Exhaust and warranty | FerrariChat
Discussion in 'Technical Q&A' started by ait_z28, Feb 8, 2020.
  1. ait_z28
    ait_z28 Rookie
    Jul 17, 2017
    23
    Hello,
    Ferrari dealer warned against installing an after market exhaust to the F12 as it will void the warranty. Will it be known to the dealer if I were to install and uninstall the exhaust every time I service the car?
    Tips welcome.
    x z8 likes this.
  2. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    Do you live it the USA, if so they cannot just void your warranty. If the exhaust caused something to go wrong with the car, they could (at their discretion) not fix that issue under warranty.
  3. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,214
    CT
    John Kreskovsky
    Not a question I'd be relying of Ferrari Chat for an answer.
  4. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    If you are in the USA you need a new dealer.
  5. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    916
    Georgia
    Mark Gronsbell
    Ferrari and most manufactures have the right to void a warranty on any item that may be affected by a modification that changes the performance of their car. When modifying, it is always buyer beware.
  6. MotoMeccanica
    MotoMeccanica Formula Junior
    450
    Canada
    It will not void your warranty. BUT if something happens as a result of said part installed, the repair will not be covered under warranty
  7. MotoMeccanica
    450
    Canada
    As Carnut said in the 2nd post
  8. ait_z28
    ait_z28 Rookie
    Jul 17, 2017
    23
    Don't live in the USA.
    My question is on the technical side of things:
    Will installing an after market exhaust then uninstalling and putting back the factory original be detected with a check (ECU/Physical check.. etc)?
    x z8 likes this.
  9. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    No, it should not be detectable, but that is a lot to go through each time the car goes to the dealer. I would invest in a very good scanner so you can clear any codes yourself.
