360 - Data logging systems for track setup | FerrariChat
360 Data logging systems for track setup
Discussion in '360/430' started by billboboy, Feb 2, 2020.
  1. billboboy
    billboboy Formula Junior
    Aug 15, 2015
    341
    San Jose, CA
    Will L
    I am currently researching the best way to get some basic data logging into my '02 360 Modena for track days. The basic data I'd like to prioritize:
    throttle position, brake pressure, steering angle, wheel speed
    I found this thread: https://www.ferrarichat.com/forum/threads/mobile-obd-scanner-logger-iphone-android-360-430.467996/page-2
    According to RaceLogic you can't get any useful data off the ODB2 (ODBii) port, and prefer to hard-wire into the CAN bus. Anyone found otherwise for track data logging? http://www.racelogic.co.uk/_downloads/vbox/Vehicles/Other/Docs/Ferrari-360.pdf
    It looks like the way to accomplish what I need is to get a dedicated data logging system and all of the sensors wired in independently from the vehicle's CAN bus system.
    Anyone had any luck with an AiM Solo2 DL or the like in their 360?
    AiM options:
    EVO5 data logger: https://www.aimshop.com/collections/racing-data-loggers/products/aim-evo-5-car-racing-data-logger
    EVO4 data logger: https://www.aimshop.com/collections/racing-data-loggers/products/aim-evo4s-car-racing-datalogger
    Throttle position: https://www.aimshop.com/collections/car-racing-sensors/products/aim-throttle-rotative-pot-and-cable
    Brake pressure: https://www.aimshop.com/collections/car-racing-sensors/products/aim-brake-pressure-sensor-m10
    Steering angle: https://www.aimshop.com/collections/car-racing-sensors/products/aim-steering-angle-10-revolutions-with-bracket
    Wheel RPM and throttle are supposedly available on the CAN bus but would have to be spliced in.
  2. brogenville
    brogenville Formula 3
    2,250
    Robin
    360Trev might have something for you here... I understand he found a backdoor that Bosch left in the engine ECU firmware that allows you to monitor all engine parameters in real time at an exceptionally high data rate.
  3. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    Thanks for the heads up Robin.
    OK, first and foremost, most data logger manufacturers know very little about specific cars. They simply don't do enough research and development. Probably work involved doesn't justify their costs.
    There is absolutely tonnes of data you can pull back in realtime from these ecus if you know how. And by the way you don't need to buy tonnes of kit either... [emoji12]
    Pm me for more information. Just on a phone right now but when I get in later I will elaborate further. [emoji106]
    MCASEY likes this.
  4. mfreed
    mfreed Rookie
    Jan 23, 2019
    2
    Mason Freed
    360trev, is there anything you can post publicly here? I have the same question - I'd love an easy way to log basic data from my '04 360. I have a logging solution using OBD2 but the update rate is awful. I'd love a (cheap!) way to log from the CAN bus or other direct connection.
    billboboy likes this.
  5. brookliner7
    brookliner7 Formula Junior
    838
    San Antonio, TX
    Hans
  6. billboboy
    Aug 15, 2015
    341
    San Jose, CA
    Will L
    No updates on my end. I added a fairly inexpensive ODBII Bluetooth and use my Blackvue dash camera. I want to look into this a lot more as the season progresses.
    I plan to ‘get’ an AiM Solo2 from Santa for Christmas to go with my GoPro Hero7 Black. Still not ideal for the type of data I’d like to be getting from the car but it’s a start.
