CD Ignition and its Superiority in Overcoming Shunt Resistances | FerrariChat
Discussion in '206/246' started by Fred Winterburn, Dec 6, 2018.
  1. Fred Winterburn
    Fred Winterburn Karting
    Jan 27, 2015
    75
    Folks, I posted this on a Porsche forum recently and was lambasted for spelling and grammar without much technical feedback which I found surprising. I've cleaned it up a little so it should be more readable. Anyway, I had an impromptu experiment that solved many a paradox when it comes to ignition systems and in particular the superiority of CDI in overcoming spark plug fouling. This has not been published by anyone before to my knowledge, but finally explains the real reason why CDI is superior in overcoming a shunt resistance compared to even high energy inductive ignitions. I hope you enjoy reading the attached PDF. Fred
  2. Bluebottle
    Bluebottle F1 Veteran
    8,519
    Newbury, Berkshire, England
    I am sure I would have enjoyed reading it if I could understand it, but, alas, it is way over my head, but that is my fault:(
    It seems a shame that, when you have obviously gone to a lot of trouble to share your expertise, you get a load of s**t for spelling and grammar, instead of the thanks that you deserve. Sharing knowledge like this is what these forums should be all about and I hope it will not deter you from doing so in the future.
    All the best.
    Skippr1999 and racerboy9 like this.
  3. DinoLasse
    DinoLasse Formula Junior
    606
    Sweden
    Lars
    Fred, it is not an easy read, but I did enjoy it.
    The concept of inductive and capacitive loads with lagging vs. leading currents is not easy or intuitive to grasp for those casually interested in electronics. Electrical engineers get it but hardly anyone else does. That is probably why you have not had any comments on the technical aspects.
    Your reasoning sounds correct, though, and you are making a good point. A CDI and an inductive system may put out voltage pulses of similar rise times, but they will behave very differently when encountering a capacitive load (spark gap) in parallell with a resistive one (fouled plug). The CDI system with its leading current should in fact fire the spark gap before it has time to cut tracks through the more resistive carbon deposits. The inductive system with its lagging current may or may not, depending on how bad the fouling is.
    The theory is certainly correct. How all this plays out in an engine under real conditions may not be as clear or obvious, but is certainly seems to give an extra feather in the cap for the CDI system.
    Thanks for sharing you observations and theories. Most interesting. / Lars
  4. Fred Winterburn
    Jan 27, 2015
    75
    lars,
    Thanks for that. I now have two EEs that believe my theory is correct. Another fellow that repairs CDIs in California was certain it was fast voltage rise time until I sent him the short article, but realized he had been fooled too, and he has been doing this for a great many years. I have read hundreds of articles including several SAE papers, including articles by Bosch, and none of them attribute the ability to overcome fouling to anything but fast voltage rise times. The exception is an article by a Mr Holden, but although he didn't believe it was fast voltage rise times per se, he assumed that inductive ignition was just as good because the rise times are similar. The reason he drew the wrong conclusion in his article is that he did not complicate his experiment by having a spark gap in parallel with resistances. (I know this through correspondence with him 3 years ago) Instead, he simply loaded the secondary of a coil with various resistances and called them 'shunt resistances', when they weren't actually shunting anything. So he drew the wrong conclusion. I have included his article here for reference. It does show how even the most brilliant can be fooled.
    Even my father, who was a real electronics expert, from radio, to radar, to power electronics, never once mentioned anything other than fast voltage rise in any of his CDI notes. He did mention inductive lag, but that was only referring to the ability of CDI to work well at high rpm while the Kettering system does not. He was not an EE, but was building radios when he was 8 years old and teaching electronics in the RCAF at age 21. Not bad for a high school dropout. I'm not an EE either, and quite frankly I wouldn't have made the power factor connection if I hadn't spent several years in the control room of a nuclear power plant. Fred
  5. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    very interesting Fred, thank you.
    Don't understand it though but get the general idea, however any benefits if you don't get spark plug fouling, lets face it SPF is a symptom of a poorly set up or high mileage knackered engine so does it improve it.?
  6. Fred Winterburn
    Jan 27, 2015
    75
    Tony, It will help with any type of shunt resistance not just plug fouling such as moisture on spark plug insulators or wires. Any time there is a misfire that finds a track to ground is not only lost combustion, but also begets more misfires as the tracking gets worse and components need to be changed out more often to restore performance. So yes, it does improve things even if the plugs aren't prone to fouling, and that doesn't take into account any other advantage of CDI. Fred
  7. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Thanks Fred, always welcome your technical knowledge.
    I was always under the impression that with fouled plugs the spark has to go somewhere and that it will find the weakest part in the HT system, with good condition spark gaps / clean electrodes etc the earth track has less resistance so it will naturally follow the easiest path and basically bypass (up to a point) any deficiency in the HT wires.
    What type of HT leads do you recommend? Also I use the NGK BP7ES in my 246 and they work perfectly, if I substitute with the iridium plug I get fouling!
