ECU Connector removal | FerrariChat
Discussion in 'Boxers/TR/M' started by curtisc63, Dec 6, 2019.
  1. curtisc63
    curtisc63 Formula 3
    Dec 13, 2005
    2,290
    Maryland
    Curtis Campbell
    OK, this is a very basic question, but - how do you remove the ECU connectors (25 pin under right quarter panel)?
    With parts hard to find and old plastic getting brittle, I do not want to break them. I see a small phillips screw on the front of them that I have removed. And I see an arrow pointing forward. But when I play with them trying to pull them off I see no movement. Push forward and pull out? Any other screws or pins to push/pull etc?
    Thanks for the help!
  2. curtisc63
    curtisc63 Formula 3
    Dec 13, 2005
    2,290
    Maryland
    Curtis Campbell
  3. Rifledriver
    37,010
    There is a spring clip holding them in place at the rear end. Flex back and lever out until front end comes free.
  4. curtisc63
    curtisc63 Formula 3
    Dec 13, 2005
    2,290
    Maryland
    Curtis Campbell
    Thank you Mr. Crall!
  5. curtisc63
    curtisc63 Formula 3
    Dec 13, 2005
    2,290
    Maryland
    Curtis Campbell
    That was the bit I needed. Worked like a charm!
