Ferrari 348TS Revs Sticking when accelerating Hard | FerrariChat
Discussion in 'United Kingdom' started by RedF1, Oct 30, 2019.
  1. RedF1
    RedF1 Rookie
    Oct 29, 2019
    8
    Gloucestershire Uk
    Justin Hibberd
    Hi All
    I had my 348TS serviced about 20 months ago at my local Ferrari sprecialist in Worcester and as i was driving home, i pulled away hard and the revs seemed to stick around 7k and not go down. I switched the engine off and back on and it was fine. I hardly use the car, so when i complained the Company who serviced it said it was too late.
    The car drives absolutely perfect, but if i pull away fast, the revs stick again - unfortunately now, if i switch the engine off and back on, it still is at high revs - then it seems to fix itself.
    The accelerator is not stuck and the odd thing is that i checked whilst it was revving in the stuck position and the carbs were closed.
    Any ideas what this could be?
  2. rob.kruiswijk
    rob.kruiswijk Formula 3
    Jun 15, 2014
    1,380
    Netherlands
    Rob
    As a starter Check you accelerator cable which opens the throttle valves. If your engine revs are high push is throttle valves back in the engine compartiment.
    The cable might need some lubrication (oil)
  3. rob.kruiswijk
    Jun 15, 2014
    1,380
    Netherlands
    Rob
  4. Silber
    Silber Karting
    Jun 6, 2014
    119
    Switzerland
    Another idea... Some 'stickiness' in revs can occur if the battery has been disconnected/switched off and then reconnected and the car not left to idle long enough for the ECU to reset itself. Need to start the engine and not touch the gas for several minutes, allowing it enough time to figure out air-fuel mix etc. If don't leave it for long enough before driving, it can give the odd sticky stutter.
  5. A348W
    A348W Formula 3
    Jun 28, 2017
    1,749
    North Wiltshire, UK
    Well the OP hasn't been on here in 26 weeks so he must have fixed it !?
    However his post does not really make sense "...and the carbs were closed". Not sure what he is referring to here...no carbs on a 348!
    But with respect to the symptoms mentioned, the linkage can easily come off the accelerator pedal but still partially function...ask me how I know!
