F430 Cold Start Problem | Page 3 | FerrariChat
Discussion in '360/430' started by yingfu, May 19, 2019.
  1. gatago
    gatago Karting
    Jun 28, 2019
    119
    Marco
    Have you had the battery checked? If not do that before you spend any money at all. An important test is battery voltage during cranking. In the US you can buy a device that does these checks for under $50.
  2. vmule
    vmule Karting
    Jun 20, 2020
    52
    Vito M
    I’ve the same issue, and it goes away if I give it a bit of gas after I turn the car on.
    Its a bit annoying tho.
  3. 1995F512M
    1995F512M Rookie
    Nov 20, 2014
    48
    haha i posted the same question not long ago too.... my car used to be fine and now it does the same thing....and when i ask the dealer the service rep said the same thing to me.....just turn off and start again
  4. 1995F512M
    1995F512M Rookie
    Nov 20, 2014
    48
    my scud does the same thing thanks in advance
  5. 1995F512M
    1995F512M Rookie
    Nov 20, 2014
    48
    hey everyone who has this issue, does your check engine light stays on until this problem is gone?
    normally i turn on the car and wait for the check engine light to go off before i start the engine but since this started to happen i have to start the engine before the check engine light will go away and it only do so after the rough idle goes away.
  6. vmule
    vmule Karting
    Jun 20, 2020
    52
    Vito M
    The engine light goes off only after the engine is on and you wait a few seconds.
  7. brookliner7
    brookliner7 Formula Junior
    885
    San Antonio, TX
    Hans
    I remember I was reading this thread when I was having issues with my 360 on cold starts when it would sit for like 8 to 12 hours, would idle terribly, idle hunt a little bit sometimes, and sometimes it would just sputter and die. The second time you started it she would fire up and start just fine.
    I wasted a lot of my time chasing the issues that were mentioned in this thread.
    Was the mass airflow sensor.
    Sent from my LM-V350 using FerrariChat.com mobile app
    1995F512M and kes7u like this.
  8. kes7u
    kes7u Formula 3
    Oct 18, 2017
    1,237
    Shorewood, MN
    Kevin
    Same issues here. Nearly identical. I don't see a record of my MAFs being charged out, so looks like a winter project!
    Thanks!
    Kevin
    Sent from my SM-G930P using FerrariChat.com mobile app
    brookliner7 likes this.
  9. 1995F512M
    1995F512M Rookie
    Nov 20, 2014
    48
    Maybe i will try the CSC sensor cleaner ...
  10. 1995F512M
    1995F512M Rookie
    Nov 20, 2014
    48
    just an update, i bought MAF sensor cleaner and opened the air box and sprayed the MAF sensor and then let it dry, it seems to have solved the problem. thanks
    oaftab and Qavion like this.
