F1 Potentiometers | Page 2 | FerrariChat
F1 Potentiometers
Discussion in '360/430' started by ideloera, May 12, 2017.
  1. F1Rossa430
    F1Rossa430 Rookie
    May 14, 2018
    1
    Akin
    #26 F1Rossa430, Aug 16, 2018
    Would you mind sending me a copy of your invoice as well? My dealer quoted me $2400 for the same. Thanks!!
    Thank you for the great write up! I am a little confused on how the actuators actually sit on the shaft but it might be more clear once i take off the old ones.
  2. 24000rpm
    24000rpm F1 Rookie
  3. SwedenPeter
    SwedenPeter Rookie
    May 9, 2013
    18
    Sweden
    Peter Dahlstrom
    Hello ! you can bye them here for 140 Euro !! https://www.sequparts.com/shop/ they also have the solenoids and the F 1 pump
  4. 24000rpm
    24000rpm F1 Rookie
    that sensor has 3 pins, while in the 360 there are 4 pins
    i asked in the tech section if some one know how to convert it, nobody answers
  5. SwedenPeter
    SwedenPeter Rookie
    May 9, 2013
    18
    Sweden
    Peter Dahlstrom
    Ok i try to find in an other place Thanks for info !
  6. SwedenPeter
    SwedenPeter Rookie
    May 9, 2013
    18
    Sweden
    Peter Dahlstrom
    Today i found an other sensor with same number for 7 Euro I order 6 of those and nex week im gonna test the original one on my car and compare it with those for 7 Euro I think that pin 4 is a doubler for the ground. Its just a potentiometer in a box !!! so I dont understand the prices on Eurospare 750 Euro !!!!!!!!!
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,081
    Central NJ
    Dominick
    Link?
    Sent from my moto x4 using Tapatalk
  8. djempire
    djempire Formula Junior
    Apr 30, 2012
    613
    Toronto
    Serf
    FWIW, I had mine replaced at a local indy for $1300CAD...all in. Including flush and re-learn.
    chenglo1 likes this.
  9. SwedenPeter
    SwedenPeter Rookie
    May 9, 2013
    18
    Sweden
    Peter Dahlstrom
    flash32 likes this.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,081
    Central NJ
    Dominick
  11. SwedenPeter
    SwedenPeter Rookie
    May 9, 2013
    18
    Sweden
    Peter Dahlstrom
    Here is the solenoids for the F 1 Pump from Japan Anyone know the price in dollar ? Image Unavailable, Please Login
  12. Flyingbrick242
    Flyingbrick242 Formula Junior
    690
    Northern AZ.
    According to my currency exchange [Japanese Yen] app this looks like $279.83..
    Looks like a good deal.
  13. 24000rpm
    24000rpm F1 Rookie
    ok, this is probably the same aftermarket sensor i bought made by a factoary about 50 miles from me. I even know the boss's daughter, local queen.
  14. 24000rpm
    24000rpm F1 Rookie
    these are under 100 US$ each sold here in china, genuine , not knockoff
  15. ideloera
    ideloera Formula Junior
    Jun 2, 2015
    525
    Chicago
    Isi
    That seems about right. I had my Indy do the work for $1,200, I purchase the part from Ricambi for about $550.
    billy.gif Formula Junior
    Mar 9, 2017
    259
    Finland
    Hejssan Peter! Did you get those things working?
  17. Ali_500
    Ali_500 Rookie
    Nov 3, 2018
    8
    I already received two of those, but the mechanic told me that they don't match, ferrari dealer told me that they are out stock from Ferrari in Italy, and were supposed to be in stock within 35th week of 2018, but still no updated info yet, also, it's out of stock from many popular auto part shops, including ricambi america.
  18. Mats Andersen
    Mats Andersen Karting
    Sep 28, 2017
    144
    Norway
    Mats Andersen
    Very useful. Thanks for sharing. Did it. It works!.
    Mats
  19. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,784
    You're welcome - glad to hear it.
  20. CarAholic
    CarAholic Formula Junior
    May 10, 2016
    519
    Anyone else complete this DIY
  21. bobby355
    bobby355 Karting
    May 21, 2009
    244
    I’d be very interested in knowing the symptoms of this problem. All i saw previously was the red transmission light coming on. Is there more to it when this potentiometer goes bad?
  22. CarAholic
    May 10, 2016
    519
    My shop said my car was throwing a code for it. Also the gear indicator will flash when cold (usually in fourth gear) and sometimes it will miss a shift and go to neutral
  23. 24000rpm
    24000rpm F1 Rookie
    due to corona virus's delay of shipments , etc, I can't put up with my car parked for 1 month or 2.
    So I've decided to do a hack job. I have one set of f430 potentiometers that has a faulty "engagement sensor" and another set that has a faulty "selection sensor"
    I am going to cut the wires and try to do it the audio guy's way, by cutting wires and grafting selection sensor from set 1 to set 2. I wonder if any one knows if the signal is sensitive enough to prevent from doing this?
  24. frankgoodson
    frankgoodson Rookie
    Dec 25, 2008
    42
    Any substitude?
  25. CarAholic
    May 10, 2016
    519
    Could anyone provide any more specifics on the installation of the sensors? Car doesn’t want to shift at all now. For the long arm does it go on the outside face or inside face of shaft. For the long arm I started 90 degree counterclockwise and and twisted clock wise for the holes to mate up. For the short arm I started 90 degree past in the clockwise direction and twisted counter clockwise for them to meet up. Clock wise is turning right with the long arm potentiometer on the left hand side.
