Boxer window lift cable replacement | FerrariChat
Discussion in 'Boxers/TR/M' started by Ludwig, May 10, 2020.
  1. Ludwig
    Ludwig Formula Junior
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    I have a partially frayed cable on one of my door lifts for the Boxer and I assumed it whould not be too difficult to replace. The problem is the disassembly of the actual spool mechanism. I need to have access to both sides to route and secure the cable and i don't see an obvious way to remove the winding drum from the worm gear drive. It looks like it should separate and slide off the shaft seemingly parting where there are toothed connections. I tried gentle persuasion but am reluctant to be more aggressive if i am missing something obvious.
    Really appreciate any advice. Image Unavailable, Please Login
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,934
    romano schwabel
    put the wire around the drum and fix it with 1 or 2 wide cable ties that the wire will not move always
  3. Ludwig
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
  4. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,159
    Canada
    Newman
    The black disc is a spring washer. I use a press, you can use a vise and a socket to clear the shaft then remove the snap ring.
