California tyre pressures | FerrariChat
Discussion in 'California/Portofino/Roma' started by Awitty, Mar 4, 2011.
  1. Awitty
    Awitty Rookie
    Apr 26, 2010
    28
    Hi
    Can anyone tell me what the tyre pressures should be?
    The car has been stuck in the garage over winter and it's now showing a low pressure warning. Can't find the service manual.
  2. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,870
    Look at the sticker in the door jam.
    Around 32 psi I think.
  3. Awitty
    Awitty Rookie
    Apr 26, 2010
    28
    Cool. Didn't think of that.
    2.2 bar for both front and rear.
    Thanks for your help
  4. RickLederman
    RickLederman F1 Rookie
    2,836
    Swanton Ohio
    Rick Lederman
    Mine says Front 35, Rear 32 ... it is raining and I got wet checking it out in the parking lot at work. FYI the car does a bit of understeer with this pressure setup. If they are both set to the same pressure the understeer goes away so I set mine to 34 all the way around. On the track I cut that back to 32 all the way around cold.
    Rick
  5. Awitty
    Awitty Rookie
    Apr 26, 2010
    28
    Thanks for the info Rick. Mine says 32 all round.
    Hope you don't catch a cold on my part!
  6. tazandjan
    39,122
    If you go to this website, you can download an owners manual and put it on your computer hard drive. Then you can look things up without having to have access to the car. Looks like all the tires except the 20" Bridgestones recommend, in the owners manual, 35/32 (2.4/2.2 bars) and those are 32/32 (2.2/2.2 bars). The data plate still has priority because tires change and the OM will likely not be updated until the M appears.
    Taz
    Terry Phillips
    http://www.ferraridatabase.com/The_Downloads/Downloads.htm
