Clear Bra and Ceramic Coating Compatability? | FerrariChat
Discussion in 'Detailing & Showroom' started by ncjetskier, Sep 25, 2019.
  1. ncjetskier
    ncjetskier Formula 3
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    I purchased a car wrapped in clear bra (I have no idea what kind). I did a search and there were numerous posts about either waxing or putting Ceramic Coating on the clear bra to protect the clear bra.
    My question is "has there been any studies on how the ceramic coating chemically reacts to the clear bra - either in a good way or bad"? Clear bra (chemically) is much different than paint.
  2. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,238
    I do not know of any studies. I know from experience that if you clear bra a car and ceramic coat it that it will always look amazing and you'll drive it in the rain and not care one bit. i highly recommend it.
  3. George Vosburgh
    George Vosburgh F1 Rookie
    At worst you would ceramic coat up to the clear bra but not over it.
  4. ttforcefed
    ttforcefed F1 World Champ
    19,241
    dont ceramic the paint....ceramic over the ppf
    obbob likes this.
  5. ncjetskier
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    I intent do ceramic coat over the clear bra, but my concern is how the coating reacts with the clear bra over time. Will it brittle -tize the clear bra, will it make yellow over time. So my question is, does anybody know how a ceramic coating chemically reacts with clear bra vs. paint?
  6. ttforcefed
    19,241
    To me the answer is pretty simple… Ceramic needs to be wet sanded to get it off the paint… Put the ceramic on the plastic and don’t risk it
  7. MobileJay
    MobileJay Formula 3
    Sep 9, 2006
    1,441
    Houston
    Jason Cavallo
    Not all ceramics need to be sanded off. I’ve removed them from paint with compounding.
    To the OP, I don’t know the chemistry behind it but depending on what brand of film and coating you go with, I’ve seen coatings last years on ppf with no I’ll effects.
  8. Jkuz
    Jkuz Karting
    182
    Carlsbad, CA
    John K
    I have XPEL clear bra on the front spoiler of my 308 and was just looking up the ceramic coating the installer recommended. They make one (XPEL.com) that is made to go over their clear bra, and maybe others? I haven't tried yet, but it seems like this would be a good bet.
  9. MobileJay
    MobileJay Formula 3
    Sep 9, 2006
    1,441
    Houston
    Jason Cavallo
  10. Bmill
    Bmill Karting
    193
    California/Minnesota
    Brad
    I have ceramic coating on all my F cars. Works great if you think it through and be carful about a installer selling only what he has access to.
    Here is the stress point. If you want to remove a ceramic coating you need to polish it off. Coatings last 1 to 3 years in the real world not the marketing world. Polishing PPF is a high risk task. You can try re coating but that can also be problematic after a few years due to chemist.
    I use car pro cquartz skin. One of the very, maybe only product designed to go over PPF. It can be chemically removed, no polishing needed. Now the trade off is a bit shorter life. But looks great.
    Just food for thought.
  11. ttforcefed
    19,241
    how is polishing ppf high risk - way easier to polish that than paint. and ppf needs to be replaced every few years anyway. burning paint is bad. burning ppf (if even possible) is a whatever, just replace it.
    BOKE likes this.
  12. Bmill
    Bmill Karting
    193
    Brad
    I don’t know I just hear that on a number of detail forums. I understand you might have a different view or information than me. That happens often too me!
    I know of only one polish designed for PPF, but I’m sure more will be coming.
    I thought good PPF’s on the market now last 5+ year. With ceramic coatings in real life lasting 1-3. I only have a year on my expel PPF, so no views. But my M5 with 3M made it 6 years or so. But I have never had a ceramic coating go much more than 2 years based upon my gloss meter and beading test.
    My guess would be compounds and polishes are designed but their manufacturers either for clear coat paint or single stage paint that is applied to a hard surface such as metal or CF.
    PPF is a plastic and depending on the manufacturer having different hardness and stretchable (like self healing)
    Using my logic, which may be wrong, it seem like polishes designed for one type of materials might not work best for a second type.. Such as using a metal polish on glass would not be my personal first choice.
    But like I said, just what I have read, and my version of logic... which my wife says is questionable many times !
    Thoughts?
    Solid State likes this.
  13. Solid State
    Solid State F1 World Champ
    10,529
    Maximus Decimus Meridius
    My detail guy says you can't polish PPF nearly as aggressive as paint and you need to be more aggressive to polish ceramic so I agree with your logic. I had my PPF replaced after 6 years and held my breath that the paint did not pull. Considered it very lucky it did not. Hated putting it back on but need the protection. You raise a good point about ceramic over self healing film which is why I chose not to. It won't last as long as the film and you can't really take it off. I do wonder the impact of hard glass coatings on the stretchy self-healing qualities of the better PPFs. Would need a chemist to answer I suppose.
    MobileJay likes this.
  14. ttforcefed
    19,241
    Theres no reason to ever polish ppf. It shld last as long as the ceramic
    BOKE likes this.
  15. MobileJay
    MobileJay Formula 3
    Sep 9, 2006
    1,441
    Houston
    Jason Cavallo
    I’ve tested the self healing ppf when coated with a ceramic and it didn’t have any I’ll effects to the seals healing.
  16. Solid State
    10,529
    No one else has ever reported issues either but to me it doesn't make sense. A hard glass coating shouldn't allow the plastic to reseal dents or scratches but hated chemistry. :)
  17. MobileJay
    MobileJay Formula 3
    Sep 9, 2006
    1,441
    Houston
    Jason Cavallo
    Haha same here. I don’t understand it that’s why I just go for things I can see and not try to understand the chemistry behind it.
