F8 exhaust options. GPF delete | FerrariChat
Discussion in '458 Italia/488/F8' started by LMH, May 23, 2020.
  1. LMH
    LMH Karting
    May 5, 2019
    195
    Spain
    jim g likes this.
  2. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    783
    Pete
    This looks very interesting indeed, thanks for sharing
  3. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,291
    Question: Is the Pista a good reference for the F8 in regards to removing the GPF?
    Aren’t the engines and turbos in these cars identical? And weren’t early production Pistas produced without a GPF? If so, then the tuning of the Pista could be a good reference for how to tune the F8 if the GPF were removed.
    Question #2: Is the GPF legally required here in the USA in 2020?
    Jo Sta7 likes this.
  4. Jo Sta7
    Jo Sta7 F1 Rookie
    4,921
    Scottsdale/Pittsburgh
    Jon
    it might be state to state but on #2 the answer is no.
  5. Ngcanada
    Ngcanada Formula Junior
    May 16, 2016
    630
    Ottawa Canada
    In regards to this topic, can we also add a capristo or forza exhaust valve controller? I cannot remember somewhere here a member possibly tried and it set off the check engine light. I just want this car to sound better/louder from outside. Its the only one thing holding me back still to really make the move to the F8.
    LMH likes this.
  6. ScrappyB
    ScrappyB Formula 3
    Oct 3, 2017
    1,378
    T
    No Pista has been or will be produced with GPF.
    Bundy and Gh21631 like this.
  7. Gh21631
    Gh21631 F1 Veteran
    8,339
    East
    Valve controller doesn't set off check engine light
  8. LMH
    LMH Karting
    May 5, 2019
    195
    Spain
    In the general F8 chat someone commented that he had the valves pinned and some error/limp mode appear, and he had to undo it
    Wasenda likes this.
  9. Gh21631
    Gh21631 F1 Veteran
    8,339
    East
    That doesn't seem to make sense and hasn't been an issue on any other Ferrari including the Pista.
  10. junc
    junc Formula Junior
    501
    Chicago/Laguna Beach
    Jun
    I’ve heard on the F8 they put sensors in the exhaust that will set off check engine lights if valves are pinned. That wasn’t done before.
  11. 17 488spider
    17 488spider Rookie
    May 22, 2020
    8
    New York, NY
    Nicholas
    Is there a video of this in action?
  12. Drson
    Drson Karting
    Mar 18, 2018
    126
    Southeast
    John Galt
    Just search FChat...well documented that you cannot pin the valves in an F8 due to ECU causing warning lights....strictly due to GPF...
    Also have to be concerned that Ferrari will not honor warranty issues if GPF altered in any way....
    Maybe these tuner companies have figured out a way to get by all of this....but I would want it in writing before I made a change....
    I really thought the F8 exhaust sound would be disappointing after owning a 458 but the F8 sounds pretty darn good...especially on cold start and above 3500 rpm....
    Coincid and LMH like this.
  13. OSUferrari
    OSUferrari Formula Junior
    613
    Denver CO
    I tried on my F8 and got error. As did Cpiguy. F8 and Portofino are first Ferrari’s you cannot pin open values (until someone figures a work around - hopefully soon!
    Bundy, LMH and junc like this.
  14. Cigarzman
    Cigarzman F1 Veteran
    I was told by my dealer if you put on a controller ,
    it will not get any errors. Apparently they have installed a few. Best , Kirk
  15. Ngcanada
    May 16, 2016
    630
    Ottawa Canada
    Really. Has any of our members here installed the unit on their F8. I would love to here real life experience
  16. PTG1
    PTG1 Formula Junior
    Oct 7, 2017
    783
    Pete
    Yes that's right, pinning throws up errors, this is confirmed
    LMH likes this.
  17. MalibuGuy
    Sep 18, 2007
    5,291
    Why not buy a Pista exhaust which doesn’t feature the GPF and bolt that into the F8. Or else dissect a Pista exhaust and use that design on your F8.
    Then you would probably need to retune the software but you could use the Pista software as a guide.
