F1 Gear Box Failure Warning Light (2004 360) | FerrariChat
Discussion in '360/430' started by Silentnoiz, May 2, 2021.
  1. Silentnoiz
    Silentnoiz Karting
    Nov 18, 2017
    121
    Nashville
    Silent Noiz
    Yesterday, I had driven the car for about 15 minutes, gotten it up to temp, switched to Sport Mode, and drove normally for another 5 minutes.
    I approached a round-about, shifted down to 2nd, was going about 20 mph, took a right and got on the throttle pretty hard, shifted to 3rd, and when I requested a shift to 4th gear it did not shift.
    I saw that the F1 Gear Box Failure light was on. I requested up/down/neutral shifts, but it would not respond.
    I pulled off into a neighborhood, found a spot where a flatbed could easily pick me up, slowed to a stop (it did not down shift automatically), and the car died (as expected).
    I restarted the car, and everything was back to normal. No other issues for the rest of the day (no strange shifting, no warning lights) on ~25 miles of back road driving and also in stop and go traffic.
    Any thoughts of why this happened, and what I should do? I'm not a mechanic, so I would go to my indy for any diagnostics/service.
    I searched the forums, but didn't find anything similar.
    TIA!
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    You need to find a code scanner and read the error code. That will give you a clue as to what is happening.
    EastMemphis and flash32 like this.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,691
    Central NJ
    Dominick
    +1
  4. Silentnoiz
    Silentnoiz Karting
    Nov 18, 2017
    121
    Nashville
    Silent Noiz
    What type of scanner would I need to read these codes? I think an ODBII reads CEL's, but not F1 Gear Box issues? So would I need an SD2/3? What are the best options for the functionality and price?
  5. yelcab
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    According to @WATSON , the Leonardo tool for your one model is $4500. A couple of us on this board have the much less expensive X431 Launch version. Leonardo probably has better Tech Support. There is none for the X431 Launch, but it does work.
  6. WATSON
    21,726
    WI
    So why the $30,000 crappy post?
    Please explain.
  7. yelcab
    Nov 29, 2001
    12,662
    San Carlos, CA
    Mitchell Le
    The Laucnh does not work on the 355F1, period.
    The $4500 is your data point, and I still consider it too expensive.
  8. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,314
    South East
    Jimmie
    OK here's another thought for OP: the reversing lever has maybe lost its locating pins so it slipped a little and caused the light - if the movement is not positive it needs the Hill replacement lever from Ricambi
    Silentnoiz likes this.
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Have a look at downloading OUTILS OBD FACILE. from france, this is an obd program you can use with a laptop , phone or i pad. It reads a 430 gearbox and picks up both engine ecu.
    Ask them if it works on a 360. Be sure to order the right program, ie an i pad is the easy one to use. You will need a bluetooth adaptor to plug into the obd socket but get from amazon as same for a lot less. They have a basic and a ultra program which u need
  10. kes7u
    kes7u Formula 3
    1,148
    Shorewood, MN
    Kevin
    Please note that the Launch device and other downloadable software only interrogates the newest 360 TCU, or the CS TCU.
    Kevin
