F355 heater (again sorry) and cooling fans | FerrariChat
Discussion in '348/355' started by MikeeB355, Jan 18, 2020.
  1. MikeeB355
    MikeeB355 Karting
    Dec 7, 2019
    82
    S Wales
    Michel Bee
    Evening all. I fulfilled a long lived dream last month and finally bought an F355, a Nero Daytona manual GTS from my local Ferrari dealer. Have to say I’m getting to grips with driving my hero but am hoping the addition of a Capristo exhaust and the arrival of spring will help it become the thing I dreamt it would be.
    Anyway, the heater wasn’t working, you might be surprised to know, so I set about getting a new motor for it. Managed to get one from a Saab breaker for a very reasonable £20 inc delivery ;0)))) and today stripped the front end to change it.
    First thing I noticed was the connectors are different, bugger... So I removed the old one, refitted the valve after opening it manually so at least I’ll have some heat inside the car and put everything back in place while I figured out what to do next. Took the car out for a short drive afterwards and it was soooo nice to feel some warmth after a month of seemingly subzero air coming out of the vents.
    After a lovely steak cooked by my very understanding wife and a large glass of rouge, I grabbed a set of screwdrivers and set about removing the gearbox bit from the Saab motor to see what lurked behind and if, yeah as if,, it would be a simple case of swapping the two parts.
    Hardly believing it myself, it was as easy as that. I simply removed all the screws connecting the motor to the black plastic gearbox part on both motors and swapped them over. I may need to tweak the position of the lever arm tomorrow when I refit it as it may not have been in the same place as the original was, should have checked before I took it off but there you go.. but still, I sit here tonight quite chuffed with myself.
    One other thing I noticed, and this is slightly worrying, is that only the near side fan was kicking in whilst the car was idling (UK RHD car..) Is this normal or should both fans run simultaneously?
    Thanking you for your help in advance
  2. Qavion
    Qavion F1 World Champ
    11,567
    Ian Riddell
    I think you'll find that everything from the aft cabin bulkhead rearwards is the same on LHD and RHD* cars, but anyway, the fans are independent. According to the Workshop Manual (WSM), the left hand fan (nearside on your car) is controlled by engine coolant temperature and the right hand/offside fan is controlled by oil temperature (since the oil radiator is "in series").
    Anyway, congratulations (on your purchase and finding a hot water valve motor). Hopefully the HVAC ECU knows how to control it when you hook everything back up.
    *other than regional/country variations
    308 GTB likes this.
  3. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    Indeed, since the ecu controls that motor to open and close the valve. I wonder if there was anything wrong with the original motor? Was it tested prior?
  4. MikeeB355
    MikeeB355 Karting
    Dec 7, 2019
    82
    S Wales
    Michel Bee
    Ok something of an update.
    Fitted the new motor and still nothing, hmmmm...
    I tested the old motor and it seemed dead which was why I went for a new one but that still asnt working so I decided to strip the two motors completely.
    What I found was very interesting. You can take the motor apart quite easily and there are no breakable parts that get damaged in doing so. I stripped the Ferrari motor and sprayed some contact cleaner on the bushes and removed the drive gear from the end of the shaft. This freed up the motor amd I spun it a few times by hand. Tried connecting it to a spare battery but it still wouldn't work so I removed the two small screws that hold it into the aluminium casing, this released the motor completely amd it simply slid out. Image Unavailable, Please Login
    Qavion likes this.
  5. MikeeB355
    MikeeB355 Karting
    Dec 7, 2019
    82
    S Wales
    Michel Bee
    This is the offending part. However, once out of the housing and connected to the battery it worked, spinning fast and freely. I then stripped the Saab motor in the same way and the motor in that one was exactly the same as the Ferrari one. This made me think.. Lots of people have said about having problems with wrong connectors on motors they have bought but if they strip the new motor apart and remove the actual motor, this can be swapped straight over for the old Ferrari one.
    Anyway, I got both motors working so reassembled them in their original housings. Happy with my work I reconnected the Ferrari motor to the car and tried it but still nothing. I checked the 30 amp fuse for the heating system and that was fine so I'm guessing the fault lies somewhere between the knob in the car, the one on the console, not the one trying to fathom out wtf is going on, and the motor itself.
    Watch this space for further..
  6. Qavion
    11,567
    Ian Riddell
    Good to know. Thanks.
    So you've applied 12 volts to the actuator connector and you can see the gearbox output running in both directions off the car? Have you also checked the potentiometer in the actuator?
    Here's the wiring diagram (5.2 car):
    5.2 HVAC Wiring Diagram
    Are other control panel functions operating (air direction, fan speed, etc)? Have you read the message threads on ECU driver chips? The control panel is not the brains of the system.
  7. Andy 355
    Jun 2, 2013
    434
    If the motors bench test ok, unfortunately the problem most likely will be in the ecu. This is a common condition and there are companies that will repair your ecu. I have seen this many times before. Fortunately for you, i believe the repairer for your ecu is indeed based in the usa.
    MikeeB355 likes this.
  8. MikeeB355
    MikeeB355 Karting
    Dec 7, 2019
    82
    S Wales
    Michel Bee
    I'm in the UK..
  9. Andy 355
    Jun 2, 2013
    434
    Ok, well you will have to ship it for repair as i have in the past...
  10. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,667
    CT
    John Kreskovsky
    #10 johnk..., Jan 20, 2020
    INRange and MikeeB355 like this.
  11. johnk...