    Would that be too difficult to do?
  18. Coincid
    Coincid F1 Rookie
    Dec 9, 2014
    3,577
    Canada
    The essential differentiation between the Pista and the F8 is predicated upon software. I have little doubt that there are tuning experts that can recalibrate the F8 to mimic that of the Pista at a fraction of the cost difference between the 2 models.
    ScottS and MalibuGuy like this.
  19. cpiguy
    cpiguy Formula 3
    2,107
    Westlake Village, CA
    Arnie Friedman
    I’ve had my valves pinned open and it affected performance and popped an error light. The dealer reverse it. Any of the electronic valve kits will do the same. Novitec has already developed an exhaust system for the F8. It can be ordered now for delivery soon. It’s very similar to the Pista exhaust. I will be considering it once I hear a few more video’s.
    LMH likes this.
  20. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    #20 Shadowfax, May 25, 2020
    Your dealers seem to say a lot of things and make a lot of claims without firstly doing their homework because if they did they wouldn't have bothered pining the F8 exhaust valves open to begin with. The F8 pre and post cat pressure sensor issue is old news my way......can't fit valve controller or pin valves or upset the back-pressure or it throws CEL and drops into a form of limp mode.
    With Pista, the usual valve controllers which were available will indeed all throw a CEL on the Pista and put the car into limp which is precisely why only the very latest controllers specifically designed for Pista will work on the car. They use a secondary duplicate set of dummy electronic valve actuators which piggy back the cars existing actuators to trick the ecu into thinking it still has control over the valves.
    With F8 the actuators are electronically controlled and variable position opening unlike Pista's which use vacuum operation so the valves are either fully opened or fully closed by the ECU.
    F8's variable position opening controls and maintain the back-pressure level in the pipe (post turbo) within a set parameter so the GPF works properly. If you screw with around with that and the back-pressure within the pipe falls outside the set parameters then the car throws CEL and goes into limp.
    Changing the muffler will also affect the back pressure upstream and I imagine that depending upon how much baffling is removed from the muffler to make more sound it could take the back-pressure levels outside of the parameters so I wouldn't hold too much hope for much improvement in sound at the muffler end. The sensors also detect any change in pulse so any change in pulse the same thing happens again. I wish F8 owners and the exhaust guys good luck with it.
    Vertix and Randyslovis like this.
  21. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    For sure but then kaboom there goes your warranty.
  22. cpiguy
    cpiguy Formula 3
    2,107
    Arnie Friedman
    My dealer took a shot at opening the valves knowIng that the word was it would throw a CEL They reversed and didn’t charge me a nickel for doing it or picking up and delivering the car twice. They’re actually great guys. As far as exhaust solutions, Novitec already has a system that is very similar to the catless and valved system they sell for the Pista, which I heard a few days ago. I think they’re taking ordered with delivery in a few weeks.
  23. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    Funny how when you click on their link the virus warning immediately engages on the computer, warning the site is dangerous (hackers and malware etc) lol.
    How do they do it? I imagine a software re write if anything. The rest of their claims being a lure to their hacking den.
  24. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    #24 Shadowfax, May 25, 2020
    Yes but I'm sure - as is the case with Novi's Pista cat-less option - that a re write is needed to use it. The only system that will work on Pista without a re write is the valved version using the stock cats. The high flow cats can trigger a CEL as the sensor in the plenum detects the change which is why you have the OBD plug in to clear them out. One positive is that the CEL doesn't affect the running or performance from what I've been told but on the F8 having the sensor upstream in the inlet manifold/plenum and downstream post cat the fail safes work in unison and are in place for any change in back-pressure or pulse up or downstream. With F8 the only way forward is a software rewrite from what Im told and that means your warranty is toast.
  25. cpiguy
    cpiguy Formula 3
    2,107
    Arnie Friedman
    Ok, so I’m no expert, but one of the guys the does some work on my Ferrari’s can add electronically controlled valves without any CEL issues. He briefly explained how he does it. He adds a second set of valves, with control. He charges around $2500 and guarantees it.
    Cigarzman likes this.
