F355 factory roll bar? | Page 2 | FerrariChat
Discussion in '348/355' started by BRADAN, Mar 10, 2010.
  1. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,569
    Calgary, Canada
    great info, thanks
    nice, cross weighted and everything, all in for 2818lbs ...i suppose with the steel monoque that you're not going to be able and get quite as light as the tube frame cars (3x8)?
    agreed, i wouldn't just plop a plate on the floor sheet metal, it'd simply tear out around the plate in an impact ...that mustang is a good graphic example
    my welding guy has/does a lot for the local RS & SS class track guys, and would use him for any cage work ....here either a scca cert tag or an inspection hole must be in place to pass inspection
  2. JeremyJon
    Jul 28, 2010
    7,569
    Calgary, Canada
    #27 JeremyJon, Apr 1, 2011
    Edit: found a few posts showing mounting plates
    http://www.ferrarichat.com/forum/showpost.php?p=140401053&postcount=4
    http://www.ferrarichat.com/forum/showpost.php?p=136308126&postcount=5
    http://www.ferrarichat.com/forum/showpost.php?p=136311263&postcount=17
    checking into things further, it appears easily to meet SCCA that even 1.5" DOM .120" could be used, and meet the pro-race class spec as well
    if i'm not mistaken standard DOM is 1020 mild, and besides any ERW tubing is $ more (here anyways)
  3. vvassallo
    vvassallo F1 Veteran
    8,281
    Palos Verdes
    Vince V
    OMG, and you want to drive our car?!!!
  4. fatbillybob
    Aug 10, 2002
    26,437
    socal
    Well...yes.
  5. sheargold1
    sheargold1 Rookie
    Jul 20, 2015
    1
    i have a 1998 red 355 with cream leather challenge rear panel and a factory fitted cream leather covered roll cage.
    I have not seen another one anywhere?
    Does anyone have any info about them, I have been unable to contact the original owner.
    ShineKen likes this.
  6. StanT
    StanT Formula Junior
    356
    Vienna, VA
    Do you know any of its geographic history? Was it first delivered overseas? Perhaps Dubai?
    Get a Carfax report. The 2 Dubai cars I know of both start their Carfax reports in March, 2000, in a Denver suburb that I don't recall now.
  7. StanT
    356
    Vienna, VA
  8. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    can you post a picture?
  9. malex
    malex Formula 3
    1,246
    FL
    #34 malex, Jul 23, 2015
    Does yours look similar to this?
  10. ShineKen
    ShineKen F1 World Champ
    16,707
    Southern California
    Nostradamus
    We need more pics of the roll bar
  11. ShineKen
    16,707
    Southern California
    Nostradamus
    Eurospares got back to me today. They checked with Italy. No part number. It was a "specially commissioned part" at the time the cars were being built. So add $20k to the value if you see one with it :).
    Yassa likes this.
  12. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,508
    Lake Villa IL
    ^ Easy enough to make one :) I wouldn't want to add the weight unless I was going to have the car on track all the time.
    I mean, if you do enough weight reduction the roof won't collapse when you roll over anyway :p
  13. ShineKen
    16,707
    Southern California
    Nostradamus
    It looks like the OMP Challenge roll cage without all the extra bars.
  14. StanT
    356
    Vienna, VA
    SoCal1, 308 GTB and ShineKen like this.
  15. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,572
    SoCal LA/OC/New Mexico
    Tim Dee
    Love it
    That cage looks custom or another version
    as the OMP Challenge would sit about 1-2 inch higher and the metal tube alone will scrap the interior panel. Looks like you have a cover and possibly padding also.
    Great looking car :)
  16. StanT
    356
    Vienna, VA
    All factory built, per PDF build sheet. See the attached PDF for pictures of 1 of 5 sister cars special ordered by the same Dubai dealership, also with a roll bar.
    Yes, the roll bar has leather covering over a bit of padding. But not like thick padding used in some cars to protect drivers' heads, etc.
    SoCal1 likes this.
  17. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,572
    Tim Dee
    No doubt at all about OEM Im just stating it is a scooch lower then the track model. Nice comparison
    StanT likes this.
  18. carnutdallas
    carnutdallas Formula 3
    1,704
    Dallas Burbs
    Rob
  19. antodoudaklian
    May 3, 2021
    2
    Northern Virginia
    Anto Doudaklian
    Awesome! Is this Ferrari of Washington?
  20. StanT
    356
    Vienna, VA
    Yes it is.
    antodoudaklian likes this.
  21. Philipnz
    Philipnz Karting
    Apr 12, 2015
    211
    Whitianga New Zealand
    Philip Hart
    ShineKen and 308 GTB like this.