    Jun 11, 2004
    10,667
    CT
    John Kreskovsky
    By the way, what year Saab was the valve motor from?
  12. MikeeB355
    MikeeB355 Karting
    Dec 7, 2019
    82
    S Wales
    Michel Bee
    It was a 1998 John
  13. MikeeB355
    MikeeB355 Karting
    Dec 7, 2019
    82
    S Wales
    Michel Bee
  14. johnk...
    Jun 11, 2004
    10,667
    CT
    John Kreskovsky
    1998 Sabb, thanks.
    That's is how mine failed. No power to the motor. Fortunately My car is a spider and I only take it out when it's top down weather. But it failed "open" so I was out driving in 90 degree weather with the dam thing blowing full hot. At least I was able to shut it off but I like to run with the AC on when it's that hot. I was able to close the valve later by applying 12V to the motor, and there is stays. I have the chips to replace in the ECU but haven't gotten around to it since I don't really care about having heat. Plus, I want to have someone hook up an SD2 and check what the ECU is doing before I start replacing chips, just in case it is something else.
  15. MikeeB355
    MikeeB355 Karting
    Dec 7, 2019
    82
    S Wales
    Michel Bee
    Mine was the opposite, it was shut closed so no heat at all. I've manually opened it now and will leave it like that u til it's necessary to run the air con but there are very few of those days here lol
  16. Qavion
    11,567
    Ian Riddell
    The valve actuator has a feedback (potentiometer) circuit. There may be no output from the ECU if you don't hook up the potentiometer wires (to the ECU) when doing your tests. That's why I asked you if you'd checked the potentiometer.
    Note also, the earth (ground) for the potentiometer may be inside the ECU (despite what the wiring diagram shows). A local chassis earth may not be sufficient.
  17. johnk...
    Jun 11, 2004
    10,667
    CT
    John Kreskovsky
    Qavion likes this.
  18. f355spider
    f355spider F1 World Champ
    17,940
    I have a thread about changing out the Bosch motor. Please note the last three digits "917" are relevant. I can't remember if that is the exact number or not. I will have to find the thread and report back. As I bought a couple of these, and one worked and one did not work correctly. And the only difference between them was the last three digits in an oval.
    FOUND IT:
    "Important info on Bosch part #0 390 721 006! These are discontinued, and you can source them from Saab used parts dealers (from a model year 2000 Saab 9000)
    There is an important sub part number to this item, I just learned today. There is a number in a circle "944" after the main part number Bosch part #0 390 721 006
    It is important you get the one with the "944", if you get the one with "917" the operation is reversed, and it won't work! I got mine from a Saab breaker parts dealer and he had both. I got lucky the first time, and it worked perfectly. Today, I was helping a friend fix his, and got one with "917" on it, and it worked in reverse. We called the Saab specialist and he admitted there are different versions and he was at a loss to know which was which, but when we checked my car, my old broken one, and the one we removed off my friends car, all had "944" in a circle after Bosch part #0 390 721 006.
    Both the 917 and 944 are used on the Saab 9000, so very important to get the right one. "
    Qavion likes this.
  19. johnk...
    Jun 11, 2004
    10,667
    CT
    John Kreskovsky
    Are you sure about the last 3 digits? I have seen both 917 and 944 listed as being from F355, 348. The difference being 917 is marked Made in Belgium and 944 Made in France. As far as operation, simple fix by either reversing the proper leads. Being a reversible DC motor, which way it rotates just depends on the polarity of the applied voltage. Also, the Saab 9000 ended production in 1998.
    Qavion likes this.
  20. f355spider
    17,940
    I have simply posted my experience with two 355s where I replaced this motor. Perhaps one can start modifying the wiring, but that screws the next owner to figure out. The proper ones are readily available with a few phone calls. I don't know about the years of Saabs from personal knowledge, I only was given the information from the Saab breaker yard I obtained the part from, and that was what was printed on the tags on both parts. If they were in error, I apologize for passing along bad info.
  21. MikeeB355
    MikeeB355 Karting
    Dec 7, 2019
    82
    S Wales
    Michel Bee
    The 914 and 917 casings are different but the actual motors inside are exactly the same. I stripped my original motor casing and the Saab one and whilst they were clearly externally different, the actual motor inside, which was easily accessed, was the same in both models so if anyone has a motor that is kaput, they can use the 917 version by taking the motor out and swapping it over with their original. Mine seemed to have a bit of a flat spot on the bushes which was fixed with a spray of contact cleaner, after that it worked fine when connected to a 12 v power supply. The problem therefore lays elsewhere for me, that’s what I’m currently working on
    f355spider and Qavion like this.
  22. johnk...
    Jun 11, 2004
    10,667
    CT
    John Kreskovsky
    Thanks for the clarification as both are being represented as for the 355 on the market.
  23. f355spider
    17,940
    Now your previous post makes total sense to me Mike, ,thank you! 917 is a simple part swap. 944 will still work, but requires removing the motor from the housing and swapping with the original one. Got it. :)
  24. MikeeB355
    MikeeB355 Karting
    Dec 7, 2019
    82
    S Wales
    Michel Bee
    That's right, strip the two parts down, remove the motors and swap, then reassemble.
    f355spider likes this.
  25. Ben111
    Ben111 Karting
    Jun 14, 2018
    57
    Ben
    My 355 keeps blowing the 30amp fuse, the car came with a circuit breaker so I keep resetting the fuse, it trips again within seconds.
    is this a known issue? And is there a fix?
