HOU - Can someone recommend me a wheel refinishing vendor? | FerrariChat
HOU Can someone recommend me a wheel refinishing vendor?
Discussion in 'Texas' started by timwu12, Feb 3, 2021.
  1. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    I have a set of 18" Ferrari 360 Challenge wheels that were recently refinished by Rim Repair Houston.
    They did a terrible job and scratched the circumference of the rear lip in the process of powder coating it and gave me attitude when I asked them to fix it. They also didn't mask the rear hub face or the bolt holes so they're now filled with powder coat and paint.
    Can someone recommend a reputable wheel repair place that knows what they're doing to redo my wheels? I don't have any faith in Rim Repair Houston to fix their mistake.
  2. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    So I have used Rollos before, but that was to repair a bend / repair a chrome outer lip
    I almost used Sab as well, but he couldn't work on my chrome SSRs, so can't speak from experience but from my friends they say he does great work
    I've used Curtis at Clarity but he takes a long long time (mostly due to covid situation) however his work is impeccable - but I'm not sure if he can do wheel work - however it sounds like you don't need wheel work, but paint work
    If you don't mind me asking, how much did rim repair charge you?
  3. timwu12
    Oct 31, 2014
    918
    TX
    $135/wheel was what they charged.
    I thought Curtis went out of business, is he still around in another capacity?
  4. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
  5. blkfxstc
    blkfxstc Formula Junior
    872
    TX
    Eric
    Great timing for this thread!
    I just bought a F12 that has some curb rash on one of the front wheels, which of the above recommendations would be best for that? Thanks in advance!
  6. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    For curb rash, I would do Rollos - mostly because I have actually experience with them, they are on Star Ln near the FoH dealership (somewhat)
    It's across STF Fitness (that's where I work out) and almost next door to Autodynamics (where I usually list my cars)
    blkfxstc likes this.
  7. Shark01
    Shark01 F1 Veteran
    Jun 25, 2005
    6,462
    I used Rollos to repaint my 6.0 wheels from black (must have been a whack job to do that to one of the best wheel design of all time) back to pretty factory silver. Did a great job....
    And I need to now go back to them to repaint my Ford GT wheels....what is the fascination with black wheels?
  8. blkfxstc
    872
    TX
    Eric
    Thanks all, I will give them a call.
  9. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,830
    Dallas Texas
    If you know you know
    FWIW, the oven that are normally used have a conveyer the wheel sits on as it travels through. That surface is what causes the scratched appearance, being on the back side of the wheel most owners would never know nor care.. BUT Ferrari are different.
    As for not covering the mounting surface and bolt holes, that sounds like an oversight, and should be easily addressed.
    Find a company that hangs their wheels or use a reputable paint shop to refinish them.
    Question about the price, does the $135.00 include mounting and balancing the tire back on the wheel?
    GL in your search in Houston.
    S
    vraa likes this.
  10. timwu12
    Oct 31, 2014
    918
    TX
    I'm not sure if their ovens have a conveyer or if they're hung but when I brought up the scratches he immediately knew what it was from.
    When they spray the wheels, they place them on a 2 tiered riser that looks like stadium bleacher seats so that the face of the wheel is facing them for them to spray. As they rotate the wheel while they're spraying it, that rotation from metal to metal contact on the backside is what caused the scratches. I wish it was only a superficial scratch to the finish but it went further than that and into the aluminum in several spots on all 4 wheels.
    When I brought it up to them, he said it's the back side, no one sees that and tried to use that as his excuse to weasel out of fixing it. Ferrari or not, that level of carelessness in quality should never be acceptable to anyone.
    As to the powdered back hub face and bolt holes, he says he does that for all wheels and has never had an issue so it was on purpose!
    All in all, not a good experience and definitely won't be going back.
    Pics after me picking it up, getting back home and looking at the back side. It didn't occur to me to check the back while at the shop so lesson learned, look on both sides next time!
    SAFE4NOW likes this.
  11. BigTex
    79,368
    Houston, Texas
    Bubba
    Man, that looks like azz.....I don't think the mounting surface is ever painted, in my experience.
  12. timwu12
    Oct 31, 2014
    918
    TX
    you're right, it's not supposed to be painted.
    painting the hub face can lead to the wheel being mounted uneven due to extra layers between the mounting surface and can cause a vibration.
    painting the lug nut seat will compress the powder coat and can work a lug nut loose
  13. BigTex
    79,368
    Houston, Texas
    Bubba
    Perhaps a long discussion with Wheels America would yield a better result??
    Or clean up what you have, and wait for the next curb, having rattle canned the rear rim....I know powder coating is all the rage, but......
