355 - F355 / 355F1 Parts Thread | Page 7 | FerrariChat
355 F355 / 355F1 Parts Thread
Discussion in '348/355' started by CRAIGF355, Aug 7, 2011.
  1. WATSON
    23,667
    WI
    Direct, plug-in replacement O2 sensors for 5.2 engines:
    Bosch 13819 - pre cat O2 sensor.
    Bosch 13820 - post cat O2 sensor
  2. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    Ferrari F355 5.2 fuel pump #140317
    Bosch 0 580 254 011. 128 L/Hr
  3. flat_plane_eddie
    flat_plane_eddie F1 Rookie
    Owner Regional Sponsor Silver Subscribed
    Mar 30, 2013
    3,167
    DC
    Eddie
    Does anyone know if the 355 brake pump kit can be found from a different car or directly from the manufacturer? The Ferrari part number is 70000772. Tried a search here but couldn't find anything...
  4. The Real Student
    Oct 6, 2015
    10
    Hey guys.
    Any thoughts on how to get the Motronic ECU fixed? UK car and it's looking like it's obsolete !
    The car won't pass the local test on emissions; Lambda is too high, CO & HC are OK.
    Thanks!
  5. Robbe
    Robbe Formula Junior
    622
    The Netherlands
    LHS Temperature switch (not the bosch unit, but the one that actually is in the LHS radiator), Ferrari part nr 158655 is the same as a Fiat Ritmo 75 series 1, and Opel(Vauxhall) Calibra 2.0, and eeven a Holden of some sort for the aussies.
    Same temp range, 87-82. Any part store should be able to order this for you , prices around 15 - 20 usd.
  6. V8ray
    V8ray Formula Junior
    Jun 18, 2013
    251
    Ray
    Is this the right one? https://www.ebay.com/itm/401287772632
  7. Robbe
    622
    The Netherlands
    Yes, that is the correct one. (at least mine was identical, and the cars I see that it is for, have the same low temp specs.)
  8. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,012
    Indio Ca/ Alberta
    Grant
    #158 taz355, Mar 30, 2017
  9. schnazzy
    schnazzy Formula Junior
    Mar 31, 2008
    494
    Seattle
    So I can't find that part number 134386 on eurospares nor ricambi. What I do find is the coil for a 2.7 or 5.2 are part number 138255 on sheet "Injection Device Ignition: 007" item "010". It is $224 on Ricambi and $155 on FerrParts. Is this part the same as Bosch 00136 and Bosch 0221503407 and WPS POWER SELECT CUF306?
  10. m.stojanovic
    m.stojanovic F1 Rookie
    3,205
    Serbia - Niš
    Miroljub Stojanovic
    134386 is an Alfa Romeo part number. Bosch 0 221 503 407 is correct for Ferrari 348/355. This coil is used in many other cars (including Malaysian Proton) and is widely available at about 40-50 USD (see for example https://www.amazon.com/Bosch-0221503407-Ignition-Coil/dp/B006K8XVMK). There are also at least ten other manufacturers of coils equivalent to this Bosch number.
  11. Markphd
    Mar 10, 2012
    713
    #161 Markphd, Apr 12, 2017
    I have a set of used OEM coils that I would part with for 50% of what FerrParts want and I also have a set of aftermarket coils for $30 for the pair if you are interested. (97 5.2 car)
    PM me if you are interested in either.
    Mark
  12. m.stojanovic
    3,205
    Serbia - Niš
    Miroljub Stojanovic
    #162 m.stojanovic, Apr 15, 2017
  13. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,012
    Indio Ca/ Alberta
    Grant
  14. FCOnyx
    FCOnyx Formula Junior
    May 28, 2012
    413
    Round Rock, TX
    Jeff
    I haven't found a cheap alternative, but thought it should be clarified as many listings of the 2.7 & 5.2 TPS in this thread don't include the version for the 5.2 F1.
    The Bosch part # for this TPS that has 2 contacts is 0 280 122 005
    Only one is used in the car, right hand bank.
  15. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    456
    London
    Steve C
    #165 redwedge, Jul 23, 2017
  16. Shiva_Austria
    Shiva_Austria Karting
    Oct 7, 2013
    61
    Austria
    Does anyone know a alternative to the factory
    gas rope
    for a 95 355 GTB manual ???
  17. krazykarguy
    krazykarguy Formula Junior
    Apr 17, 2014
    732
    Fort Mill, SC
    Matt
    Looking for an alternative part # to the speedo sensor (located on the transaxle under the LH CV boot...
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,012
    Indio Ca/ Alberta
    Grant
    Just a reminder that this thread is for solutions once they are found.
    WATSON likes this.
  19. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,210
    CT
    John Kreskovsky
    F355 2.7 MAF, Ferrari part: 154916, Bosch Part number (stamped on part): 0 280 213 012, Exchange number: 0 986 280 110.
    Also Saab part, see below.
  20. The Outcast
    The Outcast Formula 3
    Apr 19, 2011
    1,562
    Royal Oak Michigan
    AIR CONDITIONING COMPRESSOR; DIRECT REPLACEMENT: Polar Bear Inc., in Florida, sells a direct replacement for the NLA F355 Sanden AC Compressor.
    Website: polarbearinc.com; Phone Number: 800-365-3516 Part Number: SO 7480F; replaces Ferrari part number 157355; Cost: $289.00
    Comes with clutch and 5-groove pulley; just bolt it and belt it.
    Hope this helps!
    GTUnit, ernie, WATSON and 1 other person like this.
  21. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Super. Thanks!
  22. johnk...
    Jun 11, 2004
    11,210
    CT
    John Kreskovsky
    Correct fitting CV joint boot:
    After searching I have found a boot that does fit and has the required "lip". It is Porsche part 92833229302 available from FCPEuro for $53.97,
    https://www.fcpeuro.com/products/porsche-cv-joint-boot-rear-left-inner-911-boxster-por-92833229302
    FCPEuro also sells an after marker version GKN Loebro 92833229302 for $3.49. which is guaranteed for life!
    https://www.fcpeuro.com/products/porsche-cv-boot-rear-92833229302-92833229303
    Also see thread https://www.ferrarichat.com/forum/posts/146562621/
  23. 05elise
    05elise Karting
    Jul 20, 2011
    211
    Sharpsburg, GA
    Dan
    If you are in need of side marker lights (rectangular USA fitted to the bumper style) they are the same as the classic '80 - '85 Fiat 124 and Pininfarina Spider and can be purchased inexpensively through classic Fiat parts vendors. The side marker lights from earlier Fiats are similar but made by Carello and not Seima so those are not an exact match.
    The side markers on the 355 have a black plastic base where the the bulb socket attaches and most of the newer Fiat side markers are the the same but some of them are entirely yellow or red. They all have the same markings and take the same bulb holders so there is no difference in the fit and only a slight difference in the color especially around the edges of the lens. The photos show two 355 equivalent rear Fiat 124 Spider side marker lights with the different color bases.
    MManzonelli and f355spider like this.
  24. Badabing!
    Badabing! Formula Junior
    Mar 30, 2014
    731
    NYC
    In my googling it seems that this is also Bosch # 69535. Rockauto shows this interchange
    Qavion likes this.
