355 - Ferrari 355 F1 Gear Display Missing Pixels - Fix Video | FerrariChat
355 Ferrari 355 F1 Gear Display Missing Pixels - Fix Video
Discussion in '348/355' started by spiderscott, May 14, 2019.
  1. spiderscott
    spiderscott Formula 3
    1,661
    Ratarossa HQ UK
    Ratarossa
    Another common 355 problem fix.
    Ferrari 355 'F1' Gear Display with Missing Pixels. Just filmed my fix
    Ive posted this on the Technical Forum but thought it would be handy on the 355/348 model specific thread also.
    Hope it helps
    Qavion likes this.
  2. PaulK
    PaulK F1 Rookie
    4,776
    Michigan
    Paul
    A really good video. Was literally just thinking about this.
  3. Qavion
    Qavion F1 World Champ
    14,224
    Ian Riddell
    #3 Qavion, May 14, 2019
    And now for the pedants and obsessive types....
    Step 1: Make sure all your dash warning lights are working (They are a lot easier to relamp when the binnacle has been completely removed). Also see last step.
    Most of the lights that need to be operating during startup can be seen in the Scott's video. Variations possible with 2.7 and 5.2 cars, F1, USA/Euro, etc... You may have to start the car to see the whole range.
    Step 2: Put towels on top of steering column and dash area to prevent metal and sharp hard plastic parts damaging leather and softer plastic.
    Step 3: If you have light coloured leather, wrap your screwdriver in tape to prevent marking.
    Step 4: Throw away large gauge solder and use only your fine gauge solder
    Be aware that the instrument connectors (flat/film type) can put up a fight. Be firm, but gentle.
    Sometimes braid (desolder wick) is easier to use than a solder sucker for removing solder.
    Get the orientation of the digital display correct!
    Clean tape type connectors as applicable (e.g. using Deoxit)
    If you are a new owner, make sure the dodgy previous owner hasn't rewired the binnacle to illuminate the CEL during start, but not if there is an actual fault.
    Rewrap wiring with Tesa cloth tape in dash area (as applicable)
    Spend half an hour trying to reinsert the instrument binnacle screws. Gets easier with practise.
    spiderscott likes this.
  4. spiderscott
    1,661
    Ratarossa HQ UK
    Ratarossa
    Thanks Ian
    Some great extra tips added there
  5. phrogs
    phrogs F1 Veteran
    7,340
    Kzoo Michigan
    I fixed mine but I did send it out to be repaired via Ricambi America. Figured for as fiddly it is I can let someone else do the soldering.