    I use the standard distributor with the Superformance S4 ignition module (changed from the useless Black Stallion module) which I fitted into the old dinoplex box. Hot and cold starting is fine and runs good to 7000pm on the dyno.
    does your new discovery alter the unit you sell?
    Kind Regards
    Tony
  8. Fred Winterburn
    Jan 27, 2015
    75
    Tony,
    Yes, with fouled spark plugs, if the energy doesn't go through the spark gap it will go through the fouling deposits instead. That won't hurt insulation, but it surely won't help ignite fuel either. Wet insulation on the other hand, or poor insulation that provides a shunt resistance will damage insulation while at the same time preventing ignition in the cylinder. And then eventually the plugs foul too from successive misfires.
    The ignition energy doesn't always have to find its way to ground on a misfire. It can be contained within the system and dissipate as heat rather than punching through insulation, but with an inductive system, or a very high voltage CDI (which is why too much voltage is bad) that is more likely to happen. With a high voltage CDI, on a misfire the voltage will rise to the available voltage determined by the voltage the discharge capacitor is charged to and the turns ratio of the coil. With an inductive system, the voltage will rise until the energy runs out or is clamped by a zener diode, or the condenser in the Kettering system. The difference is, CDI is less likely to create a misfire because of the higher immediate power and the power factor advantage that helps even when there is no fouling.
    This discovery of mine does not alter anything, but has solved several experimental observations that seemed contradictory. This theory ties it all together and things make sense now. I am going to re-write my article on voltage overshoot because this ties in with that as well.
    I don't own a Dino, but I like Taylor Spiral wound suppression HT wires. Just don't use the carbon wick variety. I use Taylor wire on my Volvo 1800. On my Morgan I use cheap bumble copper conductor wire and it contains the energy of the relatively low voltage CDI really well. I recommend making sure that secondary side resistance is no higher than 10 thousand ohms from the wires, spark plugs, spark plug boots(if they are the resistive type) etc.
    If you are getting fouling with the iridium plugs, you could try opening up the gap just a little. The fine wire reduces the voltage required to fire the plug and this can lead to fouling more quickly. Try another 5 thou and see if it doesn't work with your inductive system. Fred
  9. Fred Winterburn
    Jan 27, 2015
    75
    Tony, regarding the iridium plugs I should have mentioned that opening up the plug gap will increase the intensity of the spark (higher power) with inductive ignitions and will blast off fouling deposits more easily. On old tractors or cars that used very narrow plug gaps, carbon would build up and make the plug gap narrower resulting in a weak spark, plus cause some shunt resistance to compound the problem. Misfires would occur. Pulling a plug lead and making a second gap would raise the voltage threshold and sometimes get the plug to fire. It was a good way of tracking down a miss to find out which cylinder was at fault. Fred
  10. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Thanks Fred, I am using a good quality silicone lead at the moment and all good so far.
    Question - does all this affect spark (burn) duration?
  11. Skippr1999
    Skippr1999 F1 Rookie
    4,498
    #11 Skippr1999, Dec 8, 2018
    Thanks for the info Fred. I haven’t installed the box you sent me yet but will soon.
    Should I keep the original ignition coil or do you recommend a different one ?
    My plugs are NGK
    Bpr7Eix
    Skipp
  12. Fred Winterburn
    Jan 27, 2015
    75
    Tony, Siicone is the jacket, but wha type of conductor is inside? With an inductive ignition two things affect the spark duration. Energy is the first, so if it is wasted in high resistances, that will result in a shorter spark. The second is plug gap, so the wider the gap the more energy that is consumed at the start and so less is available during the long trailing glow phase (that is probably useless anyway) Fred
    "TonyL, post: 146341396, member: 54594"]Thanks Fred, I am using a good quality silicone lead at the moment and all good so far.
    Question - does all this affect spark (burn) duration?[/QUOTE]
  13. Fred Winterburn
    Jan 27, 2015
    75
    Skipp, the retrofit is designed to be plug and play for your original box, so you can use the original type coil. If it ever fails, you can replace it with something less expensive or available. Old coils can be failure prone. I would use a 1.5 ohm inductive type canister coil if that happens. There will be less energy transferred(although I have never tested an original two terminal Dino coil) but you won't notice the difference in performance. Fred
  14. Skippr1999
    4,498
    Thanks Fred
  15. Carby tuning
    Carby tuning Rookie
    Mar 14, 2021
    9
    Greg kuchel
    please explain what you quantify as fouled plug or even better would be a picture of a fouled plug that you refer too.
    Thanks.
