Ceramic Brakes for Maserati GranTurismo - Quattroporte | FerrariChat
Discussion in 'Other Parts & Collectibles' started by Exotic Lambo, Aug 8, 2016.
  1. Exotic Lambo
    Exotic Lambo Formula Junior
    Aug 15, 2011
    491
    South Florida
    Gianca
    #1 Exotic Lambo, Aug 8, 2016
    Big Brake Carbon Ceramic Kit for Maserati GranTurismo or Quattroporte
    Description:
    Utilizing Ferrari parts we have come up with a direct bolt on carbon ceramic kit for Maserati GranTurismo and Quattroportes.
    Comparison:
    OEM front steel rotor: 360 mm - 24.2 lbs or 53.24 kg
    Front carbon rotor: 394 mm - 15.29 or 33.63 kg
    OEM rear steel rotor: 330 mm - 22.1 lbs or
    Rear carbon rotor: 380 mm - 11.9 lbs or 26.18 kg
    Fitment:
    2008 - 2017 Maserati GranTurismo
    2004 - 2013 Maserati Quattroporte
    Included:
    -Instructions
    -Front and rear used carbon rotors 394 mm and 380 mm (also new rotors are available)
    -Front 6 piston used calipers and brake pads, custom painted in any color
    -Rear 4 piston used calipers and brake pads, custom painted in any color
    -Custom 6061 T6 anodize aluminium front and rear rotor hats
    -Custom 6061 T6 anodize aluminium front and rear caliper brackets
    -Front and rear 12.9 steel caliper bolts
    -New front and rear steel braided lines
    With used rotors: $9,990.00
    With new rotors: 14,990.00
    shipped anywhere in the US
  2. raider1968
    raider1968 F1 Rookie
    Mar 13, 2008
    4,966
    NC Mnts & Asheville
    John E
    R the new cc brakes still available for the 2009 GTS? Could I have a dealer install them - I use Ferrari of Atlanta
    Am using the car more all the time and the only complaint I have is the steel rotors
  3. Exotic Lambo
    Aug 15, 2011
    491
    South Florida
    Gianca
    I sold the kit but I could put another one together if you are interested, it would take about 60 days.
    I have the calipers, brake lines, pads and rotors; I would have to have cut the rotor hats and caliper brackets.
    Any mechanic could install them, it is really not rocket science.
  4. raider1968
    Mar 13, 2008
    4,966
    NC Mnts & Asheville
    John E
    definitely want to do it - could you call when you have a chance - I'll private message my phone number
  5. Exotic Lambo
    Aug 15, 2011
    491
    South Florida
    Gianca
    Sure will, thanks.
  6. leon2
    leon2 Rookie
    Dec 27, 2019
    16
    Sydney, Australia
    Leon Chan
    Are you able to make ccm brake kits for the 4200GT/ Gransport? I think they are also 5x108 but different offsets.
    Sent from my SM-N960F using Tapatalk
  7. amuha
    amuha Rookie
    Mar 1, 2022
    1
    BERT
    hello, are these disc same size as OEM brembo carbon ceramic discs ?
  8. oohsnapss
    oohsnapss Rookie
    Feb 4, 2023
    1
    Hank Lee
    do you still have these kits available?
  9. tazandjan
    39,123
    394 mm rotors are Corvette rotors. Ferrari rotors are 398 mm.
    3604u likes this.
