Carbon Ceramic Disc Cracks | FerrariChat
Discussion in 'Middle East' started by mark.ruffley, Apr 6, 2017.
  1. mark.ruffley
    mark.ruffley Rookie
    Mar 13, 2017
    32
    Hi All... I've just seen one of my rear rotors on my F430 is cracked in 2 places. Both small cracks... Car has 14,000km, 2008... Is this normal and needs attention / repair / replacement? Brakes working fine.. Thanks
    Sent from my SM-G930F using Tapatalk
  2. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    37,964
    houston/geneva
    Ross
    the danger while driving normally is relatively small.
    if you go to a track day and do a lot of heavy braking, then its different.
    the risk is that the rotor will shatter and leave you with reduced braking power, and perhaps other damage.
    $5k per corner to repair....ask me how i know ;)
  3. mark.ruffley
    mark.ruffley Rookie
    Mar 13, 2017
    32
    Thanks Ross. I'm in Dubai so repair is not an option unfortunately... Am looking for hardly used, one careful owner!
  4. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,126
    Fort Washington, PA
    John S
    Mark - ever check into swapping to steel rotor setup? A lot of guys I know will swap over so it costs a fraction of the cost to replace the brakes when its time.
  5. mark.ruffley
    mark.ruffley Rookie
    Mar 13, 2017
    32
    It's a consideration but wanted to keep car as original as possible. Looks like I've found a 'slightly' used carbon disc so good to go.. Thanks.
  6. mark.ruffley
    mark.ruffley Rookie
    Mar 13, 2017
    32
    Hi all. Got a slightly used CCM rotor from Ferrparts. Took less than 48hrs to arrive in Dubai via DHL. Thanks Russ.. Great customer service.
