Cometic Head Gaskets for 308 ? | FerrariChat
Discussion in '308/328' started by jdjagguy, Jul 7, 2020.
  1. jdjagguy
    jdjagguy Karting
    Sep 11, 2007
    67
    Enid Oklahoma
    Richard Crump
    Has anyone tried the Cometic head gaskets for a a 308/328? I have had good results with these gaskets on other cars and have been trying to make sense out of the information posted on this site about current production Elring gaskets and on the gaskets such as those offered by Superformance and others.
    Appreciate your comments
    Richard
    Euro, 308 QV
  2. derekw
    derekw Formula 3
    1,520
    London, UK
    Derek W
    There is a lot of movement with these blocks and I decided to change my order at the last minute after advice that you should really ensure very flat surfaces for the MLS gaskets like Cometic. I used some extra high temperature RTV on the water passages on the Elring gaskets and have been advised by a few people to re-torque the head nuts after a few hundred miles.
  3. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    There are exceptional threads on this topic of head gasket. Very complex subject with one major issue that being cylinder protrusion above deck height and compress ability of the gasket.
  4. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,541
    Cerritos, CA.
  5. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #5 Crowndog, Jul 7, 2020
    Hinecker did the thread “correct 328 head torque “ has the best headgasket discussion. Starting discussion around remark#40-45
  6. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    See above post!
  7. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,527
    California SF bay area
    Paul
    I was told you can’t use MLS gasket because of liner protrusion, you’d have to modify the block.
  8. Hinecker
    Hinecker Formula Junior
    Mar 14, 2011
    379
    Hello all,
    I put my engine back together using Elring gaskets from Superformance. Reason behind this was that none of the feedbacks I got about different materials and manufacturers were not consistent enough to convince me.
    Martin from Germany did a extensive research on these gaskets and date of manufacture. It all pointed out that these gaskets were fabricated in Germany, not in Spain as many people assure using "junk".
    I also had an issue with the tightening of the head nuts... Some manuals recommend angle torque others recommend 10 Kg/m.
    Finally I opted for Elring gaskets and 10 Kg/m torque. Did a hydraulic test and started the engine. 500 miles later, engine starts right up, idles ok, does nor overheat and sounds great.
    Temp goes up to 195 F and the fans kick in. I did notice that the header tank cap overflowed a couple of times. Replaced it with the 1.1 Bar instead of the 0.9 Bar, problem seems to be cured.
    Another thing I did was before initial start up, I filled the header tank completely, bleeding the air out of radiator and thermostat housing while maintaining the header tank full. Connected a hose from the overflow of the header tank to a jug with coolant, so as I drove, the possible remaining air in the circuit could be expelled out and coolant would be absorbed back into the engine when it cooled down (copied this from my VW Minibus).
    So far so good.
    Hope this helps.
    John.
  9. Hinecker
    Mar 14, 2011
    379
    Richard,
    One last hint, my head gasket problem came from warped heads and block. Had to shave 0.15 on heads and block. Head gaskets don't start leaking (compression/water) all of a sudden. Generally it's a consequence of something else.
    I have pictures of the whole process, if you're interested.
    John.
  10. JCR
    JCR F1 World Champ
    10,019
    H-Town, Tejas
