DIY Maintenance 458 thread. | Page 5 | FerrariChat
Discussion in '458 Italia/488/F8' started by Melvok, Feb 25, 2019.
  1. up4speed
    up4speed F1 Rookie
    3,544
    Long Island, NY
    Chris
    Did you remove both side panels in the engine compartment? If not, do you think that would help?
    Melvok likes this.
  2. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,647
    Milwaukee, WI
    Ferrarifobs.com
    Yes both side panels were removed.
    Melvok likes this.
  3. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,117
    Mel
  4. Melvok
    Jul 25, 2008
    14,117
    Mel
    I only do NOT recommend his sort of car battery, an AGM will do the job fine imo, like the oem version.
    Metalguru and alibo70 like this.
  5. Melvok
    Jul 25, 2008
    14,117
    Mel
  6. Melvok
    Jul 25, 2008
    14,117
    Mel
    Y E S !!
    Removed it … quite simple IF you have a device that goes deeper in (any) ECU.
    And my friend seems to have such a device … watch the Dreaded Green Wrench is GONE now …
    He explaned that in some (IT) cars there seems to be a clock installed that counts back 365 days and then gives a sign.
    He simply typed in 00 (zero - zero) days till next service … and it vanished.
    So cheap OBDII software (like ELM etc) will never do the trick.
    HAPPY ! … YES !
    Baitschev and AlfistaPortoghese like this.
  7. Melvok
    Jul 25, 2008
    14,117
    Mel
    #107 Melvok, Apr 21, 2020
    Brand seems to be TEXA IDC …..
    Under "Niveau" we see the ZERO km …
    And under "UIT"... 0 dagen = 0 days to following service ...kms
    AlfistaPortoghese likes this.
  8. gobble
    gobble Formula 3
    Jan 29, 2010
    1,647
    Milwaukee, WI
    Ferrarifobs.com
    Do you know if the Launch tool will also eliminate this?
    Melvok likes this.
  9. DoubleD33
    DoubleD33 F1 Rookie
    2,757
    Pasadena, CA / Oahu, HI
    Dan D
    I will chime in on this. I purchased a Launch X431 I car Scan about 3 years ago to use on my Porsche. I paid around 250 bucks. It is an orange rectangle with Bluetooth that plugs into the obd 2 port.
    There is an App and it works on iPhone. It has the functionality to clear the green wrench. It also has special test and live data for a lot of systems. It reads transmission and even will read and clear air bag codes. (I turned the key on with a bag unplugged and needed to clear the code).
    I was going to buy a launch tablet version for the F car and on a whim I tried this one right before i purchased one and I was surprised.
    Viper830tt and Melvok like this.
  10. Frank_N
    Frank_N Rookie
    Apr 20, 2020
    13
    Frank
    Which one from Launch? Can you send a link? I need to use it on a California
  11. DoubleD33
    DoubleD33 F1 Rookie
    2,757
    Dan D
    For reference this is what I got. Mine came from amazon but I see it is no longer available from them. Search around as I see them still for sale other places. As I remember the software download comes from an app that you install. It has worked well for me over the past 3 years.
  12. Frank_N
    Frank_N Rookie
    Apr 20, 2020
    13
    Frank
    Thanks a lot! Could you check if you see also the California in the model list? I would really appreciate it!
    Thanks again
  13. DoubleD33
    DoubleD33 F1 Rookie
    2,757
    Dan D
    California is an option on my menu
  14. Frank_N
    Frank_N Rookie
    Apr 20, 2020
    13
    Frank
    Gonna buy it right now! Thanks!
    I am having some weird issues on the Cali, sometimes it is limited to 3500/3800 RPMs, no lights then if i turn off the car and then ignite again the limitation disappear... anyone knows what could be?
    Thank you!
  15. AlfistaPortoghese
    AlfistaPortoghese Moderator
    Mar 18, 2014
    3,778
    Europe, but not by much.
    Nuno
    Which OBD-II and software have you guys been using on your 458s?
    Kind regards,
    Nuno.
  16. DoubleD33
    DoubleD33 F1 Rookie
    2,757
    Dan D
    the software for the one above is an app called EZ Diag.
  17. AlfistaPortoghese
    Mar 18, 2014
    3,778
    Nuno
    Thread added to the 458 master sticky thread.
    Kind regards,
    Nuno.
  18. action-ant
    action-ant Karting
    Nov 16, 2015
    176
    San Francisco, CA
    Anthony
    Hi guys,
    After buying two OBD devices and having no luck, can someone confirm that the Launch X431 iCarScan worked for clearing the service light on their 458?
    Thank you for any help,
    Ant
  19. DoubleD33
    DoubleD33 F1 Rookie
    2,757
    Dan D
    The one I posted above cleared the green wrench. I did not follow through and see if it went to a blank date or reset it for a year.
  20. hgoodwiniii
    hgoodwiniii Karting
    231
    HI DoubleD33, do you know if this one activates the ABS valve for brake fluid flushing/bleeding? Thanks.
  21. DoubleD33
    DoubleD33 F1 Rookie
    2,757
    Dan D
    I have not used it but is has the option on the menu.
  22. hgoodwiniii
    hgoodwiniii Karting
    231
    That's good to know; There's quite a bit of interest in that here on the forum. Thanks.
  23. Melvok
    Jul 25, 2008
    14,117
    Mel
    DO let us know about THAT in return for the info you found here please Dan !
    Is will also be handy when we want to exchange our brakepads.
  24. Melvok
    Jul 25, 2008
    14,117
    Mel
    Brakepads ..
    Who is able to make a DIY write-up here for renewal of front pads please ?
    I may have to do that soon, I have the pads already in the front trunk in case the light will show that it is time :)
    And tell what tools were needed, f.i. how to get the brake cilinders back ...or just open the bleedingscrew ?
  25. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,646
    Silicon Valley
    Did this last year on rears before a track day as they were looking too thin to last safely. Pretty easy. Aside from usual safety procedures in jacking up car and removing wheels, the pad process just involves driving out the pins with a suitable diameter brass punch. This releases the springs on top of the pads. Remove them and the wear sensor.
    Spread pads carefully so they’re loose, and pull them up and out. No need to remove the calipers. Don’t open the bleed screw unless you want to bleed the brakes. Be sure the brake reservoir cap is open and you have removed some fluid before the next step so it doesn’t gush over and make a mess. But don’t remove so much you uncover the bottom of the reservoir or you will introduce air into the system.
    Once old pads are out, just use a piston spreader to retract them. I used this Girodisc tool because it’s easy (but expensive). Pop the new pads in, the springs, sensor, and carefully line up and drive the pins back in. You will feel them seat by the change in feel and tone of tapping them back in.
    Throughout, be careful not to nick the rotors! As with any other safety item, if you’re not sure you can do this, get expert help or have it done by a pro.
    https://www.************/Caliper-piston-spreader_p_5970.html
    SVCalifornia likes this.
