Define a "mid engine car" for me... | FerrariChat
Discussion in 'General Automotive Discussion' started by 11506apollo, Oct 6, 2019.
  1. 11506apollo
    11506apollo F1 Rookie
    2,698
    Tx Co Ca
    It is puzzling to me that a so called "mid engine car" is one with the engine/block forward of the rear axle.....
    .....however, if the engine/block is behind the front axle.....its not a "mid engine car"?
    Try and explain that to me if you can....
  2. GuyIncognito
    99,717
    I hear a lot of manufacturers refer to "front mid engined" for an engine behind the front axle.
  3. Nativetroy
    Nativetroy F1 Veteran
    5,988
    central fl
    Troy
    I consider a true mid engine car to be one where the engine is behind the driver and before the rear axle. Front engine would be over or in front of the rear axle. Rear the opposite. Some cars do have front engines that are behind the front axle. Corvette. 370z, I think the SLR was like this. I think Nissan coined the front/mid term.
    paulchua and carguyjohn350 like this.
  4. 11506apollo
    2,698
    Tx Co Ca
    My technical mind would be much happier if the world adopted Rear mid engine and front mid engine, just for the sake of accuracy and proper geometry
  5. technom3
    technom3 F1 World Champ
    18,511
    Phoenix AZ
    Justin
    You are asking the general public to define a term that is in "general use"
    Fee people ask for anything other than a Kleenex and when people want a cola. They typically ask for a coke...
    Yes a mid engine car is anything between the axles.
    Don't expect the public to follow. especially now that the whole internal combustion engine thing is in its twilight
    BOKE likes this.
  6. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,673
    Pittsburgh, PA
    Matt F
    So...
    Does a front mid-engined car need to be front wheel drive transverse engine?
    If not, there are very few front-engined cars...
    Matt
  7. Tcar
    Tcar F1 Rookie
    NO. Of course not.
    Rear mids don't have to have transverse engines, do they????
  8. Smiles
    Nov 20, 2003
    16,673
    Pittsburgh, PA
    Matt F
    So this would be a mid front engined car?
    GuyIncognito likes this.
  9. Tcar
    Tcar F1 Rookie
    Yes. The engine is behind the front axle on the Bug.
  10. technom3
    18,511
    Phoenix AZ
    Justin
    And also on the Vette and even Camaros for years.
  11. dwhite
    dwhite F1 Rookie
    My 69 TVR was front mid engine and had 50/50 weight ditribution and was 150lbs heavier on the right side to compensate for the driver, all from the factory. Only car which had a higher skidpad g-force in the stats at the back of R&T was a Dino at like .85gs.
    Mid engine is when the engine resides in the chassis completely behind the front axel and completely forward of the rear axel.
