Dust Seal Source? | FerrariChat
Dust Seal Source?
Discussion in '365 GT4 2+2/400/412' started by D.J, Jan 27, 2021.
  1. D.J
    D.J Karting
    Mar 17, 2015
    103
    Perth WA
    Hi,
    has anyone got a source or alternative for #26 110150 dust seal as per drawing? The few suppliers I have found want huge money for them, as a dust seal would a non pressure single lip oil seal would suit?
  2. Tojo
    Tojo Formula Junior
    Apr 12, 2002
    481
    Tim
    I had a similar experience. Ended up getting them from GT Carpets in Phoenix. Still around $80usd at a rough guess
    Sent from my SM-G935F using FerrariChat.com mobile app
  3. Steve Magnusson
    25,156
    110150 is a Forsheda V-ring seal -- try a search on "Forsheda" or "110150" for prior threads and some pictures. It's the kind of thing that a good bearing supplier might be able to get, but they often don't do small retail sales (and you'd need to know the size).
  4. D.J
    D.J Karting
    Mar 17, 2015
    103
    Perth WA
    Hi Steve, thanks for your reply, these are not standard V-Rings as they are designed to be shaft mounted where this is bonded to a metal case and is housing mounted. I am starting to look at Gamma (axial face) seals to try to track them down.
  5. Steve Magnusson
    25,156
    Yes, I'm now recalling that on your model it is a (custom?) bonded assembly (as was discussed in the prior threads); whereas, on TR it is not (and is just a standard V-ring). Good luck with the search.
    D.J likes this.