  16. Fred Winterburn
    Jan 27, 2015
    75
    10 million ohms or less shunt resistance (IE, in parallel with the spark gap) usually from carbon deposits on the business end of the spark plug. It can be on the spark plug itself or external from carbon tracking or contaminated or wet insulation. Sometimes the fouling deposits are arranged such that there are insulating spaces between areas of conductive deposits. If that happens the voltage has to rise far enough for the effective resistance to actually become conductive, or moisture bridges the gaps making the fouling conductive with less voltage applied. You may or may not be able to measure fouling resistance with a low voltage multi-meter depending on whether the conductive bits are continuous or not continuous as described above. I do know that most CDIs will fire a spark plug that is completely black with soot while with inductive systems there will be at least some misfires. Fred
  17. Carby tuning
    Carby tuning Rookie
    Mar 14, 2021
    9
    Greg kuchel
    Thankyou for your reply.
    I’m trying to upload some pics of plugs and spark that I take before tuning and after I have made changes.
    You might find what I have found over the years to be of interest as I have of what I’ve read from your posts in various forums.
  18. Carby tuning
    Carby tuning Rookie
    Mar 14, 2021
    9
    Greg kuchel
    This job in particular has always stood out to me.
    It was a 3.3litre Holden 6cyl with 2 stromberg carburettors and Bosch hei ignition.
    I went there to fix a “rich” running engine and to find some more power. The carburettors had been reconditioned to factory specs for this mildly cammed engine with slightly raised compression.
    I fixed the rich running engine and found much smoother power delivery by changing both the plug type first then the coil.
    Once a more consistent flame kernel at firing time was established by more current flow across the plug,the plug showed the true afr colour in the cylinder at firing time. I find on jobs that whenever cylinders are given finer fuel droplets the amp demand across the plug goes up.
    CDI I find is far superior then inductive. I have never seen inductive beat CDI yet one the fuel droplets are finer.
  19. Carby tuning
    Carby tuning Rookie
    Mar 14, 2021
    9
    Greg kuchel
    This is ICE ignition with their booster vs MSD with a very good coil.
    ICE is inductive and MSD is CDI.
    When I use CDI it allows me to use finer fuel drops and open up the plug gaps and engage more fuel molecules,but... they must be fine and very well atomised or you can go backwards.
    I find that ICE ( inductive ) does not build the flame kernel fast enough and this in turn builds less cylinder pressure by TDC.. it’s very noticeable and you can hear and feel it in the engines.
    I tune street cars with power ranges between 200-800hp..
    Feel free to ask any questions..
  20. Carby tuning
    Carby tuning Rookie
    Mar 14, 2021
    9
    Greg kuchel
    This is a plug from a 650hp carburettors engine on 98 pump unleaded fuel with a crane ignition.
    The ignition is very powerful and provides a very good spark profile. It is CDI ignition and starts the flame kernel very fast that builds heat very quickly. You have to be careful with this ignition as it can produce a lot of nox gas at firing time.
    With this ignition you can use a 50 thou plug gap and keep adding fine fuel droplets and keep making power.. note how the flat section of the centre electrode is very etched from the amps energy... I find this is key in tuning if you want smooth power.
  21. Carby tuning
    Carby tuning Rookie
    Mar 14, 2021
    9
    Greg kuchel
    I might add that this tan colour on the porcelain is very representative to a 12.7-12.8 afr at plug firing time.. it represents a good snapshot of the GASSED AFR condition around the plug at firing time.
  22. Carby tuning
    Carby tuning Rookie
    Mar 14, 2021
    9
    Greg kuchel
    Note also that the straight section ( side ) of the centre electrode from the porcelain to the top of the centre electrode is kept clean of carbon on the tan plugs. Generally this area on a plug is used to set the heat range of a plug but I find that with CDI I can get that section to be clean of carbon no matter what heat range I use..as long as the fuel is well atomised in that area.
  23. Fred Winterburn
    Jan 27, 2015
    75
    Carby, Thanks for all of that! Makes one wonder why most manufacturers did not and still do not use CDI. Perhaps there are some I don't know about that do today. A good forum for you to post your findings and experience would be on Speed talk. https://www.speed-talk.com/forum/ I really enjoy building and experimenting with my simple (really my father's design but tweaked) CDI and getting feedback from customers on how it improved their cars. My sales are shifting heavily towards the 6V units and I've gotten behind again. Fred
  24. Carby tuning
    Carby tuning Rookie
    Mar 14, 2021
    9
    Greg kuchel
    Fred,I’m building a test car with a carbureted LS engine.. at some stage I would be interested in trying your CDI and comparing it.
    Have you compared yours to the MSD or Crane units before?
    Here is a comparison between the msd blaster SS coil vs the msd big blue coil,both with the same msd cdi digital 6 box.. interesting huh?
    The power and smoothness of the engine once tuned made the client very happy.. that is his car.
  25. Carby tuning
    Carby tuning Rookie
    Mar 14, 2021
    9
    Greg kuchel
    Fred. Can you give me your opinion on the following.
    In the spark pic the one on the left.. I think it’s a good example of the gasses being ironised prior to the current flowing.. I think the haze around the main current flowing is this taking place. What do you think ? Or am I way off..
