F1 Potentiometers | FerrariChat
F1 Potentiometers
Discussion in '360/430' started by ideloera, May 12, 2017.
  1. ideloera
    ideloera Formula Junior
    Jun 2, 2015
    525
    Chicago
    Isi
    Hi everyone,
    I took my car in for an inspection and the tech found ~12 errors related with the F1 Potentionmeters. This was at the dealer and I was quoted $1k for the part and around $2k for labor. I am planning on buying the parts online (way cheaper than at the dealer) and taking it to an independent to do the work.
    Now, does anyone here have a detail list of the parts needed for a potentionmeter replacement(aside from the potentionmeters themselves)?
    Thanks!
  2. NbyNW
    NbyNW F1 Rookie
    What's the part number?
  3. ideloera
    Jun 2, 2015
    525
    Chicago
    Isi
    248095
  4. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    #4 mike01606, May 13, 2017
    The F1 selection and engagement position sensors are Peugeot Citroen throttle position sensors.
  5. FlyingHaggisRacing
    FlyingHaggisRacing Formula 3
    Jul 2, 2013
    1,368
    You could do it yourself
    They are held on with 2 screws each.
    Put the gearbox in Neutral, before taking them off.
    As you take them off they will return to a Zero position as they are spring loaded internally.
    taking the heat sheild off and general access will probably be the worst parts.
  6. RedNeck
    RedNeck F1 Veteran
    9,979
    The CSA
    Me
    That's a DIY all day long, under $600 from Ricambi with FCA discount. Paying $3k would be ridiculous
  7. ideloera
    Jun 2, 2015
    525
    Chicago
    Isi
    Thanks guys. The dealer did say that they have to remove the actuator itself to install the potentiometers....hence the high-ish price.
    Anyone here know of any DIY instructions for this issue?
  8. RedNeck
    RedNeck F1 Veteran
    9,979
    The CSA
    Me
  9. LorenzoR
    LorenzoR F1 Rookie
    I just took the actuator off of my car last month. Not a difficult job at all. But as FLYINGHAGGISRACING said,,MAKE SURE you put the car in neutral before you take it off. Fell free to call me if needed
  10. NbyNW
    NbyNW F1 Rookie
    #10 NbyNW, May 13, 2017
    I have my undertray off and tried to get pics to help you but the rear bumper also needs to come off for access. I've had my acuature off before with no issues - it comes off in one piece. No bleeding of the system, etc. Don't remember if it needed sealant to reattach but that's easy too (looks like I did use sealant). Getting to it is the hard part. For me, I'd do it, but depends on your comfort level. A pic from mine a while ago (360CH).
  11. ideloera
    Jun 2, 2015
    525
    Chicago
    Isi
    Thank you guys for all the input!
  12. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
  13. Jgivoo
    Jgivoo Formula Junior
    432
    New Jersey
    I believe Ideloera has a F430 and the above from Juri is for a 360.
    This is great information to have.
  14. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,641
    England
    Mark
    #14 mwstewart, May 15, 2017
    Yes, 360 and F430 sensors are very different. Sadly no cheap alternative for the F430 that I am aware of.
    To install them, first remove the actuator and then unscrew the old pots from their mounting plate. Next remove three mounting screws from the mounting plate keeping the fourth installed in the corner, furthest away from the potentiometers (red arrow).
    Fit the long arm potentiometer (engagement) first starting aprox. 90 deg anti clockwise from its screws. It needs to sit on the end face of the shaft, marked with a pink arrow. Slowly twist the pot until the end is home, then keeping the pot face down to the plate, twist clockwise until the screw holes line up - there will be light spring pressure trying to twist it back the other way.
    Take the same approach for the second one (selection), making sure the flat part of the short rod will lay in the shaft groove - twist it into the groove cut out on the side of the shaft - marked green. It will mate up - they are close and it looks like the selection pot doesn't meet up, but there should be light spring pressure trying to twist it back the other way.
    F1Rossa430 likes this.
  15. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    #15 Juri, May 15, 2017
    For 430F1, those potentiometers are from Magneti Marelli (Ferrari part 248095 "POTENTIOMETERS KIT" consisting of two potentiometers) sold by Ricambi America for $650.20
    https://www.ricambiamerica.com/248095-potentiometers-kit.html
    Those cross-reference with BMW / Mini part numbers: 23427507168; 23427507169. Prices from various online parts dealers vary, but generally are less than $250/each. So, the total cost of two potentiometers (one with and another without a "hook") is less than $500. Although, those are exactly the same potentiometers, those are not sold together as a kit with a common electrical connector. Therefore, I would not even bother adapting those to save $100 or so...
    Access to those potentiometers is easy, but installation is tricky, especially of the one with the "hook", as described well by mwstewart.
  16. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    Apologies.....I should have clarified my comment was for 360 pots.....
  17. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,641
    England
    Mark
    Juri, that's useful to know, but I checked out some photos and the BMW sensors have different armatures.
  18. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    That is why I wrote "adapting" (modifying)...
  19. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,641
    England
    Mark
    Yes, the electrical connectors, which is fine, but the hooks are also different, and they are plastic welded to the pot wiper internals.
  20. ideloera
    Jun 2, 2015
    525
    Chicago
    Isi
    #20 ideloera, May 16, 2017
    Thank you for the instructions. I am going to find an independent shop that can do this. The problem is that most of the shops I have called in the Chicago area dont want to do the work unless they supply the part, which they want to charge me way more than it costs... snakes.
  21. natman316
    natman316 Formula Junior
    Jul 20, 2015
    468
    I had the potentioemter changed at the dealer for around 1k (F430)
  22. ideloera
    Jun 2, 2015
    525
    Chicago
    Isi
    1k In labor and 1k in parts?
  23. natman316
    Jul 20, 2015
    468
    Nope, total. Part #248095...if thats the same part.
    Part was 660 and labor was 400
    Reason for replacement was that my transmission error light came on from time to time. the replacement fixed it. Can send you a copy of the invoice if you want.
  24. ideloera
    Jun 2, 2015
    525
    Chicago
    Isi
    Please do!
  25. natman316
    Jul 20, 2015
    468
    PM'd u
