DE 458 Challenge | FerrariChat
DE 458 Challenge
Discussion in 'Challenge/GT Cars/Track' started by 400exr1, Apr 3, 2021.
  1. 400exr1
    400exr1 Rookie
    Apr 3, 2021
    1
    Dallas, Texas
    Blake
    All,
    Picked up a 458 challenge that I plan to run here in the Dallas area. Would love to connect with anyone with experience running the 458 for track days. I don't plan on using regular trackside support. Probably do a couple of days of trackside setup. Converting to fuel pump fuel fill, steel rotors, running stickers for now. Any guidance is appreciated!
    danielinCO2 likes this.
  2. naparsei
    naparsei Formula Junior
    Oct 11, 2005
    299
    Land of Enchantment
    Alex
    Following. Just starting this process myself, but not in TX. Car is in NV. I am sticking with the dry break, already converted to steel rotors.
    ewright likes this.
  3. FCD
    FCD Karting
    Nov 27, 2011
    170
    Germany
    In the Ferrari Club Germany Racing series, the vehicles are allowed to drive with steel brakes. We have several 458 and 488 Challenge driving the brakes from TM Performens and are very satisfied!
    https://tmperformanceusa.com/product/ferrari-458-brake-rotors-and-pads-full-set/
    ewright likes this.
  4. CarbonDan
    CarbonDan Karting
    191
    PNW
    Subscribing to this as well, I'm planning on taking a similar plunge myself.
    Has anyone considered running Hoosier R7s with softer springs, simply for the increased number of usable heat cycles?
  5. windsock
    windsock Formula 3
    1,149
    Hoosiers and the Michelins require a substantially different set up then the Pirelli simply installing softer springs will not work. The Michelins and the Hoosiers require about half the camber the Pirelli runs or you will have catastrophic tire failure.
    CarbonDan likes this.
  6. CarbonDan
    CarbonDan Karting
    191
    PNW
    Absolutely, I didn't mean to minimize the extent of adjustment required. But is it safe to say that Hoosier R7s can be fitted to the car, assuming proper setup changes conducted by an experienced race team/tech, and acheive reasonable performance and results, with the understanding that it will be substantially slower than the OE slicks?
    This is what I have difficulty getting to the bottom of with these factory race car options (Be it 458 challenge, gt3 cup, gt4 clubsport, supertrofeo, etc):
    Assuming proper (and potentially complicated) suspension and alignment adjustments, can these factory race cars be run with Hoosier R7s with solid feel, response, and impeccable safety characteristics, or is there something about these factory race car setups generally that make running hoosiers a bad idea no matter how you slice it?
    Assuming I'm willing to give up overall performance.
    I currently track a 2018 GT3 and a 2017 viper ACR Extreme with v720 tires. I want to continue tracking heavily, but also feel I need to take the next step up in terms of safety. In my mind it seems difficult to beat the safety of one of these factory race cars with the proper cage, fire suppression, isolated fuel cell, nets, etc etc etc. My goal is to have a safe car to track at DE events, while keeping consumable cost down (accepting overall speed will be decreased as well), while also accepting that a ferrari race car is never going to be an economical propositon (and I'm ok with that).
  7. windsock
    windsock Formula 3
    1,149
    With a proper set up you should get 4-5 good days form a set of Pirelli tires at the ridge. I can connect you to several drivers that currently run the ridge.
    Put some steel brakes and the Rabestos ST43 pad on it and your running costs are not going to be much different then any dedicated track/racecar that is comparable in lap times.
  8. CarbonDan
    CarbonDan Karting
    191
    PNW
    That's about the greatest news I've heard yet! 4 usable days out of a set of tires is enough lifespan for me to scratch the entire hoosier work-around. That's about what I get from my other tires already anyways.
    I run the girosteel rotors and ST43 pads on my Viper ACR-E and they are sensational.
  9. windsock
    windsock Formula 3
    1,149
    I would recommend the same brakes on the Challenge car.
  10. jr-f12-15
    jr-f12-15 Karting
    72
    Tomball, TX
    John Refalo
    Following. Also running a 458 Challenge for track days. Does anyone have any experience getting the data aquisition system to download?
