Catalist question | FerrariChat
Catalist question
Discussion in '308/328' started by krisdisk, Oct 2, 2018.
  1. krisdisk
    krisdisk Formula Junior
    Mar 29, 2009
    500
    Flanders Belgium
    Kris De Bruyne
    Hi guys, I've got a easy question, and hopefully I'll get an easy answer. Here goes: since I own my 308, I always found the car made all sorts of noise, like tiny explosions while running. The car now had a major service but the noise is still there. Now I think it might have something to do with the cats that were replaced with straight pipes. Does anyone had simular experiences?
    Also what are my options? My guess is reinstalling new (or used cats), but what if I want to keep the straight pipes? Will I have to change the camshafts?
    Thanks for your advice guys!
  2. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,691
    Mike 996
    Can't comment on the "tiny explosions" but the exhaust sound level is louder with a straight pipe than with a cat. Perhaps you are just hearing the sound from the absence of a cat? I sort of liken it to the muscle cars where, typically, the exhaust manifolds were replaced with headers. The sound changed considerably, adding a "rickety-tick" sound to the exhaust note. Essentially, removing the Cat removes some muffling so that MIGHT be the cause of the sound difference.
    Could you record/post a video with the sound of the engine/exhaust?
  3. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Not seeing how changing camshafts would be part of the equation.
  4. Dr Tommy Cosgrove
    35,350
    Birmingham, AL
    Tommy
    I heard it on mine with a tubi test pipe. Mostly when I lifted the throttle at speed.
    It's gone with my Hyperflow.
    You can leave your cams alone. No worries with them either way.
